3rd Gen Tacoma 2.7L ECU Tuning
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Sep 10, 2017.
  1. Oct 29, 2017 at 12:48 AM
    #101
    Dabitha Nuggsworth
    Dabitha Nuggsworth Was stuck in garage, now stuck in hell
  2. Oct 29, 2017 at 7:41 AM
    #102
    Fleischwagen
    Fleischwagen 2.7 > 3.5
    North Jersey
    2017 SR 5MT 4X4
    5.29's, ARB locker, 6112/5100, Deaver AAL, LCE Header, aFe dry-flo filter, Hurst/Core shifter, CBI T3 Front, Warn Winch, CB/UHF Radio equipment, Backrack, KC fogs and spots
  3. Oct 29, 2017 at 9:36 AM
    #103
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Any progress on this?
    Kuntrykid and 5 Lug Fury like this.
  4. Oct 29, 2017 at 9:43 AM
    #104
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    They are still working on the MT tune for the 3.5, after that is done then they said they would have some time to work on the 2.7 tune.
    mikestaco17 and MOC221_ like this.
  5. Oct 29, 2017 at 9:46 AM
    #105
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Yep, we may see the first V6 M/T version drop to the masses soon. Mat is back on the ground this week so things should pick up. The first dyno pulls have been done and one guy has had 1.03 for a coupla weeks. Hang in there guys..
    Bowers86 and 5 Lug Fury like this.
  6. Oct 30, 2017 at 12:44 PM
    #106
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I'm more interested in better shift points for the auto tranny than squeezing power out of the 2.7L. Better driveability is more important to me but more power doesn't hurt. I'm going for LCE headers next and maybe electric fans.
    mikestaco17, MOC221_ and 5 Lug Fury like this.
  7. Oct 30, 2017 at 2:59 PM
    #107
    DecaturTide
    DecaturTide Well-Known Member
    River City
    2016 SR AC BARCELONA RED
  8. Oct 30, 2017 at 4:48 PM
    #108
    mikestaco17
    mikestaco17 Well-Known Member
    MIKE
    BAD ASS UTILITY CAB
    patiently waiting sir
    5 Lug Fury likes this.
  9. Oct 30, 2017 at 4:52 PM
    #109
    mikestaco17
    MIKE
    BAD ASS UTILITY CAB
    nice I myself have ben looking into the spal 300w and 500w electric fans , there sealed and brushless fans , just may free up some ponies!!!!!
  10. Oct 30, 2017 at 6:37 PM
    #110
    Nitori
    Maricopa AZ
    2021 T4R SR5
    I've looked into electric fans too, but there's a lot of engineering behind it.
    First and foremost is the actual temp control. We already have a temp sensor, but reading its input for a fan control circuit is a can of worms. Not that I couldn't potentially look up connector PNs and whip up a splice free piggyback, but at the very least you'd have to have some sort of controller read the voltage and kick on a relay. (and maybe even have a manual "on" switch)
    Not rocket science, but one bullet point on a list of items. Some premade kits elect to stick a temp probe between the fins of the radiator, but that is ghetto and unreliable, in my opinion it should not be part of a proper solution.
    There's also the question of A/C- you shouldn't really have the A/C running without a fan running too- so now you're looking at tying into another electric system.
    Most often ignored is good shroud design. Simply zip tying a spal fan onto your rad isn't gonna cut it. Often times a kick ass fan with no shroud actually ends up netting higher temps than stock with shroud. The stock shroud is also designed around the clutch fan's "passive pull" because it's always spinning. You want something that doesn't let much air "leak" while stopped, but allows passive cooling when you are moving without the electric fan on.
    Most well regarded kits give you an aluminum shroud with rubber flaps that open up for a little extra passive cooling, like this:
    Note that is also sealed all around the edges with weather stripping- the seal here is super important!
    I know there are some OE solutions where the 2TR is run without a clutch fan, but if I remember right that's only on the Toyota Hiace which is a bizarre cabover van thing, and the fans are mounted super low and suck air down thru the radiator.
    I'll do some digging because now you've got me curious, but I think it's most likely that the 2TR tends to default to clutch fans in most applications.
    So ultimately, if the end goal has to be 100% rock solid reliability the clutch fan is actually pretty damn good, all things considered, unless you spend a lot of time, research, and development on making a proper kit for the 2TR. And I've heard that it's not even that much power you free up anyways- go spin your fan blades by hand (with the engine off!! :eek:) and you can feel it puts up some resistance, but if you've ever done a timing belt it feels like way less force than what the cams and valve springs give you.
    Just my $.02, I'm not opposed to the idea but I would want to see a lot of careful thought put into the design plus some solid data to back up the claims.;)
  11. Nov 7, 2017 at 8:24 PM
    #111
    Fleischwagen
    North Jersey
    2017 SR 5MT 4X4
    Am I the only one who thinks the truck makes more power when it's warming up? It seems the cold start enrichment makes the truck seem more responsive..
    mikestaco17 likes this.
  12. Nov 8, 2017 at 4:47 PM
    #112
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Somebody just needs to Dyno a truck with and without a fan
  13. Nov 15, 2017 at 10:46 PM
    #113
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    :bananadance:
    I can't like this enough
    :popcorn:
  14. Nov 15, 2017 at 10:47 PM
    #114
    05Taco4x4
    2TR-FE Enthusiast
    You should definitely do 2nd Gen before 3rd gen, way more people.
    Boring likes this.
  15. Dec 3, 2017 at 6:15 PM
    #115
    Fleischwagen
    North Jersey
    2017 SR 5MT 4X4
    Updates? Anything?!
  16. Dec 4, 2017 at 10:00 AM
    #116
    OVTune
    OVTune Well-Known Member
    OVTune
    we will have a major announcement very soon regarding several toyota platforms we support
  17. Dec 4, 2017 at 10:18 AM
    #117
    05Taco4x4
    2TR-FE Enthusiast
    Exciting
    Boring, Durango95 and RocTaco like this.
  18. Dec 4, 2017 at 10:52 AM
    #118
    Fleischwagen
    North Jersey
    2017 SR 5MT 4X4
    Awwwww yes!!!! Can't wait to hear!
  19. Dec 4, 2017 at 12:22 PM
    #119
    OVTune
    OVTune
    We just signed the deal for exclusive distribution of our toyota tuning tool for the USA..
    So we will be releasing end user tuning options for everything! 2.7L Tacoma included!
  20. Dec 5, 2017 at 11:12 AM
    #120
    Fleischwagen
    North Jersey
    2017 SR 5MT 4X4
