3rd Gen Steering Rack Bushings
Discussion in '3rd Gen. Tacomas (2016-2023)' started by downinpuertorico, Jun 11, 2020.
  1. Dec 9, 2023 at 12:23 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    If you don’t mind what was the part number from energy suspension? I have to do mine but am currently roaming in South America and need to get the right part the first time. Thanks.
  2. Dec 9, 2023 at 12:32 PM
    Stopmithering
    Stopmithering Well-Known Member
    Stuart
    17 Tacoma TRD Sport ACLB MT
    The same ones as seen at the top of the thread. 8.10106G from Energy Suspension. Good luck.
  3. Dec 9, 2023 at 1:04 PM
    PTSDTherapy
    22 SR5 DCSB
  4. Dec 9, 2023 at 1:10 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    i clipped the side of a raised median accelerating onto the highway at about 5-10 mph. bent the damn axle shaft but it was still "in spec" so no shop would replace it because they couldn't "replicate the issue" that they kept blaming on tire balancing and characteristics of the truck. ridiculous experience. i think the flange or studs were slightly bent.
    replaced wheel, tire, drum, differential and still had the issue. spent months and thousands of dollars trying to get it fixed. 15 total shop visits and $4,000 before i gave up. ended up having to sell it because i couldn't drive it like that. even had a shop remove everything and inspect and the dealership wouldn't install a new part even when i told them i would pay for it. absolute insane experience.
  5. Nov 26, 2024 at 4:38 PM
    GawainXR
    GawainXR Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    How much should the bolt/bushing shift when parked on the ground and turning the wheel 1/4 turn or so back and forth?
    I've been getting a bit of steering wheel shimmy and wandering on some of the highways around here and my alignment as well as balance should be good.
    The passenger side visibly shifts a bit.
    https://imgur.com/a/awhiKmc
  6. Aug 15, 2025 at 9:48 AM
    noah_sobel
    noah_sobel Well-Known Member
    Noah
    Army Green 2020 Toyota Tacoma TRD Pro
    Wescott lift and 33”s
  7. Aug 15, 2025 at 11:13 AM
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    If you read the thread, post #20, he said he did it on his 3rd gen.
