3rd gen roof weather strips
Discussion in 'Northern California' started by Anonymoustacoma2020, Apr 30, 2021.
  1. Apr 30, 2021 at 1:18 PM
    Anonymoustacoma2020
    Anonymoustacoma2020 [OP] Member
    Anyone in the Fresno area have their roof weather strips left after placing an OEM roof rail. Messed up mine when going to place my prinsu cab rack
  2. May 2, 2021 at 1:59 PM
    ToYoda4x4
    ToYoda4x4 Well-Known Member
    2019 Sport
    I'm curious how you messed yours up? I just bought a used prinsu and swapped roof weather strips with the seller. He cut his weatherstrips to mount the rack directly to the roof and used silicone to prevent any leaks so the weather strips he gave me came in 3 pieces versus the one original piece. Can't you use the weather strips you have and add silicone to fill in any gaps in the seal?
    Mark77 likes this.
  3. May 2, 2021 at 8:36 PM
    Anonymoustacoma2020
    I was trying to drill through the weather strip to have a more clean look. Ended up just cutting and doing what you mentioned. Still looks great and was much easier to do.
  4. May 3, 2021 at 8:27 PM
    ETALATE
    ETALATE Non Sum Qualis Eram
    Burlingame, CA
    2011 DCSB TRD OR
    2nd gen strips will work too fyi
    Leeder1, TegoTaco and HI_Taco like this.
  5. Jan 7, 2022 at 2:48 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I realize this thread is old but I’m having this issue now. I removed my Prinsu rack and sold it, then tried to use silicon to fill in the holes where the roof rack was mounted.
    I used commercial-grade silicon and the roof still leaks. I’m not sure what the issue is but now it seems that I have to spend $3,000,000 to buy two new pieces of weatherstripping and replace it completely.
    It’s not a leak I can ignore, I tried doing that for a while but it was literally dripping water on my head the other day when it was raining.
    If anyone has any suggestions I could try before spending the outrageous amount of money they want for two pieces of rubber weatherstripping, I’d greatly appreciate any advice; I have no clue how the water is penetrating the silicon.
  6. Jan 7, 2022 at 2:54 PM
    Reddirtnaps
    Reddirtnaps Well-Known Member
    Oklahoma
    2019 DCSB 99 UZJ100
    https://www.automotiveauthorityllc....toyota-tacoma-black-roof-top-trim-molding-kit
    Heres a cheap alternative.
    You probably didn't clean the old silicone out well enough, but you could probably run a bolt in and out to clean it out and try again.
    If I ever remove my rack id probably fill the holes in with silicone then put the 3m paint protectant over the holes before siliconing the weatherstripping back down.
  7. Jan 7, 2022 at 6:57 PM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Thanks for the link, that’s a life saver. I’ll definitely buy those and give them a shot before I dish out the cash for the OEM strips.
    That’s some good info on plugging the holes. I used plastic snap screws (same kind that hold the bumper on) to fill the holes. Then covered those with silicon; clearly didn’t work out lol
  8. Jan 8, 2022 at 7:17 AM
    Reddirtnaps
    Oklahoma
    2019 DCSB 99 UZJ100
    Yeah that was definitely your problem! You can use those snap screw to fill the holes if you want to but you wanna fill the holes in with silicon before you slam those bad boys in. The weatherstripping isn’t the problem so if you’re replacing them because of the leak you’re wasting your money. Just pull those plugs and reseal the holes generously and you’ll be fine.
    Road_Warrior[QUOTED] likes this.
  9. Jan 8, 2022 at 8:01 AM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Oh awesome, thanks man. I’ll do that instead of getting the new weather stripping.
    Only problem is I will have to dig out all the silicone to pull those plugs up. Oh well, live and learn.
    Reddirtnaps[QUOTED] likes this.
  10. Mar 5, 2023 at 3:44 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    confirmed?
  11. Mar 7, 2023 at 7:38 PM
    erok81
    erok81 Well-Known Member
    Imposter
    I’m way late but use flex seal tape over the holes. No chance will it leak.
  12. Mar 7, 2023 at 7:54 PM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    I appreciate the info! Funny enough, that’s exactly what I wound up using and I haven’t had any issues since. That stuff is awesome.
    erok81[QUOTED] likes this.
  13. Mar 7, 2023 at 8:28 PM
    erok81
    Imposter
    I used it for the exact same thing. Zero leaks as well. It’s amazing how it sticks to wet stuff too. I used it for something else one just to hold some cardboard over a hole. Masking tape, fell right off. Duck tape, fell right off. Flex tape not only stuck right away but was almost impossible to get off the next day.
  14. Mar 8, 2023 at 5:10 AM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Yeah that stuff is gold! I bought a can of the spray to have on hand in case I need it after seeing how good the tape works. I think in a few years when the silicon I used to seal the holes gets old, I might use the flex seal spray to seal it up again.
