3rd Gen Tacoma A/C Noise
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dpippel, May 23, 2018.
  1. May 23, 2018 at 12:25 PM
    dpippel
    dpippel [OP] Well-Known Member
    Phoenix, AZ
    Super White 2020 TRD Off Road 4WD DCSB A/T
    Greetings all! New member here. I purchased my 2018 TRD Off Road A/T in the middle of April, and overall I love the truck (coming from a 4th gen 4Runner SR5). However, since Day One I've had cabin noise issues with my air conditioning. Two different sounds that seem to be related. Here's what happens:
    When I'm running the A/C and the truck is actively moving or accelerating, a very noticeable "sighing" sound can be heard emanating from the dash. It actually sounds like Darth Vader breathing and is VERY annoying. It cycles about every 4-5 seconds. I'll hear the sound for 4-5 seconds, it will stop, then it will come back in 4-5 seconds. Lather, rinse, repeat. The timing between incidents can be variable, but it happens ALL THE TIME when I have the A/C running. Particularly noticeable on the two lowest fan settings, probably because the fan noise on the two higher settings drowns it out. If I turn off the A/C button in the middle of one of these sighs, the sound stops instantly.
    The OTHER sound issue is related, but doesn't always happen. When it does, it's typically during acceleration. It's a whistling sound, almost like the sound you hear when you blow across the top of a half-full beer bottle, and it coincides perfectly with the Darth Vader sigh. It can be quite loud. My wife heard it for the first time this weekend and said "Wow! That's not normal!", so it's not just me.
    Neither of these issues are evident if the truck is sitting at idle with the A/C running, only when it's actually being driven.
    This is making me nuts! I've taken it to the dealer once, with the same detailed info that I've presented here, and they told me they couldn't find anything wrong. The mechanic asked that I put another 1K miles on the vehicle (it had 500 on the odometer when I took it in) and bring it back if the problem was still there. Well, it IS still there and the whistling sound has actually become worse. I'm going to be taking it back to the dealer next week for this to press them on it, and I'm also going to take a different Taco for a test drive to see if it has the same problem.
    No other vehicle that I've ever owned has had an A/C system that sounds like this, and I can't imagine it's by design. Has anyone else here experienced this issue? If so what was the fix?
    PatosTaco and Sunusu like this.
  2. May 23, 2018 at 12:32 PM
    Mtn Mike
    Mtn Mike Well-Known Member
    Spokane, WA
    2017 TRD OR AC
    Oh great, more 3rd gen Tacoma quirks that I now have to obsess about looking for in mine. :lalala:
    Mine does the whistling noise, but I've never associated it the the AC. Maybe turn up the music?? :rockband:
    djgynee, BillsSR5, JonesMGMOR and 3 others like this.
  3. May 23, 2018 at 12:36 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Yeah they all make the Darth Vader Exhaling sound, you will get used to it.
    drewmac270 and sierra141 like this.
  4. May 23, 2018 at 12:55 PM
    dpippel
    Phoenix, AZ
    Well that's disappointing to hear. Like I said, this is the only vehicle out of the 11 I've owned that has an A/C system that sounds like this. My wife's 2016 4Runner doesn't do it either. Thanks a million, Toyota. :(
    shakerhood likes this.
  5. May 23, 2018 at 1:02 PM
    Freetime
    Freetime Well-Known Member
    2016 TRD OR AC 4x4 Quicksand
    Mine only does the whistling sound first thing in the morning when I turn the air on as I am pulling away from the house. Never does it again after that. I always have the AC on, recirc off, temp about 2 notches above max.
    davidstacoma likes this.
  6. May 23, 2018 at 1:12 PM
    GR8APE
    GR8APE Well-Known Member
    I'm 64 years old and have quite a bit of hearing loss which can be a good thing sometimes . My wife on the other hand has incredible hearing. In fact she is always hearing things that I can't. She has never mentioned hearing any odd noises coming from my truck, so no they don't all make it.
    TDImark, BillsSR5 and Jeremy4x4 like this.
  7. May 23, 2018 at 2:25 PM
    shakerhood
    Southern Ohio
    I think it may be the vacuum actuated blend doors moving so it's just the air sounds, most people probably don't pay attention to it or just get used to it.
  8. May 23, 2018 at 2:29 PM
    dpippel
    Phoenix, AZ
    That's a good guess. I wouldn't mind it so much if it wasn't so LOUD. I can hear it above human speech from the radio when I'm driving below 40. I'm still taking it back to the dealer and will at the very least do that test drive to compare how mine sounds with a different truck.
  9. May 23, 2018 at 3:03 PM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    A/C??? We need no A/C in Az.
  10. May 23, 2018 at 3:08 PM
    dpippel
    Phoenix, AZ
  11. May 23, 2018 at 3:22 PM
    shakerhood
    Southern Ohio
    Do you have the Dual Zone Climate Controls?
  12. May 23, 2018 at 3:24 PM
    dpippel
    Phoenix, AZ
    I do not. Decided to pass on the Premium Package due to headroom issues with the moonroof, so just got the Tech Package.
  13. May 24, 2018 at 7:13 AM
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    The blowing across a bottle sound may be the lower control arm kazoo. It typically happens at lower speeds. Check your lca’s for plugs.
    Skydvrr likes this.
  14. May 24, 2018 at 7:15 AM
    dpippel
    Phoenix, AZ
    Thanks for the info, but it is most definitely coming from the A/C. If I turn off the A/C while it's whistling, the sound stops instantly.
    josehh07 and SandyTaco4x4 like this.
  15. May 24, 2018 at 8:36 AM
    shakerhood
    Southern Ohio
    It is definitely the AC, i believe it is the blend doors, sounds like a pressure release. After you shut the truck off and sit for a few seconds you can actually hear it moving too.
  16. May 24, 2018 at 8:45 AM
    Burro09
    Burro09 Well-Known Member
    Miami, FL
    2017 Tacoma TRD Pro Cement MT
    Mine does it too. Sounds like some harmonics in a refrigerant pipe. Maybe future models might get a muffler somewhere. Doesnt bother me. If i had to compare it to something, it kind of sounds like a steam whistle under the hood.
    EDIT. Mine does it most when its very hot outside, and under acceleration. The compressor seems to really shake the engine when cycling on vs. Other cars i have driven. On a hot day compressor engagement feels like a misfire. These use the new refrigerant at higher pressures, maybe its that?
  17. May 24, 2018 at 9:46 PM
    Riding Dirty
    PlastiDip
    Wow, that’s really interesting. Mine never did that, so I’m kinda surprised at that.
    shakerhood[QUOTED] likes this.
  18. May 25, 2018 at 12:46 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    What you are hearing is the refrigerant expanding into the evaporator in the dash everytime the compressor cycles on. It is expanding and cooling (as that is how the refrigerant works). In my previous vehicles (specifically a GC), this was an indication of slightly low refrigerant. Even my 89 Honda does it. In the Taco, I don't know if that holds true. You may want to have the dealership check the refrigerant levels. I bet if they add just a couple more ounces of refrigerant, the sound will mostly go away.
    AKGSD, BillsSR5, Skydvrr and 2 others like this.
  19. May 25, 2018 at 5:41 AM
    Freetime
    That's because the truck automatically turns on fresh air when you shut it off to keep the AC system from staying damp inside and getting mildew/mold
  20. May 25, 2018 at 5:51 AM
    Burro09
    Miami, FL
    I dont think this truck or any toyota has used vacuum blend doors for quite a while. Thats an old Merican thing from my experience. It was so sarisfying hearing the pressure release when shutting the a/c off.
    The auto ouside air when shutting truck off is genius though. I always did that manually before shutting off the a/c to reduce moldy smells.
    Skydvrr likes this.
