3rd Gen stock tweet crossover
Discussion in 'Audio & Video' started by MattDsTaco, Jan 15, 2024.
  1. Jan 15, 2024 at 3:55 PM
    MattDsTaco
    MattDsTaco [OP] Member
    2017 Tacoma TRD Off Road
    Does anyone know what the stock built in crossover is for the tweeters. I've tried looking and don't see it posted anywhere. The cap on the tweeter says 2.2uf but using the charts online that would be 18k hz so I'm probably missing something.
  2. Jan 15, 2024 at 4:04 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    It's inside the tweeter frame. That 4 pin plug is kind of a funky design - the tweeter takes the full signal input on 2 pins, then it will split and output the woofer frequency to the door on the other 2 pins. I'm not sure of the frequency. I don't think it matters, since replacing the tweeter means you are replacing the x-over by default.
  3. Jan 15, 2024 at 4:39 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    sounds about right. the 86 tweeter high pass was similar. i had done the calculations at one point on ft86club. the tweeter in the 86 was somewhere near 16-18khz, and the dash mid was crossed somewhere near 12khz if memory serves.
    it sounds high, but keep in mind it's also a very tame 6db/oct slope, so plenty just underneath the crossover point will come through as well, especially given the quality and small size of the plates of the capacitor used.
  4. Jan 15, 2024 at 4:42 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    As a bit of a clarification, the tweeter connection doesnt send a woofer frequency down to the door. The tweeter connection itself is just a bridge and the door speaker connection gets a full signal.
    it is a paper cone with no tweeter so it doesn’t reproduce high frequencies by default so to the best of my knowledge the door speaker doesn’t have any crossover at all.
    as mentioned, if you are replacing the tweeter, you will be using the crossover included with the new tweeter so no need to worry about the factory one
  5. Jan 15, 2024 at 4:43 PM
    MattDsTaco
    I was thinking about swapping the tweeters out in my friends truck for Peerless clones and didn't know if could reuse the stock cross overs. Sound like we would need to buy some.
  6. Jan 15, 2024 at 5:19 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Aren’t Peerless pretty much all home-theater speakers? Typically 8ohms, typically low sensitivity, neither make for good car audio
  7. Jan 15, 2024 at 6:04 PM
    MattDsTaco
    They make a few speakers and tweeters that I've seen people on www.diymobileaudio.com use in budget builds.
  8. Jan 16, 2024 at 4:54 PM
    soundman98
    NW Indiana
    these?
    https://www.amazon.com/Zer-one-Composite-Tweeters-Loudspeakers/dp/B07W4TX6V6/
    that's what i'm running in my truck currently. i'm very happy with them
    the car has a genuine set of peerless ring radiators
    https://www.parts-express.com/Peerless-XT25SC90-04-1-Dual-Ring-Radiator-Tweeter-264-1014?quantity=1
    these are slightly cleaner sounding, but only barely, than the clones.
  9. Jan 16, 2024 at 4:57 PM
    soundman98
    NW Indiana
    i beg to differ.
    i've been extremely satisfied with my 6" peerless hds mids. they remain the only drivers i've ever moved between vehicles. most times i get bored and try something else
  10. Jan 16, 2024 at 5:38 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    I gladly stand corrected. I was in the home theater industry before car stereo so I’m far more familiar with them on that side.
  11. Jan 17, 2024 at 4:41 PM
    soundman98
    NW Indiana
    the point is somewhat moot in some respect though, as of 2023 peerless/tympany stopped selling to dealers in small quantities, which means many dealers dropped them, or in parts expresses case, they're running their stock out, and offering the product line but with a minimum 100-2,000 order quantity depending on product, and depending on popularity.
    https://www.parts-express.com/Peerless-NE265W-08-10-Paper-Cone-NE-Woofer-8-Ohm-264-1518?quantity=100
    https://www.parts-express.com/Peerl...num-Full-Range-Speaker-264-1185?quantity=2000
