3rd Gen Sway Bar Quick Disconnects?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by poopshute, Jan 25, 2017.
  1. Jan 12, 2022 at 1:00 PM
    #81
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    So you’re saying all those dudes who straight up tossed their sway bars don’t even get extra articulation because they had a lift that wasn’t long travel?
  2. Jan 12, 2022 at 1:02 PM
    #82
    BudFriendguy
    BudFriendguy TRD BRGLR
    Zak
    Portland, Oregon >> Cleveland, Ohio
    2021 TRD Sport ACLB 4WD 6MT V6 Voodoo Blue
    Was articulation the objective?
    It always seemed like getting rid of that violent side to side rocking whiplash was the goal.
    tonered likes this.
  3. Jan 12, 2022 at 1:04 PM
    #83
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is 100% NOT what I said. Please re-read my post and the post that I quoted.
  4. Jan 12, 2022 at 1:05 PM
    #84
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Letting the IFS work . . . independently . . . was a nice side benefit. :D
    But, yeah. The harshness not being there was my main reason.
  5. Jan 12, 2022 at 1:05 PM
    #85
    dfanonymous
    ? the guy who wasn’t you that I quoted was talking about articulation, so I asked a question.
    What people buy and actually use it for is no concern to me..
    BudFriendguy[QUOTED] likes this.
  6. Jan 12, 2022 at 1:08 PM
    #86
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. I was talking total articulation. Not a single word about the SB.
  7. Jan 12, 2022 at 1:09 PM
    #87
    dfanonymous
    No, I read it. I not arguing yet. I’m asking.
    You said, you would be limited by CV angles and need a long travel. I’m making the relative leap that with that logic, removing the sway bar all together without a long travel gives you no articulation because of the same reason then..
  8. Jan 12, 2022 at 1:15 PM
    #88
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    On that leap, the SB removal or disconnect has no effect on even bumps. Just stating the obvious.
    Flexing, I believe that it gives more on uneven bumps across the IFS. To know for sure, it would have to be measured. Coil rating and SB thickness (30mm on all but Sports and Pros which is 32mm) could affect it. It would be a fun nugget to know.
    I like to believe that I have more IFS flex without the SB. I know that I have more flex out back with my leaf packs because I was able to measure it.
    Just restating the generality that we do not get more total suspension travel with a typical lift.
  9. Jan 12, 2022 at 2:10 PM
    #89
    eurowner
    eurowner Duke Sky
    Scoty
    Damping is controlling the speed of compression and rebound of the spring.
  10. Jan 12, 2022 at 2:11 PM
    #90
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes.
  11. Jan 12, 2022 at 2:43 PM
    #91
    ZebraScissors
    ZebraScissors Well-Known Member
    Drake
    Reno, Nevada
    2018 Cav Blue TRD Pro
    Yes they will absolutely allow more ARTICULATION from left to right, but don't get that confused with actual suspension TRAVEL.
    Gonks[QUOTED] likes this.
  12. Jan 12, 2022 at 2:45 PM
    #92
    Gonks
    Gonks Well-Known Member
    OC
    SOLD 2020 White TRD Offroad 4x4
    Interesting and a nice learning experience for me. I thought that what you said was only true for the spacer lifts and not a true suspension lift. I have a lot to learn
    tonered[QUOTED] likes this.
  13. Jan 12, 2022 at 2:47 PM
    #93
    Gonks
    OC
    Understood and thank you for even more i sight. So, these truly do add noticeable articulation?
    I guess I was also curious on peoples experience with longevity and if these caused and unforeseen issues. I use my truck as my DD to work, and these always seemed like such a nice compromise on a jeep. I was linked this thread from another threat because I mentioned disconnects seemed next to non existent for Tacomas
  14. Jan 12, 2022 at 2:49 PM
    #94
    ZebraScissors
    Drake
    Reno, Nevada
    They worked great when I had them, but now I just run 700LB extended travel kings, and don't use a swaybar at all.
    Gonks[QUOTED] and tonered like this.
  15. Jan 12, 2022 at 2:53 PM
    #95
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Some of the stuff is mind blowing. Like even if 33s or so clear, you still need to full stuff them and account for that when trimming.
    The easy route is staying with 32s. :D
  16. Jan 12, 2022 at 3:00 PM
    #96
    Gonks
    OC
    One of the hardest things for (totally new to this) has been figuring out the difference between people and websites stating they are “clearing” tires and actually clearing the tire when being used wheeling.
    I got my truck used with 32 Wildpeaks on them, and don’t plan to upsize until I find they limit me!
  17. Jan 12, 2022 at 5:01 PM
    #97
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yeah. It is very hard to tell.
    For a DD, it will be had to find the limit with 32s. Pucker will find you.
  18. Mar 16, 2022 at 10:19 PM
    #98
    TacoTuesday1
    SD CA
    KDSS
  19. Feb 12, 2023 at 9:53 AM
    #99
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Figure I'd post over here.
    We installed the Overland Custom Designs swaybar disconnects yesterday. Had some conflict with the Total Chaos Spindle gussets, but a Milwaukee 90° die grinder with a cutoff wheel made that go away.
    If you are considering these, I'd check out the 5 year review over here :thumbsup:
    Edit: these didn't work unclipped with the spindle gussets
    DoulosXP, Puga10 and Gonks like this.
  20. Dec 3, 2023 at 7:19 PM
    #100
    RyanDCLB
    4/19 DCLBOR
    I ended up putting these up for sale over here. :thumbsup:
