3rd Gen Supercharger
Discussion in '3rd Gen. Tacomas (2016-2023)' started by particleman, Nov 4, 2016.
  1. Nov 4, 2016 at 9:13 PM
    particleman
    particleman [OP] Well-Known Member
    2016 2wd SR5
    My question is. If the major complaints about this generation Tacoma are low end torque and the transmission which I believe will be fixed through software TSB or warranty work. Why is there no pressure on Toyota to continue with a supercharger which would fix the torque complaints? It would be a pretty wicked truck with a supercharger. All that torque through the RPM range.
  2. Nov 4, 2016 at 9:30 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    They won't sell enough of them. Anything in any corporation is purely about money.
    inwood customs and Joe23 like this.
  3. Nov 4, 2016 at 9:39 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The tightening fuel economy standards imposed by CAFE 2025 are fundamentally changing the way auto manufactures are designing and building their car/truck engines. Sadly a parasitic low efficiencey roots blower has no place in this new automotive future. With Toyota's shift to Atkinson cycle technology it does not make sense to invest in more R&D for a dead technology. From here on out the new gasoline game is variable displacement and small displacement turbos.
    You vote with the dollar, and you bought the truck anyway. Toyota will check that off as a sign of approval.
    alexplb, cctk2, knayrb and 1 other person like this.
  4. Nov 4, 2016 at 9:43 PM
    the_dau
    the_dau Well-Known Member
    Vancouver BC
    2017 Inferno TRD OR DCSB
    what the existing super long supercharger thread wasnt enough?...
    Joe23 and particleman[OP] like this.
  5. Nov 4, 2016 at 9:43 PM
    DrVonEvilSatan
    DrVonEvilSatan Well-Known Member
    Toyota Truck
    The torque curve isn't that much lower than the 4.0. Where we feel it's less is the high end is so much more. It's best not to look at this as a torquey truck engine but from the perspective of a car. If you want it to move you need to give it the revvs.
  6. Nov 4, 2016 at 9:45 PM
    particleman
    2016 2wd SR5
    No
    cctk2 likes this.
  7. Nov 4, 2016 at 9:45 PM
    Bishop84
    Bishop84 Well-Known Member
    Regear if you want more power. The old 4.0 Supercharger wasn't that special, even with stock tires it still didnt feel fast out of the box.
  8. Nov 4, 2016 at 9:50 PM
    particleman
    2016 2wd SR5
    I have zero complaints about my truck. Im just wondering how Toyota is looking at this thats all.
  9. Nov 4, 2016 at 9:52 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Regear if you want more applied torque, but it does not give more power. While I agree that the 4.0 SC isn't the best it could be out of out of the box, after the SC and pulley upgrade, my truck will literally break the rear end free and drift it to the side lighting up the traction control if I hammer on it at freeway speeds when wet. And I'm on 32s. It is a game changer, though an expensive one. I've not seen any stock trucks complain about to much torque causing wheel spin and traction problems running oversized tires on the freeway.
  10. Nov 4, 2016 at 9:52 PM
    Naturalness
    Naturalness Well-Known Member
    Andrew
    Vermont
    2017 MGM OR DCSB
    Speaking with a source at a particular assembly plant powertrain department - you're going to see a turbo in a new Toyota before you'll see another supercharger.
    That said, the turbo diesel engine from the Hilux may be making its way over to North America in a few years, if the project ever gets approved. There's your turbo And your torque.
    alexplb likes this.
  11. Nov 5, 2016 at 4:03 AM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Yeah it'll be brought over by Santa clause riding it over the ocean on the back of lochness monster after his meeting with boogie man and the tooth fairy
    El Duderino and bobrown14 like this.
  12. Nov 5, 2016 at 6:08 AM
    TacoMan2017
    TacoMan2017 Well-Known Member
    There is a "Supercharger Light" on our trucks, its called the ETC button. Use it and enjoy a different engine!
  13. Nov 5, 2016 at 6:12 AM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    except it does nothing to the engine... and is only on automatics because its a transmission shift point feature. magnuson is close to if not already into production on their supercharger for the 3.5
  14. Nov 5, 2016 at 6:13 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    supercharger and you need to run premium fuel as well.
    no thanks.
    with the increasing fuel cost I'd rather not need to pay the extra 50-60 cents/L for premium.
    If you need that much power...buy a fullsize
    Tacoma has enough power for my needs.
  15. Nov 5, 2016 at 6:20 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    0.5 hp avg.
    Now when in boost it uses more, but you are in boost alot less than you would think, its load dependent, not rpm alone, not throttle alone.... load.... i find it hard to believe anyone drives a DD at a high load all the time.... if they do, they need a V8 or diesel
    If someone has the blower and suffers any dramatic mpg drop, its their fault, or the system is not working properly.
  16. Nov 5, 2016 at 6:24 AM
    FSUNole
    FSUNole Well-Known Member
    2016 blazing blue Tacoma TRD off road
    It would be cheaper for Toyota to stuff a 4.7L V8 into the Tacoma than do the R & D to certify a supercharger for the Tacoma.
    I'm not holding my breath for a diesel. Its too much a premium and I hate diesels anyway.
  17. Nov 5, 2016 at 6:45 AM
    Naturalness
    Andrew
    Vermont
    2017 MGM OR DCSB
    Point taken. But this time the information was coming from North American R&D. It has a project code. Timeline is 2019-ish, if it gets the go-ahead, and everything is on time.
    The original 4.7L made around 245 hp, but had decent torque and sounded fantastic with the right pipes. Someone work on a mod...
  18. Nov 5, 2016 at 7:09 AM
    bradwhitenikki
    bradwhitenikki Well-Known Member
    Brad
    2016 Tacoma Trd Off Road 6sp Auto
    Well spoken.
  19. Nov 5, 2016 at 7:14 AM
    bradwhitenikki
    Brad
    The whole point of Atkinson is to combust less fuel over a longer stroke. Boosting the air charge would defeat the gains of the Atkinson cycle portion of the engine management. A very small turbo could help with pumping losses, but the gains would be small. To really gain torque from the turbo, you must switch out of Atkinson mode, and the fuel economy will drop a small percentage. The truth is torque costs fuel economy. While to some that is OK, I think Toyota is forced to forgo some torque to meet the CAFE standards. Now... the aftermarket could certainly capitalize on this....
    particleman[OP] and crashnburn80 like this.
  20. Nov 5, 2016 at 7:19 AM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    You must be new to tacomas . . . . . .
