3rd Gen Tacoma 2.7L ECU Tuning
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 10, 2017.
  1. Jul 14, 2022 at 9:42 AM
    #901
    Nyrob
    Nyrob Well-Known Member
    Robert
    2021 SX 2.7 AT 4WD
    5100 1.1 Front, 5125 Icon Stage 2 Rear, 5.29's, LCE Header
    Any further updates anyone tweak the 2.7 yet
  2. Jul 14, 2022 at 9:59 AM
    #902
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    Sorry! It is still just the four ECU IDs noted in the 1st Post.
    There is another update coming, but it does not list any new 2.7l ECU IDs: vF Tuner noted that he was purchasing the ECU IDs that were identified here but don't have support. So, that might take a while?
    We still need to identify that last ECU ID to complete the list.
    Thanks!
    cryptolime likes this.
  3. Jul 18, 2022 at 7:43 AM
    #903
    tonered
    tony
    Lynnwood, WA
    Confirmed. Sorry, folks. No new ECUs added with this latest vF release. I will keep monitoring the situation.
    Thanks!
  4. Jul 18, 2022 at 8:44 AM
    #904
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    maybe next year. :annoyed:
  5. Jul 18, 2022 at 8:54 AM
    #905
    tonered
    tony
    Lynnwood, WA
    Hahaha!
    You guys have waited long enough.
  6. Aug 2, 2022 at 7:54 PM
    #906
    taco_truck9
    taco_truck9 Member
    israel
    2019 Tacoma SR TSS
    Man they need to take this 2.7l tune out already :bananadead:
    tonered[OP] and cryptolime like this.
  7. Aug 2, 2022 at 8:39 PM
    #907
    tonered
    tony
    Lynnwood, WA
    I hear you!
  8. Aug 3, 2022 at 4:53 PM
    #908
    Sflo2012
    Sflo2012 New Member
    2019 red tacoma tss
    I’m new to all of this and I’m not the most knowledgeable person when. But is is there a tune I can get for my Tacoma it’s a 2019 2.7 tss and I’m getting kinda tired of the cruise control issue
    tonered[OP] likes this.
  9. Aug 3, 2022 at 5:52 PM
    #909
    tonered
    tony
    Lynnwood, WA
    Sorry, but not yet. vF Tuner ordered up a bunch of ECUs.
  10. Aug 4, 2022 at 6:14 AM
    #910
    Chugiak76
    Chugiak76 Well-Known Member
    Colorado Springs, Colorado
    2020 Tacoma SR 2.7 4x2, AXC
    Depending on whether your cruise control issue is with hunting or with hanging up in too low of a gear, you can use S mode to alleviate the situation - provided you don't mind interacting with the truck.
    If you're experiencing "hunting" (frequent shifting), just throw it in S mode, set it to S5, and if downshifts (rpm goes up) shift to S4. If it downshifts again, shift to S3. Repeat until hunting stops. Once you can visually tell the road conditions have changed, shift up a gear. If it starts hunting again, downshift back to a lower gear. If it seems happy, you can try upshifting again. Repeat as needed. This is what I do and it works for me. If you drive the same roads you learn what S gear you need to be in to prevent hunting.
    Often when in D my Tacoma gets "hung up" in 5th gear, meaning it can and should shift to 6th, but it doesn't. This happens more often with cruise control turned on. Shifting to S mode and setting S6 usually makes it finally go into 6th gear, but it will go to 4th very briefly as the starting point for S mode is S4. Some Tacomas get hung up in lower gears like 3rd or 4th, and that is much more annoying. That's never happened to me, so I can't 100% guarantee this will help but I can infer that it will based on my limited experience.
    davidstacoma likes this.
  11. Aug 4, 2022 at 6:48 AM
    #911
    TacoMike
    TacoMike Well-Known Member
    Pennsylvania
    '19 SR AC Utility 4x4
    I use S mode 100% of the time. I like to have some input while driving. I've got 25,000 miles on my truck now and I think it drives leaps and bounds better than when it was new.
  12. Aug 4, 2022 at 7:56 AM
    #912
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    anyone know if the "AI-SHIFT" learning in 'D' gets input from how you drive in s-mode? or is it only in D? what about ECT mode? if you use ECT mode a lot does it effect the learned behavior in D?
  13. Aug 4, 2022 at 9:09 AM
    #913
    TacoMike
    Pennsylvania
    I used ECT with S mode all the time for about 15,000 miles give or take. Now I don't use ECT at all anymore. I have no knowledge if it affected how my truck drives now. I've said this before, for me personally the biggest improvement in drivability was adding a throttle amplifier. I don't have to put the gas pedal through the floor board to get it to respond.
  14. Aug 4, 2022 at 9:16 AM
    #914
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
  15. Aug 4, 2022 at 9:31 AM
    #915
    Nyrob
    Robert
    2021 SX 2.7 AT 4WD
    Which device do you have pedal commander? That is probably the most excited thing I am when tunes start to become available adjusting the pedal sensitivity. I had a pedal commander but after a year and about 12k I started to get brake malfunction code pop up a quick search and it seems a lot of people have that problem overtime with them. I pulled it out and decided to just wait for a real tune but it’s taking a while lol
  16. Aug 4, 2022 at 9:35 AM
    #916
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    i might go with a pedal commander too. i was waiting for a tune but i don't think we will get any for at least a few years it seems like.
  17. Aug 4, 2022 at 12:12 PM
    #917
    TacoMike
    Pennsylvania
    I bought one off fleabay called 9drive or something like that. It was vehicle specific. I've had it on well over a year now with no issues.
    GlideOn likes this.
  18. Aug 8, 2022 at 3:41 PM
    #918
    Nyrob
    Robert
    2021 SX 2.7 AT 4WD
    Thanks for the heads up grabbed one off Amazon it was like $55 bucks, seems to be the same as the pedal commander i had at 1/5 the price will tide me over until or if ever a tune is released
  19. Aug 13, 2022 at 1:48 PM
    #919
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
  20. Aug 13, 2022 at 2:00 PM
    #920
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    :bananadance::burnrubber:
    PapaRee[QUOTED] likes this.
