3rd Gen Sanded Dipstick
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hiPSI, Oct 2, 2023.
  1. Oct 2, 2023 at 6:15 PM
    hiPSI
    hiPSI [OP] Laminar Flow
    South Carolina
    2024 Long Tundra
    Alright,
    For some of you new guys, oil does not stick well to stock Dipstick. So, get you a piece of 400 grit sandpaper and sand up to the full hole. Sticks good and easy to read.
    I just did my 5K oil level check. Perfectly full and a nice honey color. What does this mean?
    If I had a catch can, no oil would be in there because no oil is missing.
    What else does it mean? By the color, it means not an undue amount of soot from detonation is in the oil. Means no sludge is developing.
    Now, I could care less if you run a can and change your oil every 3K miles. You do you.
    But for the ones here with a shred of logic and common sense? My level and color means no blowby or leaks and good to go the normal 10K between changes. It's only at 35K.
  2. Oct 2, 2023 at 6:18 PM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    No way I’d run a brand new engine to 10k miles before changing oil and filter. 5k miles max throughly out life of the truck
  3. Oct 2, 2023 at 6:19 PM
    hiPSI
    South Carolina
    2024 Long Tundra
    Again, you do you. Several thousand Blackstone Lab oil sample reports disagree with you tho.
    Tocamo, Malvolio, Lt. Dangle and 15 others like this.
  4. Oct 2, 2023 at 6:22 PM
    19992021Taco
    19992021Taco Well-Known Member
    1999 and 2021 Tacoma
    Oh boy! It's a always a good time for an oil fight... :argue:
  5. Oct 2, 2023 at 6:22 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    For best results, sand over tube opening
  6. Oct 2, 2023 at 6:24 PM
    hiPSI
    South Carolina
    2024 Long Tundra
    The sanding part was the important news. The other was just the results of the check.
    Northerntaco69 and RustyGreen like this.
  7. Oct 2, 2023 at 6:25 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
  8. Oct 2, 2023 at 6:28 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    I think you forgot the disclaimer:
    Do not taste the honey
    Malvolio, Squirt and StayinStock like this.
  9. Oct 2, 2023 at 6:29 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Approaching oil change #10 (100k miles) but only because I dont like to give people money unless its for tattoos or Grizzly.
    Diskoball, Malvolio, Junkhead and 5 others like this.
  10. Oct 2, 2023 at 6:30 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    If someone is dumb enough to taste it they deserve what they get. :puke:
    Squirt, TomTwo, shakerhood and 2 others like this.
  11. Oct 2, 2023 at 6:39 PM
    hiPSI
    South Carolina
    2024 Long Tundra
    You would be surprised at how many times I have tasted oil throughout the years...
  12. Oct 2, 2023 at 6:40 PM
    Bill0351
    Bill0351 Well-Known Member
    Bill
    2023 SR V6 4x4
    Tires/Cap
    Actually, this reminded me that I wanted to sand my dipstick.
    It also reminded me that changing my oil every 5,000 miles isn’t really necessary, but old habits die hard, and I tend to idle my vehicles a lot for AC and heat.
    Hasn’t cost me anything yet, because I get free 5k oil changes for the first 24,000 miles at the dealership.
    hiPSI[OP] likes this.
  13. Oct 2, 2023 at 6:41 PM
    hiPSI
    South Carolina
    2024 Long Tundra
    That's me. Your Public Service Announcer...
  14. Oct 2, 2023 at 7:34 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    I have adopted the method of giving the dip stick business end a light spritz of flat black spray paint.
    Very easy to see oil on a matt black surface.
    Prep as your spirit wills you. (I used brake clean and a scuff of sand paper)
    eta
    I just got an e-mail from the selling dealer service dept. notice that my taco was likely due for a going over. So I called to see what they had in mind. They nixed the oil change, "Every 10K is all that is needed". And I've always been a 5K sort of guy. I'm going to miss those recreational oil changes......;-)
    ScrippsRanch67 likes this.
  15. Oct 2, 2023 at 7:42 PM
    eurowner
    eurowner Duke Sky
    Scoty
    I sanded mine at 60,000 miles, since lighter is faster, now at 63,000 miles, I have not checked the dipstick.
  16. Oct 2, 2023 at 7:47 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Mobil 1 has oils that protect to 20,000 miles now.
    RIX TUX and hiPSI[OP] like this.
  17. Oct 2, 2023 at 7:59 PM
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    It doesn’t matter how long the oil is supposedly good for if the filter isn’t proven to still do its job at that mileage (which it isn’t).
  18. Oct 2, 2023 at 7:59 PM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    Now do filters.
    Junkhead likes this.
  19. Oct 2, 2023 at 8:00 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Thanks for reminding me I need to do my annual oil change... I typically don't get the mileage...
    msgs350, Tocamo, Junkhead and 3 others like this.
  20. Oct 2, 2023 at 8:32 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    i dont think TOYOTA would recommend 10k changes if the their filters were not up to it
    Tocamo, Lt. Dangle and Chew like this.
