3rd Gen Sway Bar Quick Disconnects?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by poopshute, Jan 25, 2017.
  1. Sep 8, 2021 at 3:13 PM
    #41
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
  2. Sep 8, 2021 at 3:27 PM
    #42
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    It’s a quick disconnect…it allows both sides to articulate as if they sway bar was removed…regardless of what your opinion of a disconnect is…the sway bar doesn’t have to disappear for it to be disconnected from the suspension…
  3. Sep 8, 2021 at 3:51 PM
    #43
    Freeheelbillie
    Freeheelbillie Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    I have to agree
    outdoor frenzy likes this.
  4. Sep 8, 2021 at 4:37 PM
    #44
    ZebraScissors
    ZebraScissors Well-Known Member
    Drake
    Reno, Nevada
    2018 Cav Blue TRD Pro
    LOL. OK so you are wrong.... But you are going to find a way to still argue instead of learning something new..... ok.... anyways...
    ^ This.
    Sdswingr likes this.
  5. Sep 8, 2021 at 4:42 PM
    #45
    Junirol
    Junirol Well-Known Member
    Rolando
    San Diego California
    05 Tacoma Prerunner SR5, 10 Tacoma 4x4 Off road
    E85 Flex fuel, TRD CAI, Magnaflow exhaust, TRD Supercharger
    If I remember correctly, the latest generation of 4runners has something akin to disconnectable sway bars, but I think they disconnect at the mounts instead of the end links. I wonder if this system is compatible to the tacomas.
  6. Sep 8, 2021 at 4:58 PM
    #46
    dfanonymous
    I know the guy that makes them made some for the guys on the 4Runner forum and bunch of FJ peoples. Not sure about the current gen of 4Runner but it might be worth asking.
  7. Sep 8, 2021 at 5:06 PM
    #47
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    I think you're looking for what is called a "Sway Bar Eject."
    I haven't seen many out there but I'm sure you could come up with something.
    ZebraScissors likes this.
  8. Sep 9, 2021 at 4:30 PM
    #48
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Lol it was a while back so doubt I’d find it!
  9. Sep 10, 2021 at 1:16 PM
    #49
    poopshute
    poopshute [OP] Well-Known Member
    Colorado
    2017 Tacoma TRD Pro Storm Trooper
    Ok, these are bad ass... thanks a ton for sharing! Plenty of Jeepers have quick disconnects like this. Actually makes disconnecting and connecting much more straight forward and easy. For someone who likes the extra articulation with them disconnected but requires the sway bar for on road driving (I tote around some precious cargo... an 8 and 4 year old)... these are perfect. @ZebraScissors, never have an issue with your CV joint getting touched? With the way that link has that flange at the bottom, it looks like it acts as a stopper. Pretty sweet!
    You, sir, need to understand things before you post silly things like this. Jeeps use this style of disconnect and it's called a "quick disconnect". The goal here is to simply release the sway bar from the suspension... that's exactly what this does. If you want a sway bar "delete", just remove the damn sway bar.
    Yup... what he said.
    TRDPro75, outdoor frenzy and eurowner like this.
  10. Sep 21, 2021 at 3:25 PM
    #50
    poopshute
    Colorado
    Meclizine likes this.
  11. Sep 21, 2021 at 7:36 PM
    #51
    Silverlogic
    Silverlogic Well-Known Member
    Tyler
    San Diego, California
    2018 Silver DCSB TRDOR
    I ordered one today too.
    poopshute[QUOTED][OP] likes this.
  12. Sep 21, 2021 at 7:54 PM
    #52
    dfanonymous
    Just keep in mind, you don’t get THAT much more articulation. Maybe a inch and a half.
    At least that what about what I get with the Trd Pro fox coils.
  13. Sep 21, 2021 at 8:05 PM
    #53
    Bishop84
    Bishop84 Well-Known Member
    It's just better for the comfort of unpaved roads. Articulation is actually a secondary benefit in my eyes. I like the reduced feed back at higher speeds.
    TRDPro75 and dfanonymous[QUOTED] like this.
  14. Sep 21, 2021 at 8:19 PM
    #54
    dfanonymous
    I came from the Jeep world. Articulation for true wheeling is foremost. A tuned suspension will handle desert running safely, at least in my opinion.
  15. Sep 21, 2021 at 8:31 PM
    #55
    Bishop84
    Jeeps are sketchy death at high speeds on gravel roads haha. They need all the help they can get.
    I went from an XJ to the Tacoma and was finally able to keep up with the higher speeds on the gravel roads.
    Tacomas really can't compete with the new wranglers for offroading, you have to put in a lot of money to come close when it comes to real wheeling. But I'd take a tacoma anyday over a jeep for the offroading I do.
    TRDPro75 and outdoor frenzy like this.
  16. Sep 22, 2021 at 3:54 PM
    #56
    ZebraScissors
    Drake
    Reno, Nevada
    I'm not sure where you are getting an inch a half. The shaft the sway slides on is like 4-5 inches long. so you would get 4-5 inches more. You can literally see the difference by parking one wheel on a rock, or even your friendly neighborhood curb.
    Sdswingr and outdoor frenzy like this.
  17. Sep 22, 2021 at 5:11 PM
    #57
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    You don't get more articulation because people are installing bolt-on OEM replacement shocks which only provide 4-5" of travel. The shocks can cycle within that range with or without the sway bar, but without just slightly reduces body compliance. There is a big different between a sway bar on a 4-5" stroke coilover on an IFS truck and a sway bar on a solid axle with 14" stroke coilovers...
    dfanonymous likes this.
  18. Sep 22, 2021 at 8:41 PM
    #58
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Sure does look like they're getting close to the coilover @ 3:20:
  19. Sep 22, 2021 at 9:25 PM
    #59
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
  20. Oct 26, 2021 at 12:57 PM
    #60
    poopshute
    Colorado
    RyanDCLB and shotgunbilly420 like this.
