3rd Gen steering wandering
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BigJShirl, Feb 1, 2021.
  1. Feb 1, 2021 at 2:36 PM
    BigJShirl
    BigJShirl [OP] New Member
    I have a 2017 TRD Offroad 4X4. I am having issues that when I hit bumps at certain angles the steering wheel jerks to one side or the other and the truck's steering seems to float or wander on the road some especially when the road is in poor condition. I have done some research and I believe I need new bushing for my rack and pinion but I can't seem to find any for this year's model. Can someone point me in the right direction?
  2. Feb 1, 2021 at 2:42 PM
    TacoTim85
    TacoTim85 Well-Known Member
    Vancouver, Washington
    2007 4Runner Sport Edition 4WD (Current)
    Start with getting your alignment checked before you start buying bushings. Visually inspect any bushings you can easily see like your lower and upper control arms.
  3. Feb 1, 2021 at 2:44 PM
    OverlandExpress
    OverlandExpress Well-Known Member
    NE Ohio
    2020 Taco TRD PRO
    Why not say I have a 2017 with XXXXX miles on it and when the front end parts/tires was last serviced/replaced. instead?
    then more pertinent responses could be made.
  4. Feb 1, 2021 at 2:56 PM
    BigJShirl
    Sorry, this is my first time posting. I have about 45,000 miles and have only had the truck for about 4 months. I have not serviced any of the parts on the front end. I did look at my bushings on the rack and pinion assembly and the assembly moves slightly when the steering wheel is turned.
  5. Feb 1, 2021 at 3:43 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Is the suspension stock or has it been lifted?
    shakerhood likes this.
  6. Feb 2, 2021 at 5:51 AM
    BigJShirl
    I have a 2" lift on the truck and running 33" tires.
  7. Feb 2, 2021 at 5:55 AM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    Bingo. This will exaggerate any and all steering feel.
    Are you asking for advice on the issue or wanting part numbers?
    usmc2msu likes this.
  8. Feb 2, 2021 at 5:58 AM
    BigJShirl
    This is the first tacoma I have owned, so is this normal steering with a lift and 33" or is there possibly an issue? Any advise would be greatly appreciated. Thanks
  9. Feb 2, 2021 at 6:32 AM
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    Im lifted. 33's and i dont expierence what you are describing with the floating and wandering. Bumpsteer at times yes.
    You should be checking your alighnement and tire pressures and any odd tire wear. If those check out then start looking at hard parts. Upper and lower ball joints, bushings, steering rack etc.
    BigJShirl[QUOTED][OP] likes this.
  10. Feb 2, 2021 at 6:51 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    After inspecting the front end for loose or worn parts...Increase caster before whipping out the parts cannon.
