3rd gen Taco manual transmission towing package
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Loqu!to, Mar 19, 2020.
  1. Mar 19, 2020 at 8:09 PM
    Loqu!to
    Loqu!to [OP] Somewhat skilled Rookie
    North VA
    2018 Tacoma TRD Sport MT OVTune
    MBRP Dual 409 SS Exhaust, many exterior mods.
    So I know the autos get an automatic transmission cooler in the package, does the manual tranny get its own cooler or no?
  2. Mar 19, 2020 at 8:14 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Manual transmissions do not need a cooler lol. They are direct drive, no torque converter or clutch pack.
  3. Mar 19, 2020 at 8:19 PM
    Bishop84
    Bishop84 Well-Known Member
    Reasonable question, but hiPSI is right, there is little to cool. The left pedal controls the heat.
  4. Mar 19, 2020 at 9:46 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    The torque converter and the pressurized hydraulic system create heat in the automatic transmission. This requires a cooler to keep the temperature in check and the cooler is normally found incorporate in the radiator. When towing more heat in generated by the weight. This extra heat needs a larger cooler to dissipate the heat so a separate (typically thermostaticaly controlled) cooler is installed along with the radiator incorporated cooler.
    In the case of a manual transmission, the fluid is splash lubricated which means the fluid is simply splashed around by the rotating gears. There is no hydraulic pressure system and no shearing from a torque converter. So no cooler is required because transmission heat is not an issue. Even under load of towing.
  5. Mar 19, 2020 at 10:23 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Yup. What these hoes said. ^^ different beast
