3rd Gen Remote Start Using OEM Remote
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nickj718, Dec 7, 2016.
  1. Dec 31, 2016 at 12:04 PM
    #741
    PJnc284
    PJnc284 Well-Known Member
    Garner, NC
    2016 Tacoma TRD Off Road 4x4
    If only they made those packs in 7's since that's all you need. lol Ebay seems to be the cheapest route. The Posi-locks could work on the wires for the auto-headlights if you have them but probably just as easy to use a lineman's splice and solder.
  2. Dec 31, 2016 at 12:43 PM
    #742
    bucktowntaco
    bucktowntaco Well-Known Member
    New Orleans
    2017 MGM DCSB TRD Sport
    I picked up a pack of the 24-26awg and a pack of 20-22awg. I plan to solder the 12v power wire.
  3. Dec 31, 2016 at 12:49 PM
    #743
    PJnc284
    Garner, NC
    Those sound like the posi-lock sizes and not the posi-taps? Might work but would require cutting each wire
  4. Dec 31, 2016 at 1:46 PM
    #744
    bucktowntaco
    New Orleans
    24-26awg item#ZRTL-640-6
    20-22awg item #ZRTL-641-6
    They are posi-taps. Just double checked their website. Thought for a second I ordered the wrong ones.
  5. Dec 31, 2016 at 1:53 PM
    #745
    Gabtap
    Gabtap Well-Known Member
    2017 Black Offroad
    Installed mine no problem, thanks :)
    gpb likes this.
  6. Dec 31, 2016 at 1:58 PM
    #746
    BadRobot62
    BadRobot62 Well-Known Member
    David
    2017 Tacoma Sport 4x4
    Level kit,
    What are you guys using to cover your carpet when doing the soldering
    Thanks
    David
  7. Dec 31, 2016 at 2:05 PM
    #747
    PJnc284
    Garner, NC
    Make sure you're not cold soldering (putting the solder to the iron tip) or getting things too hot and you should be able to minimize and drops. I didn't use anything on the floor but always better safe than sorry though. Believe @gpb also used aluminum foil to shield the wires from where he was soldering.
    gpb likes this.
  8. Dec 31, 2016 at 2:09 PM
    #748
    BadRobot62
    David
    Level kit,
    Thanks for the tips, tin foil sounds like a great idea.
  9. Dec 31, 2016 at 2:21 PM
    #749
    PJnc284
    Garner, NC
    Believe it's generally used to clean wires that have oxidized after being exposed for a while and help make sure you have a clean joint. I didn't use any but some swear by it. I'd probably avoid using that big thick solder you have there also.
    Hank Heel and gpb like this.
  10. Dec 31, 2016 at 2:30 PM
    #750
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Correct. Helps guard against human error. Particularly when using a butane iron with hot exhaust ports.
    Generally I've used it when soldering copper plumbing, helps clean up oxidized copper tubing. Typically not needed when soldering automotive wires, especially when you're using a rosin core solder.
    I used a thin rosin core solder for this, as in 0.05in diameter made for electronics. Easier to work with since you don't end up flooding your work with solder. This is close to what I have, the actual spool I use is something I've had twenty years: https://www.radioshack.com/products/rosin-core-solder-1-5-oz
    Hank Heel likes this.
  11. Dec 31, 2016 at 3:33 PM
    #751
    gpb
    Atlanta
    Should be fine. If that was in my parts drawer I'd use without a second thought. Not enough difference to go buy something else.
    bigshane likes this.
  12. Dec 31, 2016 at 4:17 PM
    #752
    facefirst
    facefirst Well-Known Member
    Geoff
    Cleveland, OH
    2017 MGM TRD Off Road DCSB
    Nothing because I know how to solder properly.
  13. Dec 31, 2016 at 4:19 PM
    #753
    BadRobot62
    David
    Level kit,
    So your saying knowing how to solder properly will keep me from making a mess ? must be nice. :)
  14. Dec 31, 2016 at 4:25 PM
    #754
    facefirst
    Geoff
    Cleveland, OH
    Haha. It definitely helps.
  15. Dec 31, 2016 at 4:29 PM
    #755
    gpb
    Atlanta
    LOL. I just left my all weather mat in place. I didn't drip any solder on it. Shouldn't happen if you're using proper technique: heat the wire with the iron, touch the solder to it just long enough to sweat solder into the wires. If you're dropping solder you're doing something improperly.
    If I had carpet mats I probably would have put down some cardboard or newspaper just in case though. :)
    When I needed to set my butane iron down I set it on its inbuit stand on the cast aluminum running board.
  16. Dec 31, 2016 at 4:31 PM
    #756
    PJnc284
    Garner, NC
    I just said "here hold this" and hand it to my dad. :thumbsup: He just took it to go get something to eat and had to remote start it. :rolleyes:
  17. Dec 31, 2016 at 5:27 PM
    #757
    gpb
    Atlanta
    Looks good!
    You'll find the braided copper wire soaks up more of the solder than solid core does.
    Hank Heel and bigshane like this.
  18. Dec 31, 2016 at 5:53 PM
    #758
    PJnc284
    Garner, NC
    Yeah not much you can do with that single strand mess. With the braided you can actually see it fill in between the individual wire strands. Use just enough to fill in but not completely coat the wraps as you still want to somewhat see the outline of the outer wraps and not just a big giant glob of solder. Also helps with heat transfer to "tin" the iron tip or get a little bit of solder on the tip prior to trying to solder the wires. A wet sponge after finishing each joint can help keep the tip clean.
  19. Dec 31, 2016 at 6:03 PM
    #759
    facefirst
    Geoff
    Cleveland, OH
    You have to tin always. Leaving a solder tip with no tinning is a big no-no.
    Wet sponge is fine for cleaning off solder but I use those gold colored Hakko tip cleaners. It's worth it's weight in gold.
  20. Dec 31, 2016 at 8:11 PM
    #760
    northwest_inferno
    northwest_inferno Active Member
    Long Beach, WA
    2017 Inferno Tacoma SR5 4x4
    FORTIN EVO ONE Remote Start
    gpb and Hank Heel like this.
