(3rd gen) SR5 vs TRD fog light wiring question
Discussion in 'Lighting' started by wolfman00, Sep 21, 2020.
  1. Sep 21, 2020 at 11:16 AM
    wolfman00
    wolfman00 [OP] Well-Known Member
    matt
    Gambrills/Crofton MD
    '16 dclb
    sortof stock. 6112/5160, pro wheels and a tune.
    i have a 2016 sr5 with the standard "driving" fogs, and i happen to have a set of TRD OR "wide angle" fogs that have been sitting in my tool box for 2-3 years now. I want to use them, and i know i can just swap them...but what im wondering about is going from 19w to 55w. are the wire leads the same to the lights on our trucks between models? i couldnt imaging them using two different harnesses. I dont feel like melting anything this week.
    anyone know?
    PS- i searched quite a bit this afternoon. couldnt find anything. (im sure its out there somewhere)
  2. Sep 21, 2020 at 11:42 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Wiring and connectors should be the same, I believe it was just the assembly that changed between models. You can double check your fog circuit fuse, you should have at least a 10A fuse to run 55w fogs, but you'll more than likely have a 15A fuse.
  3. Sep 22, 2020 at 5:42 AM
    wolfman00
    matt
    '16 dclb
    just checked after your post- its a 15. so the wiring is def good enough.
    already popped on in. took longer to get the damn splash guard loose. beam is definitely wider
    thanks for getting back to me!
    crashnburn80[QUOTED] likes this.
