3rd Gen Sport 4x4 Wheel Play
Discussion in '3rd Gen. Tacomas (2016-2023)' started by redcx9, Oct 16, 2018.
  1. Oct 16, 2018 at 6:19 PM
    redcx9
    redcx9 [OP] Well-Known Member
    Lebanon, PA
    2016 Tacoma TRD Sport DBL Cab
    Rotated my tires. Driver rear had to play from front to back when turning the wheel. The rear passenger tire when turning the wheel from front to back to get the lug nits to seat it would turn slightly and I would hear a clunk. Is this normal?
  2. Oct 16, 2018 at 6:59 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Ummm
    Check your u bolts on your rear leaf springs, they’re probably lose
  3. Oct 16, 2018 at 7:09 PM
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    and go a little higher than what the book said on the setting.
    per forum
    Re-torque leaf spring u-bolts - forum recommended
    Torque spec:
    52 lb-ft (19mm)
