3rd Gen Speedometer Issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DonB, Mar 25, 2021.
  1. Mar 25, 2021 at 12:02 PM
    DonB
    DonB [OP] New Member
    2017 Tacoma SE
    My 2017 just started having speedometer issues last week. I have 35,000 miles and it's just out of warranty. I found some old threads, but no real solutions. Has anyone else had their speedometer intermittently stop working? Sometimes it doesn't work at all, other times it is off by 60 mph or more. It seems to reset and work normal after I shut the truck off and restart it.
    I called my local dealer and they acted like they have never heard of this issue. Anyone know what the root cause is?
    HondaGM likes this.
  2. Mar 25, 2021 at 12:04 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I'd start by checking the connections on the ABS sensors on each of the wheels. make sure they're good and tight
    HondaGM likes this.
  3. Mar 25, 2021 at 12:05 PM
    Tacospike
    Two Trucks
    The dial?
    Does the digital speedometer still work? I know, not the issue at hand but curious if it is the speedometer hand or if there is another issue if both stop.
    HondaGM and kahanabob like this.
  4. Mar 25, 2021 at 12:10 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    It's common. mine has from day 1, been ticky and sometimes just gets stuck. I have the extended warranty and before that's done I will get the cluster replaced. Take a video of it and show the dealer. I'm thinking he's full of shit like most car salesmen are.
    HondaGM likes this.
  5. Mar 25, 2021 at 12:19 PM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    check your frame wiring harness, your wheel speed sensors, and your ecm
    HondaGM likes this.
  6. Mar 25, 2021 at 1:55 PM
    Midnight beauty
    Midnight beauty Well-Known Member
    White mountains AZ
    2020 midnight black Tacoma TRD Sport
    Check the back of the cluster where the plugs go. I would also check the circuit board on the cluster.
    HondaGM likes this.
  7. May 16, 2024 at 10:53 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    I know this is an old thread ...but my 23 v6 AC speedometer is acting up.when you accelerate the needle is smooth as glass..but if you let off the gas and start slowing down real slow..its like it hangs and notchy on the decel..
    anybody else seeing this?
