3rd Gen Supercharger
Discussion in '3rd Gen. Tacomas (2016-2023)' started by particleman, Nov 4, 2016.
  1. Nov 5, 2016 at 7:52 AM
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    Birthplace of Davy Crockett
    What the elastic bungey cords between the cab and seat, with the plastic seat belt holder for?
  2. Nov 5, 2016 at 8:01 AM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    whatchu talkin bout willis!
    the_dau likes this.
  3. Nov 5, 2016 at 9:21 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    0.5hp when not under load. Most people report about a 1mpg drop with the blower. And it would be difficult to work with the Atkinson cycle technology, requiring more R&D, R&D that would reduce fuel economy.
    Toyota has just over 8 years to raise the fuel economy average to 54.5mpg. They will face heavy fines for every 0.1mpg they are short. That is a near impossible challenge. You are going to see a massive shift into favoring efficiency over everything else. Anything unnecessarily parasitic will have no place in this automotive future. Your going to see manufactures spending their R&D dollars on smaller discplacement high boost turbos, not larger displacement lower efficiency superchargers.
  4. Nov 5, 2016 at 10:03 AM
    monsterkx2fiddy
    On cars most have a little piece of elastic bungey cord coming off the cab between the seat and cab. I believe it holds the seatbelt. but idk why?
  5. Nov 5, 2016 at 10:14 AM
    brich999
    Bryan
    all tore up already
    and this pertains to a 3rd generation tacoma supercharger how?o_O
    alexplb, t0nyvalenzuela and the_dau like this.
  6. Nov 5, 2016 at 10:39 AM
    monsterkx2fiddy
    And air actuated valves using a computer and recycled exhaust. Less wasted energy, less weight, less emissions, more fuel economy and more power.
    Hey Toyota I want a job....
    bradwhitenikki likes this.
  7. Nov 5, 2016 at 5:36 PM
    bradwhitenikki
    bradwhitenikki Well-Known Member
    Brad
    2016 Tacoma Trd Off Road 6sp Auto
    I like the way you think.
  8. Nov 5, 2016 at 5:40 PM
    Naturalness
    Naturalness Well-Known Member
    Andrew
    Vermont
    2017 MGM OR DCSB
    Koenigsegg is using this technology. Therefore, it's probably really expensive and well-engineered. Cool tech though.
  9. Nov 5, 2016 at 5:44 PM
    bradwhitenikki
    Brad
    I think cars need to lose some weight, reduce thermal losses, and dump the parasitics, pretty fast.
  10. Nov 5, 2016 at 10:38 PM
    the_dau
    the_dau Well-Known Member
    Vancouver BC
    2017 Inferno TRD OR DCSB
    you engineer a vehicle that can do that and meet emissions AND safety requirements....If it were that easy don't you think they would have done that by now? I'd imagine if they were able to drop all that stuff the vehicles would be much cheaper for Toyota to manufacturer...
  11. Nov 6, 2016 at 1:59 AM
    Lsittingbull
    Lsittingbull New Member
    Ford is doing it with Aluminum and meeting IIHS safety crash testing And I don`t see why they can not use a 4cyl turbo to get the hp and tq figures they need.
  12. Nov 6, 2016 at 1:27 AM
    monsterkx2fiddy
    Konnesig actually bought that company for their technology. Before they became konnesig, I read that supposedly they had all the problems associated with air/electronic/pneumatic actuated valves and camless technology Meanwhile still cheaper than our traditional way.
    Many of the auto manufactures in the U.S. market have been experimenting with it including Ford and GM. A low cost ($25-30k) Chinese auto manufacturer is utilizing this technology into their production vehicles.And many auto parts manufacturers are investing some money in R&D.
    A fun little shop project is to build one at home with and small 4 stroke motor.
  13. Nov 6, 2016 at 5:13 AM
    FireMedic2290
    FireMedic2290 Well-Known Member
    CT
    Just curious, but why hasn't the Hilux been manufactured here yet? Is it the EPA standards?
    Naturalness[QUOTED] likes this.
  14. Nov 6, 2016 at 5:25 AM
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    Probably a few reasons, but look up the chicken tax. That's probably one of them.
    monsterkx2fiddy likes this.
  15. Nov 6, 2016 at 5:51 AM
    #35
    bradwhitenikki
    Brad
    It can be done. Most internal combustion engines are less than 30-35% chemically efficient. There are great gains to be had there. Most tires are a high silica compound with a heat generating flagella at the end of each carbon chain. Add up all the molecules in a tire's sidewall, and you have a lot of heat being generated in tires. That is why some people with hybrids sink their gas mileage when they switch to a non recommended tire. The hybrids have tires with altered carbon chains. Heat=wasted energy. Most steel bearings are slightly out of round and add to the parasitic losses. There are a lot of bearings in a drivetrain. Gear mesh coefficients of friction is another great energy waster. There are platings and coatings that drop coefficients of friction to nearly zero without drag. With the current processes, materials engineering can go a long way.
  16. Nov 6, 2016 at 6:38 AM
    #36
    Naturalness
    Andrew
    Vermont
    2017 MGM OR DCSB
    Short answer: Ask Japan.
    TMC (Japanese mother company) still retains the design of every North American Toyota/Lexus/Scion, except the Tundra - which is why the Tundra is called an All American truck. Japan dictates that the tacoma is for NA, and the other continents get the Hilux.
  17. Nov 6, 2016 at 6:48 AM
    #37
    FireMedic2290
    CT
    Interesting. Thanks
  18. Oct 8, 2019 at 10:28 PM
    #38
    alexplb
    alexplb Well-Known Member
    It does exactly 0 improvement but uses more gas. Useless.
    inwood customs likes this.
