3rd gen SPOD setups?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dentpusha, Apr 13, 2016.
  1. Apr 29, 2018 at 5:57 PM
    #101
    Colorado Crawler
    Colorado Crawler Well-Known Member
    2017 Black Tacoma TRD Off-Road
    Looks good.
  2. Apr 29, 2018 at 6:02 PM
    #102
    Colorado Crawler
    The Bantam also has some input trigger connections that make some other wiring simpler. You can set some inputs to trigger off of ignition. I want to wire in my dome light to use it for puddle lights and the Bantam will make that super simple.
    No more relays and all that crap with the Bantam. Just keeps it easy and clean. Plus I like that they use a cat5 cable to connect their LCD screen.
    It’s an investment but you get a lot of functionality and protection for all your goodies.
  3. Apr 29, 2018 at 6:27 PM
    #103
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    Just checked out the bantam on youtube and it seems to be the exact same as the source but smaller. Same amount of outputs, same setup for trigger wires. And Bluetooth which is built into the se with hd panel. Only thing is its half the size. Nice looking unit tho.
    Colorado Crawler and Alesimo like this.
  4. Apr 30, 2018 at 9:56 PM
    #104
    Colorado Crawler
    Here is the comparison chart from sPOD.
  5. May 1, 2018 at 10:01 AM
    #105
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    2020 Jeep Wrangler JLUD
    That's pretty handy. Can't say I understand a ton of it haha
    Colorado Crawler likes this.
  6. May 1, 2018 at 12:49 PM
    #106
    Colorado Crawler
    I was under the impression you had to buy the additional Bluetooth adapter ($135) for any sPOD SE unit and according to the chart above that seems accurate. I also don't believe the SE has the additional trigger inputs outside of the ignition input. So IMO the smaller size (half), Bluetooth function out of the box, input triggers and added electrical protection.....it's a bargain considering it is only $85 extra. That is if you can get over paying $800+ in the first place.
  7. May 1, 2018 at 12:59 PM
    #107
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    My SE HD has Bluetooth built in. What's the ignition module?
  8. May 1, 2018 at 1:05 PM
    #108
    nwAdamR
    nwAdamR Well-Known Member
    Adam
    SW PDX
    2016 Tacoma TRD OR LB AT MGM
    Same here.
  9. May 1, 2018 at 1:21 PM
    #109
    Broccoli
    Airdrie Alberta
  10. May 1, 2018 at 1:34 PM
    #110
    Colorado Crawler
    Hey if Bluetooth is included then what do I know....definitely not the first time or last time I was completely wrong....lol. I was going off the grid and the website from when I was previously looking at the SE I also thought i was going to have to buy the Bluetooth separate but I believe you both.
    I think you are correct. You could likely use the dome as any input but then those accessories work off the dome obviously. I don't want my compressor to ever run if the ignition is not on and I want my future puddle/rock lights to work off the dome light so I will use both. I like not having to worry about diodes and all that stuff when splicing into your factory wiring.
  11. May 1, 2018 at 2:46 PM
    #111
    nwAdamR
    Adam
    SW PDX
    From what I understand, Bluetooth is built into the HD panel, not the SE system itself. If you have the HD panel (or Bantam), no need for the extra Bluetooth module.
  12. May 1, 2018 at 2:48 PM
    #112
    Colorado Crawler
    Ahh that makes sense. Thanks for the clarification.
    nwAdamR[QUOTED] likes this.
  13. Jul 21, 2018 at 7:59 PM
    #113
    Colorado Crawler
    Updated setup. Got the reverse trigger and dome light trigger both working. The Tacoma dome light setup makes this quite interesting.
    The circuit breaker underneath has been nice when I want to quickly disconnect the sPOD and accessories.
    Picture of the tray upside down out of the truck so you can see it better. Used one bolt from the ARB OBA.
    Broccoli likes this.
  14. Aug 23, 2018 at 9:24 PM
    #114
    PNW Explorer
    PNW Explorer Well-Known Member
    Idaho
    2018 Tacoma TRD OR DCLB Mag Gray
    @Colorado Crawler, what connection did you end up using for the reverse light trigger? I am trying to sort through the mountain of wiring diagrams for the Tacoma and found the Back-up light connection, is that the connection you used?
  15. Aug 24, 2018 at 7:59 AM
    #115
    nwAdamR
    Adam
    SW PDX
    Can you just tap into the reverse light's wire? That's what I plan to do (using SPOD's LSHS adaptor).
  16. Aug 24, 2018 at 8:03 AM
    #116
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    I was looking at the LSHS and I haven't a clue how it works. I get the premise I guess but I'm not sure how it ties into the sPod. Please educate me!
  17. Aug 24, 2018 at 8:08 AM
    #117
    nwAdamR
    Adam
    SW PDX
    The LSHS simply plugs into the second ethernet-looking connection in the SD via a Cat 5 cable. Plug & Play. I'd take a picture, but I'm out of town.
  18. Aug 24, 2018 at 8:11 AM
    #118
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    So I did know that part but I'm not sure how I could use it to make my rock lights come on with my dome light. And how would the sPod tie into that.
  19. Aug 24, 2018 at 8:46 AM
    #119
    PNW Explorer
    Idaho
    I remember briefly reading some about not rapping into the reverse lights because of too much power draw or something, but I'm not sure I believed that because the wire gauge should be plenty sufficient. Maybe it was something else...
  20. Aug 24, 2018 at 8:58 AM
    #120
    nwAdamR
    Adam
    SW PDX
    Tap into your dome lights somewhere, then lead that wire to the LSHS (into one of the eight inputs).
    I don't believe there's an issue tapping anything. Doing a quick test with my LSHS, I led a wire directly from my battery terminal to the LSHS. Worked good!
    Fellas, just give SPOD a call. They're more than helpful!
    Alesimo[QUOTED] likes this.
