3rd gen rwd to 4x4?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cemsport45, Sep 18, 2024.
  1. Sep 18, 2024 at 1:12 PM
    cemsport45
    cemsport45 [OP] New Member
    Ben
    20 trd sport
    swap
    I have a 2020 trd sport rwd. I know the suggested idea of just buying a new truck with 4x4 but i don't want to. I want to learn how to do the swap myself. I've done some research as of right now I will most likely need a 4x4 trd sport transmission. I front dif. CV axles. and the front and rear drive shaft. As for the transfer case I was thinking I would go with the fj one because itll save some wiring. But my biggest concern is the wiring. What would I need to due to in that sense. Ive seen some people say I wont need to wire anything up besides the dash lights for 4wd? is that true? Would my ecu still work with the 4wd parts? I need some advice and direction. Thanks
  2. Sep 18, 2024 at 1:17 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Anything is possible with enough time and money! Worth the effort? I doubt it but one thing for sure is you will be without your truck for awhile. This is not a weekend/case of beer undertaking.
    PS: Welcome to TW and have fun with your effort!
    BillF1564, Taco22trdor, Chew and 2 others like this.
  3. Sep 18, 2024 at 1:18 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    You'll wish you had before it's done.
  4. Sep 18, 2024 at 1:23 PM
    jmneill
    SE
    Closer to a drink yourself to death before it's done thing.
  5. Sep 18, 2024 at 1:36 PM
    ericin1984
    ericin1984 Well-Known Member
    2023 TRD OR Auto
    You will end up completely upside down on the cost of doing vs the value of the result. The truck is likely to be worth less than it was in 2WD, due to the modifications and the fact that the VIN will say it is a 2WD truck. It will be valued, essentially, as a rebuild.
  6. Sep 18, 2024 at 1:37 PM
    TacoGranny
    TacoGranny Well-Known Member
    2020 TRDOR DCSB Cement 6MT
    33's, Sliders, Skid Plates, Softopper, ATH rear bumper
    https://www.tacomaworld.com/threads/05-15-2wd-to-4wd-conversion-guide-for-dummies.716703/
    This is probably as close as you're going to get for a guide.
    As far as advice and direction? It's 100% not worth the time or the money just because you want to learn how to do it yourself, with absolutely no guarantee that it will work or you won't ruin something much more expensive in the process. Resale value goes out the window immediately, nobody would ever buy a 2wd to 4wd truck done by someone in their garage, or at least they wouldn't pay nearly what an unmolested 2wd or 4wd truck would fetch, so you're stuck with the truck forever. Buy a beater 1st gen and try it on that if you have the itch to work with your hands and learn about the process, at least you aren't tanking the value of a $40k+ truck just because you feel like it.
    BillF1564, Barsoom, Chew and 3 others like this.
  7. Sep 18, 2024 at 1:39 PM
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    Forget about doing 4x4 conversion, not worth the time, or money. Better off buying good used 4x4, no need buy brand new.
  8. Sep 18, 2024 at 2:01 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
  9. Sep 18, 2024 at 2:11 PM
    2020TacomaGuy
    2020TacomaGuy Well-Known Member
    2020 4x4 DCSB SR5
    This is definitely a Friday post. You're 2 days early. Repost on Friday you'll get more replies.
    BillF1564, kahanabob and Barsoom like this.
  10. Sep 18, 2024 at 2:13 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    This is the kind of thing you do to a beater project that already has no value, not a four year old truck. You'll spend a couple grand on parts and tools to do the job and lose about $15k on the value of the truck afterwards.
    Barsoom, 50Buck, Chew and 3 others like this.
  11. Sep 18, 2024 at 2:18 PM
    SGJarrod
    SGJarrod Jester of the Degen...
    STL
    23 TRD OR DCLB, Blue Crush
    I got a sticker and some cool valve stem caps...
    I think everyone has said exactly the truth. But if u must butcher ur truck, go full hog. Might as well LS swap it too.
  12. Sep 18, 2024 at 2:23 PM
    seang
    seang Eternal Noob
    TX
    17 White Off Road
    i considered it for about 5 minutes on my 2nd gen (RWD) when i got stuck in the mud on a kayaking trip for the 2nd time. I laughed at myself, then decided to trade it in for my current.
    stav, Barsoom and shakerhood like this.
  13. Sep 18, 2024 at 2:34 PM
    NC Gazzer
    NC Gazzer Well-Known Member
    Durham, NC
    1996 Tacoma 4wd 2.7 + 2023 TRD Sport
    Way early for April 1, mate!
    Malvolio and kahanabob like this.
  14. Sep 18, 2024 at 7:20 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Welcome to the forum :hattip:
    Can you do it - sure.
    Is it worth the time & effort? Probably not.
    Back in the days after dinosaurs roamed the earth but when vehicles still had breaker points & carburetors I did the 6 cylinder to V8 and automatic to manual swaps. :rolleyes:
    IF you had the identical vehicle with the desired drive train right next to the one you wanted to modify it was a lot of work transferring all the parts -- If you were gathering the parts piece by piece it was a lot more work still.
    I'm much older and a bit wiser from the experience - like what you have or buy what you want is my opinion.
  15. Sep 18, 2024 at 7:26 PM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    2025 Tundra Crew Max
    I'd bet on an ECU swap too, because of the extra functions that the traction control system is going to have with 4WD. ATRAC on a 4wd will be different than a 2WD.
    Like others said, this is better learned on an old beater than on a truck less than a decade old. You'll lose money hand over fist. If that is no concern and this is just a project you want to do, go for it, but if you need your truck to work reliably then this is a major risk.
    Post up a thread chronicling it all if you do decide to go at it. Just be ready for the flak you'll get for it.
    BillF1564 and Chew like this.
  16. Sep 18, 2024 at 7:40 PM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    The bot new member posts on TW have been getting out of hand recently. 1 and done
    Ricardo13x, kahanabob and Sprig like this.
  17. Sep 18, 2024 at 7:43 PM
    50Buck
    Doubt it's a bot post. Lots of people post up a question on lots of forums, and then it takes a few days to get back through and check them.
    23MGM[QUOTED] likes this.
  18. Sep 18, 2024 at 7:58 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Sounds like a great idea. Here’s my suggestion. Buy a “20 trd sport” 4x4 just like the 2wd you have. Then transfer all the 4x4 stuff to your 2wd and all the 2wd stuff from your truck to what was the 4wd. That way you get to experience the joy of making your 2wd a 4wd. And best of all you can sell the former 4wd which is now 2wd and almost break even cost wise.
  19. Sep 18, 2024 at 9:11 PM
    gdr
    gdr Well-Known Member
    Bill
    Temescal Valley, Ca.
    2016 Inferno Tacoma TRD OR 4x4
    You better check the frame. I think they are slightly different.
    kahanabob and SGJarrod like this.
  20. Sep 20, 2024 at 11:02 AM
    Sprig
    Ken
    The OP joined TW Wednesday, made a single somewhat bizarre post and has not signed on to tw again. Hasn’t looked at a single response. Three possibilities here, mom took away his computer privileges, it’s a bot, or a troll. On various sites I’m seeing more and more - join, make a single post (usually somewhat bizarre or dumb), sign off, never seen again. Time will tell, maybe the guy is legit, we shall see.
    Malvolio, kahanabob and auskip07 like this.
