3rd gen stock spring rate (TRD OR)
Discussion in 'Suspension' started by barcelona7568, Jan 7, 2017.
  1. Jan 7, 2017 at 9:36 AM
    barcelona7568
    barcelona7568 [OP] Well-Known Member
    CO
    16 DCLB, Stock
    I have not yet gotten a straight answer on what the stock spring rates are for the 3rd gen TRD Off Road. Can someone cite a credible source?
    Also - will aftermarket springs fit on the stock shocks? I don't want to lift the truck. but I put a metal bumper on and I think it sagged about 1/4".Thinking a stiffer spring will boost me back up to pre-bumper glory.
  2. Jan 7, 2017 at 9:37 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Pretty sure it was something like 710 lbs.
    You can't use a lift coil on stock shocks.
    barcelona7568[OP] likes this.
  3. Jan 7, 2017 at 10:17 PM
    DaVikes
    DaVikes Well-Known Member
    Ross
    Denver
    Colorado Sports Car
    Arb front bumper, warn winch, All Pro rear bumper, OME up front, OME and All Pro Standard in Back, ARB locker, 34 x 10.5 KO2's, 17" Level 8 Trackers, and fancy single piece driveshaft.
    FinnJ and barcelona7568[OP] like this.
  4. Jan 7, 2017 at 10:42 PM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    I don't think they have a 700 lb spring an OME 884-885 are around 600 lb springs and are stiffer than stock springs.
    Unless the new OR is way stiffer..
    You can jump with a 700 lb spring...
  5. Jan 7, 2017 at 10:43 PM
    shr133
    Muskego, WI
    2010 V6 Sport
    Just stick in a small spacer to bring it back up.
