3rd Gen Tacoma - 1" Factory Lift Explained?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Quickdraw08, Sep 17, 2019.
  1. Sep 17, 2019 at 1:52 PM
    Quickdraw08
    Quickdraw08 [OP] Well-Known Member
    Andrew
    2019 White Tacoma TRD OR
    Can someone explain to me how the 3rd Gen Tacoma comes with a 1 inch lift from the factory? What are they using to get that lift? Are there spacers up front and an extra leaf in the back? Is it an overall suspension lift? I've googled it but I cant find anything on it.
    I am curious because I want to lift my 2019 TRD Off Road with a 2 inch lift. To accomplish this, I want to add the 3rd Gen Bilstein 5100's all around. The front Bilstein's will be set to zero and I will add an 887 coil to actually get the front lift. The rear will be an 1.5" AAL. I tow a 2,000 camping trailer around so I want some rake in the back so it doesn't sag.
    So, if I add the above setup plus the factory lift of 1inch... that should bring me to a 3inch overall lift? Do I need to worry about new UCA's or diff drop with this setup?
    I'll be running 265/75/R16 wheels and tires.
    Thanks in advance.
  2. Sep 17, 2019 at 1:54 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Not sure where you found this information.. The third gen does sit roughly an inch higher than the second, so maybe that's what you're referring to? Or perhaps the Pro which sits an inch higher than the other models?
    SIDELINER4 likes this.
  3. Sep 17, 2019 at 1:57 PM
    Quickdraw08
    Andrew
    I had a guy from the lift shop tell me that the 3rd gen comes with a factory 1" lift.... I guess I took his word for it. Sorry, I'm just trying to get this figured out. Lots of bro science out there. :)
  4. Sep 17, 2019 at 1:57 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    It’s not lifted. Think of it as it sags less.
  5. Sep 17, 2019 at 1:58 PM
    Loco_Barbon
    Loco_Barbon Just deez nutz hangin’ out
    Hugh Mungus
    Where ever my 10mm isn’t
    i LiKe tRuCkS!!
    Penis valve stem caps.
    The TRD Pro comes with the Fox suspension which is a 1" lift over the other trim packages. In this situation 1+2 doesn't equil 3, If you are looking for a 3" lift then you will need to install a 3" lift.
  6. Sep 17, 2019 at 2:00 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Only the PRO comes with the 1" lift from the factory.
  7. Sep 17, 2019 at 2:00 PM
    QuicksandTaco
    QuicksandTaco Well-Known Member
    Cody
    Oregon
    2015 Inferno TRD Pro 6spd
    URD short shifter, 285/75/16,
    They’re not lifted. They just sit 1” higher than 2nd gens ad stated above. I’m also pretty sure the Pro suspension only lifts the front 3/4” and has no difference in the rear. At least that’s how the 2015 Pro’s are.
    Quickdraw08[OP] likes this.
  8. Sep 17, 2019 at 2:01 PM
    Quickdraw08
    Andrew
    OK, thanks for the information. Much appreciated.
