3rd Gen Tacoma 2.7L ECU Tuning
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 10, 2017.
  1. Mar 12, 2021 at 4:56 AM
    #661
    OVTune
    OVTune Well-Known Member
    OVTune
    most of those messages are for the 2nd gen 2.7L, which we can support, much easier than the 3rd gen. They will release with the 4.0 in vF tuner when we release 736kb file support.
    05Taco4x4 likes this.
  2. Mar 12, 2021 at 4:58 AM
    #662
    Stormpeacock
    Stormpeacock IG: @storm.peacock
    Rich
    Atlanta, GA
    19 Cement Offroad
    MCB Elite Performance Tuned 5.29 Differential Gearing 35" Kenda M/T on Steelies SOS Bumpers, Skids, and Sliders Ranch Camper Shell
    Got it! Looking forward to it!
  3. Mar 12, 2021 at 4:59 AM
    #663
    OVTune
    OVTune
    The goal is to support every tunable toyota :).
    But the 2nd gen stuff 4.0L, 2.7L... if you think that the 3rd gen has a lot of ECU versions....... that's why it has not been released yet. I think just the 4.0L has close to 100 different ECU IDs.
  4. Mar 12, 2021 at 5:03 AM
    #664
    Stormpeacock
    Rich
    Atlanta, GA
    19 Cement Offroad
    Is there any rhyme or reason for this?
  5. Mar 12, 2021 at 5:04 AM
    #665
    OVTune
    OVTune
    code fixes, bugs, and I believe a lot of ECU versions were updated because the stock tune had really bad detonation problems
    YotaKid and Stormpeacock[QUOTED] like this.
  6. Mar 12, 2021 at 7:13 AM
    #666
    Teal_6
    Teal_6 Well-Known Member
    Robert
    Spokane
    2016 Tacoma SR 5spd
    So does this mean that 2016 is available? Or is it only automatic still?
    TACOROSSO and ExplorHer like this.
  7. Mar 13, 2021 at 11:15 AM
    #667
    Fleischwagen
    Fleischwagen 2.7 > 3.5
    North Jersey
    2017 SR 5MT 4X4
    5.29's, ARB locker, 6112/5100, Deaver AAL, LCE Header, aFe dry-flo filter, Hurst/Core shifter, CBI T3 Front, Warn Winch, CB/UHF Radio equipment, Backrack, KC fogs and spots
    Any luck with 16-17 Manual trans 2.7's?
  8. Mar 13, 2021 at 11:42 AM
    #668
    dalejunior
    dalejunior Well-Known Member
    I am interested in this as well.
    ExplorHer likes this.
  9. Mar 15, 2021 at 4:27 AM
    #669
    ExplorHer
    ExplorHer Question Authority
    Near Pittsburgh
    2016 4cyl, 5MT, 4x4, 2 seats, dents, & rust
    Also Interested in the 2.7 w/ manual 5spd.
  10. Mar 15, 2021 at 6:59 AM
    #670
    OVTune
    OVTune
    Unfortunately we cannot do the 16+ MT
  11. Mar 15, 2021 at 7:45 AM
    #671
    ExplorHer
    Near Pittsburgh
    Thanks for letting us know.
  12. Mar 15, 2021 at 8:35 AM
    #672
    Teal_6
    Robert
    Spokane
    2016 Tacoma SR 5spd
    Agreed. Guess its gonna be sprint booster for me.
  13. Mar 16, 2021 at 6:59 PM
    #673
    Fleischwagen
    North Jersey
    2017 SR 5MT 4X4
  14. Mar 17, 2021 at 7:04 PM
    #674
    NewMexiMan
    NewMexiMan Well-Known Member
    2016 SR 5 Speed
    Why's that?
    Fleischwagen and H860 like this.
  15. Mar 27, 2021 at 7:38 AM
    #675
    David McGinnis
    David McGinnis Well-Known Member
    David
    Sierra Vista, AZ
    2021 4X4 Sport AC 3.5L MT - OME lift with Dakar leafs. 10x33 Coopers. ARB Bumper. KDMax Tune. 2017 SE AC 2.7L 2WD AT - OME lift with Dakar leafs, BA bumper, tooter manifold spacer, header, OVTuned. LED lights. Does not run like your average 2.7; this truck pulled a broken down HMMWV out of a wash. 2008 PreRunner 4.0L - 3" spring lift with Bilstein 5100s, ARB bumper, rear sway arm. Old Reliable, been around, beat up, and still runs like a beast.
    I have the 2.7 tune in a 17 AT.
    The real value in the tune for me was the ability to adjust the AT. I did a ton of work on the shift points and greatly improved drivability with 33x10 tires and 4.88 gears. Along with a speedometer adjuster circuit, adjusting the transmission was the key to getting back to >20 MPG.
    On the engine tune, the things you can do is adjust advance and adjust the MAF. I spent weeks working on the advance, and most of that was learning to notice positive and negative differences while driving at different RPM and loads. It takes time to come up with a small improvement, make small changes and evaluate, not push too far, and leave room for unexpected variables. I haven't put time into learning the concepts for playing with the mix yet - and learning this stuff takes time especially when you have a life full of other things.
    By far, my most significant upgrade to my 2.7 (excluding the transmission tune/speedo correction) is the LCE header. I actually adjusted the overdrive shift points because I could hold those gears with less throttle. But it was adjusting the AT that made the LCE really worth it.
    NONE of this will bring magic power to push against headwinds or take hills at 85 MPH while retaining 6th gear. The wind drag at those speeds overwhelms the 2.7 and a tune won't fix that (the 2.7 is almost 100 HP less than the 3.5). This is still a Hilux motor, and intended for the parts of the world where interstate highways are uncommon. The 2.7 is more than enough to run 2 lane highways at 60 to 70 MPH. At freeway speed, you need apply so much throttle that the truck will drive in fourth gear for anything that is not flat or downhill. (and before anyone reminds me, clearly 33x10 tires do not help)
    Bottom line is this; IF my truck had a MT I wouldn't have done ANY of this stuff. I would have just shifted it how ever I wanted making it drive however I wanted. (I also have a 2021 with 3.5 and MT - and driving that truck the way I want is way simpler)
  16. Mar 27, 2021 at 8:46 AM
    #676
    DanielFerrer5618
    DanielFerrer5618 New Member
    Danny
    2020 Tacoma SR 2.7L
    Eibach Pro 2.5-inch lift, Rough Country Tri-fold Cover and seat covers, LED interior lights.
    So will there “eventually” be a tune for the 2020 SR 2.7L AT? Have been waiting on this for a while! Please let me know!
    hella_tacoma likes this.
  17. Mar 27, 2021 at 9:59 AM
    #677
    hella_tacoma
    hella_tacoma Well-Known Member
    San Francisco, CA
    2020 SR AC 2.7L Black
    Patiently waiting too, anything we can help with to accelerate eheh, the process?
  18. Apr 12, 2021 at 4:20 PM
    #678
    CarnageCityBih
    CarnageCityBih New Member
    2013 Tacoma PreRunner 2.7 Uni-Filter Mod Second Air Filter Delete
    Any plans on 2.7 engine being release on 2nd gen ?
  19. Apr 12, 2021 at 4:53 PM
    #679
    hella_tacoma
    San Francisco, CA
    Probably such a small demand for 2.7L ECU tuning it's not worth for these guys to spend the time and effort, it would have made little 4 bangers real nice.
    whatstcp and 4×4×4 like this.
  20. Apr 13, 2021 at 8:23 AM
    #680
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I disagree, strongly
