3rd Gen Shifting & MPG SR vs OR
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sparky121, Nov 1, 2023.
  1. Nov 1, 2023 at 11:46 AM
    sparky121
    sparky121 [OP] Member
    The Zeppelin
    23 DCSB MGM
    After driving my new Tacoma for a few days I have noticed some odd things about my 23 TRDOR compared to my 21 SR.
    When I got the SR I noticed absolutely no weird shifting or lack of power like everyone talks about. It averaged around 19 MPG combined, I drive around 70-75 mph on the highway and about 2500 miles/month.
    On a trip over the weekend from STL to Peoria the 23 stayed in 5th gear for almost the whole drive ~75 mph and we averaged about 15.5 mpg on a pretty flat highway. Everyday average is around 17mpg.
    The 23 also seems to have a hard time holding 6th on a normal highway drive and the shift to 5th gear is slow.
    Not sure if this is just difference in tires/tire size, or if there is some gearing differences between the two, everything I can find says its the same.
    Not really a major complaint although not being able to hold 6th is strange. I've read most of the shifting issue threads but didn't see anyone comparing the different models.
    Curious if anyone else has had a similar experience with different 3rd gen years/trims. Also if anyone else has the same situation with 6th gear.
  2. Nov 1, 2023 at 12:17 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    If your sr was 2wd and the new off-road is 4wd, then that explains it. 2wd vehicles of the same model usually drives lighter than 4wd counterparts.
    Junkhead likes this.
  3. Nov 1, 2023 at 12:30 PM
    sparky121
    The Zeppelin
    23 DCSB MGM
    Should have noted that, both were DCSB 4x4 3.5 AT
  4. Nov 1, 2023 at 1:57 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    a small constant headwind can play a huge roll here, in either model
  5. Nov 1, 2023 at 2:19 PM
    sparky121
    The Zeppelin
    23 DCSB MGM
    That would make sense, it was dark for most of the trip so I had nothing to gauge the wind.
    Chew[QUOTED], Stevie17 and Junkhead like this.
  6. Nov 1, 2023 at 2:49 PM
    Motor Away
    Motor Away Well-Known Member
    I’d be curious what the difference in curb weight is between the SR and TRD OR. The SR has a heck of a lot less stuff…not even door emblems!
  7. Nov 1, 2023 at 2:51 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    If both 4x4s, makes no difference.
    Stevie17 and Chew like this.
  8. Nov 1, 2023 at 5:03 PM
    Ehahn84
    Ehahn84 Well-Known Member
    Oly, WA
    2021 DCLB TRD Off-Road MGM
    OTT. DD SS3. RLD Canopy. Yokohama G015.
    I'll play.
    I have a '21 TRDOR 4x4 and the shifting was total crap until I got it tuned. Did the OTT tune and that is all fine and dandy. The truck won't get above 15.5 mpg no matter what I do...full of tools/empty, canopy/no canopy. 15.5mpg with my 265/75R16 tires.
    I also have a '23 SR AC 2wd with the 4-cyl and for some reason I like this truck significantly more. It shifts better, feels peppier, just drives better. I know it won't get me places that the TRDOR will...but as an everyday driver it's 10x better. And, it gets 22.6mpg stock.
    sparky121[OP], IronratPR and bulalo like this.
  9. Nov 2, 2023 at 5:24 PM
    sparky121
    The Zeppelin
    23 DCSB MGM
    At least it’s consistent, that’s how my 1st gen was. 17mpg in the wind, with the wind, with 245’s, with 33’s, didn’t seem to matter it just was where it liked to be.
    The more I drive it the more I’m getting used its quirkiness. I had an outback prior to the 21 SR and that had a seriously strange transmission and was absolutely gutless so I was probably just happy to have more power with the Tacoma last time around.:burnrubber:
    Ehahn84[QUOTED] and Chew like this.
  10. Nov 2, 2023 at 8:21 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    I can assure just a few MPH of headwind, if steady, makes a difference. I’ve done it several times heading dead west on the interstate for 160 miles to a match, and 4 hours later turning back. Usually West in to the wind and east with. Of course weather changes, but it was repeatable. West was about 2-2.5 MPGs less, and then it picks up on the way home.
    TreeFortRichard likes this.
  11. Nov 2, 2023 at 8:26 PM
    toyotahenry
    toyotahenry N/A
    Houston, Texas
    2021 TRD OFF ROAD 4X4 ARMY GREEN
    I usually throw it into S6 on the highways. It’s the “eco mode” as i call it since it’ll try to stay in 6th gear at all times. might be slightly sluggish but one will gain the fuel economy in return.
    Canadian Caber likes this.
  12. Nov 2, 2023 at 8:27 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Has your 23 even gotten past the break in period yet?
    The SR will also come with tires more oriented to highway driving and have less rolling resistance.
  13. Nov 2, 2023 at 8:30 PM
    RedWings44
    Michigan
    S6 does not hold the truck in 6th. S-mode only limits the maximum gear the truck will go into. So S6 is the same as normal Drive. If you stop at a red light and select S2 to try and start in second, you're not actually in 2nd. You'll still be in 1st.
  14. Nov 2, 2023 at 8:53 PM
    toyotahenry
    toyotahenry N/A
    Houston, Texas
    you’re correct, it will not hold it in 6th indefinitely. however the truck will do its best to get to 6th when possible. i have experimented with this plenty of times before.. lol
    sparky121[OP] and Canadian Caber like this.
  15. Nov 3, 2023 at 5:58 AM
    mfalbojr
    mfalbojr Well-Known Member
    Kansas City, MO
    2024 TRD Sport Silver
    I have a 2017 Trd Sport. Recently it was at the dealership for service for a week. The dealership gave me a 2023 Sr5 to drive. It held 6th gear on the highway much better than my truck, shifted less than my truck. Only real difference in the trucks was tire size and a few hundred pounds. Minor difference in trucks, big difference in driving manors.
  16. Nov 3, 2023 at 6:54 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I have a 23 sport
    After the OTT tune, I regular to get 19.5-21.5. I do run ethanol free fuel. When running gas with ethanol, I normally lose about 1-1.5
  17. Nov 3, 2023 at 7:18 AM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    i recently did a 2000-mile trip. on the way, i averaged 20.5 mpg. i was surprised it was that good because i was often going 70-80 MPH. on the return, fuel mileage was about 18ish. i followed the same route both directions and actually drove a bit slower on the return.
    i had a head wind on the return which had some effect. also, it was much colder on the return. i noticed when the temperature drops below 30F, my fuel mileage drops by about 1 mpg.
  18. Nov 3, 2023 at 7:49 AM
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    My 2020 holds 6th gear like it should. Not sure what you are experiencing.
    2020 OR DCSB V6 Auto 4X4. Stock configuration.
  19. Nov 3, 2023 at 7:53 AM
    Newbie1983
    Newbie1983 Well-Known Member
    Rudy
    Yup. They do shift funky shifters
  20. Nov 3, 2023 at 8:05 AM
    sparky121
    The Zeppelin
    23 DCSB MGM
    This was my assumption, good to hear someone else with a similar experience.
