3rd gen Tacoma 4.88 Re-gearing speedo/odo
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Offroad2WD, Nov 8, 2019.
  1. Nov 8, 2019 at 8:51 AM
    Offroad2WD
    Offroad2WD [OP] New Member
    Khiem
    2019 Tacoma TRD Offroad 2WD
    Hello guys,
    I have a 2019 Tacoma 2WD. I'm about to put 4.88 Nitro gears on my truck and leave everything stock for now. Would 4.88 gears change the speedo and odo readouts?
    Thank you.
  2. Nov 8, 2019 at 9:26 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    i don't know the answer but i also have a 2WD i would like to do the same. have you thought about installing true posi traction while doing the re gear?
  3. Nov 8, 2019 at 9:32 AM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    Speed sensors are part of the wheel ABS assembly, not transmission. Re-gearing won't affect the speedo, but different sized tires will.
    Satchmo likes this.
  4. Nov 15, 2019 at 11:15 AM
    Satchmo
    Satchmo Member
    2019 Black Tacoma Double Cab with Sport Upgrade
    TacoMamba35 is correct. I just had Nitro 4.88s installed and left my tires stock. No variance in speed or speedometer accuracy.
