3rd Gen Stock Speaker Specs?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dirty Harry, Nov 2, 2017.
  1. Nov 2, 2017 at 10:00 PM
    Dirty Harry
    Dirty Harry [OP] Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    Google has not turned up much and Crutchfield isn't super helpful either. Can anyone tell me the stock resistance/ohmage and wattage for the speaker systems?
    Also, I've got some new Memphis PRX27 mid speakers on the way and I want to see if some Eminence Pro Audio drivers I got laying around will work in the front or rear doors.
    https://www.crutchfield.com/p_953PR...&awnw=g&awcr=183010775916&awdv=c&awug=9022933
  2. Nov 3, 2017 at 9:04 AM
    Dirty Harry
    Andrew
    SW Florida
    Update: If anyone happens upon this thread in a search, I'm 90% sure the stock system speakers are 3-4 ohms. 8 ohm speakers can be successfully used in place of these as often times, they have a higher sensitivity to account for the higher resistance. Hope this helps! I'll report back about the tweeter swap.
  3. Nov 3, 2017 at 9:11 AM
    drtyday44
    drtyday44 Member
    Do you have the base or stock Jbl?
  4. Nov 3, 2017 at 9:20 AM
    drtyday44
    drtyday44 Member
    JBL is 2 ohm
  5. Nov 3, 2017 at 9:37 AM
    Dirty Harry
    Andrew
    SW Florida
    I've got base.
  6. Nov 3, 2017 at 10:24 AM
    Deacon Blues
    Deacon Blues Well-Known Member
    Colorado
    2017 SR5
    The front doors and dash tweeters are wired together, neither will work without the other, so either 2ohm each or 8ohm depending on series or parallel wiring.
    Not sure what the drop in Subaru/Kicker tweeters are though, that's the most common swap here.
  7. Nov 3, 2017 at 11:16 AM
    Dirty Harry
    Andrew
    SW Florida
    Hmm. I mean, I got this straight from Crutchfield. Usually they know their shit. I would have preferred to be able to buy OEM Plus tweeters but you have to get their 1200 dollar package deal. That's laughable.
  8. Nov 3, 2017 at 11:22 AM
    Deacon Blues
    Colorado
    2017 SR5
    No sorry I just mean if you completely remove one or the other, neither work.
    You can swap in any tweeter you want, just would change the load the stereo gets.
  9. Nov 3, 2017 at 11:24 AM
    Dirty Harry
    Andrew
    SW Florida
    Ah gotcha. Thanks for clarifying.
  10. Nov 3, 2017 at 12:46 PM
    wingfiry
    wingfiry Well-Known Member
    Atlanta
    2016 TRD Sport 4x4 AC MT White
    When I replaced my non-JBL factory speakers, they were stamped 4 Ohms.
