3rd gen tacoma anytime fog mod!!!!!!!!!!!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cdubray, Nov 14, 2018.
  1. Jan 12, 2021 at 7:57 AM
    #181
    Gehxplore
    Gehxplore Member
    G
    2019 Black Taco TRD Sport
    Hi!
    Thanks to you all for figuring this out and posting.
    Got my new to me 2019 a couple months ago and have been trying to figure this out {was so easy in my 2014}.. I go exploring in the ADKs and need all the light i can get..
    my question is:
    where is the: " ignition switched power via an add a circuit fuse tap in the interior fuse box " tapped from?
    any pic?
  2. Jan 18, 2021 at 5:20 PM
    #182
    Victory
    Victory Well-Known Member
    St. Pete, FL
    2016 White Tacoma TRD Off Road
    Sorry don’t have a pic. I tapped the “P. Outlet” fuse (cigarette outlet). That’s a 12v ignition switched fuse. Use an add a fuse tap.
  3. May 14, 2021 at 4:30 PM
    #183
    Graydog
    Graydog New Member
    2018 Tacoma TRD OFFROAD
    Did this ever come to fruition? Was it a plug and play fog anytime mod? I am very interested if this is still available. Thanks!
  4. May 23, 2021 at 2:49 PM
    #184
    Red18Taco707
    Red18Taco707 Well-Known Member
    Richi
    Nor Cal
    Red 18 TRD POOR
    Installed the Brite Box. Works as advertised
    70F95C69-85AA-40DE-B1A7-58D2B97F11F5.jpg D8447462-F94F-4AAA-B02E-164EEBA2CAAB.jpg
    TacoPandaTRD and Graydog like this.
  5. Nov 16, 2021 at 10:36 PM
    #185
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
    Did you get the anytime fog with the separate switch or the one for just the fogs with highbeams?
  6. Dec 10, 2021 at 7:38 AM
    #186
    Cereal_killer
    Cereal_killer Well-Known Member
    Dan
    '18 Off-road, ‘96 V6
    Yeah
    I’ve managed to get fog lights anytime cutting only one wire and tapping 2 others. It’s also retained the dash indicator (except when high beams are on).
    I did it with an N channel FET instead of a relay or the P channel FET method as this way only required cutting a single wire.
    N FET:
    Gate - illumination source, I tapped into the dash light circuit at the clutch start button
    Source - tapped M6_26 (BLUE) from the factory switch
    Drain - CUT 1F_27 (tan) and hook to the truck side [not the ECU side, leave that floating]
    I just used a random circuit board I had in my junk bin with a TO-92 footprint for the N FET but you could simply air wire it. Don’t forget the pull down resistor between source and gate to ensure it turns fully off.
    B7E867BE-AB7B-4CC4-832F-01F521FF420F.jpg 23CC235F-8813-4D90-BB76-ACDF415FB3B6.jpg F19A8392-38EE-46EB-AC6D-74AF50595FC6.jpg
    Karminski likes this.
  7. Dec 10, 2021 at 8:04 AM
    #187
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That was the entire mod? No running power wires to the fogs?
    :cheers:
    Cereal_killer[QUOTED] likes this.
  8. Dec 10, 2021 at 8:28 AM
    #188
    caribe makaira
    Caribbean, Puerto Rico
    If it's "anytime", you chose the dash illumination circuit why?
  9. Dec 10, 2021 at 9:35 AM
    #189
    Cereal_killer
    Dan
    Yeah
    Yes, 3 wires behind the dash cubby. What’s in the 2 pictures it literally it!
    Because that wasn’t what I wanted, if you wanted to use this method but have true anytime just connect the FET gate to switched accessory 12v. My desire was fogs with high beams and this accomplishes that.
    tonered[QUOTED] likes this.
  10. Dec 10, 2021 at 9:36 AM
    #190
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Nice! You want to make another one of those for the sparky challenged? :D
  11. Dec 10, 2021 at 9:42 AM
    #191
    Cereal_killer
    Dan
    Yeah
    I would be glad to however you can buy a non surface mount N-FET so you don’t have tiny delicate soldering to do. I just happened to have this FET and figured I’d slap it on the old PCB so it had the copper for heat sinking, not that it’s creating any heat being used as a switch like this.
    N-MOSFETS are a dime a dozen if you wanted to source a through hole part for easier soldering.
    Edit here’s a good choice
    https://www.mouser.com/ProductDetail/Vishay-Siliconix/SIHA22N60AE-GE3?qs=MLItCLRbWsxWrMye2VTGJQ==
    Karminski and tonered[QUOTED] like this.
  12. Dec 10, 2021 at 9:44 AM
    #192
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I am sure there would be some demand, but if it is just soldering up to one component, I can pull that off. Can you toss up a link to the proper one?
    Thanks!
    :cheers:
  13. Dec 10, 2021 at 9:53 AM
    #193
    Cereal_killer
    Dan
    Yeah
    Looking at the data sheet this would be a great choice at >$4 from mouser electronics
    Don’t forget you’ll want a 10k resistor between gate and source, any old 1/4w resistor will work but lmk if you want a mouser PN for that too. It’s not totally required and I’d bet money it’d work without one but good design practices tell us to have one in the circuit.
    Do you need a diagram or is my first post adequate?
  14. Dec 10, 2021 at 10:07 AM
    #194
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yeah, I need all the help that I can get, but I did buy one of these from @Victory. I never got around to installing it due to the wire routing. Can that be repurposed for your version of the mod?
  15. Dec 10, 2021 at 10:38 AM
    #195
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Am I the only one who doesn't understand the point of fog lights + high beams? Is it for slow driving in pitch dark where you want side illumination? In which case would ditch lights not be preferable?
    The fog spec is very specific and meant to be most helpful in fog where high beams are a really bad idea.
    So, this is just a way to get more than one use out of a light designed to meet a spec which is specifically for a single purpose?
    Montana_Actual likes this.
  16. Dec 10, 2021 at 10:41 AM
    #196
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    For dark, rural roads when no one else is around. Max lighting. Fogs and low beams or fogs and parking lights in actual fog.
    I definitely do not want ditch lights. :D
  17. Dec 10, 2021 at 12:25 PM
    #197
    Cereal_killer
    Dan
    Yeah
    It won’t work, an N channel mosfet switches a negative circuit from a positive signal (What I’ve used), a P channel mosfet switches a positive circuit from a negative signal. With no more cut factory wires but a little more add-on wiring (one maybe two more wires) you could do this same method with a relay of you have one. SPDT (5-pin).
  18. Dec 10, 2021 at 12:28 PM
    #198
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks for the kid level explanation. I do appreciate it.
    I will follow your method for the min amount of modding.
    Thanks!
    :cheers:
  19. Jan 22, 2022 at 8:01 PM
    #199
    justdoit
    justdoit Well-Known Member
    Colorado Springs
    22' 4x4 AC TRD Off-Road
    I just jumped the high beam relay to the fog relay.
    Simplythetruth likes this.
  20. Jan 22, 2022 at 9:26 PM
    #200
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    3rd Gens don't work like that. Zero gray wire mod possibilities.
