3rd gen tacoma anytime fog mod!!!!!!!!!!!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cdubray, Nov 14, 2018.
  1. Nov 15, 2018 at 9:36 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    No problem. Thank you for putting this together.
  2. Nov 15, 2018 at 9:41 AM
    hallux
    hallux Well-Known Member
    Thanks for this!
    Just wish there was a way to NOT cut the wires. Hmmm maybe @mesojdm and @DSIM can finagle something like that ECT mod.
  3. Nov 15, 2018 at 11:14 AM
    CementHead18
    CementHead18 Well-Known Member
    Jim
    SC
    2018 CementTRD Sport 4x4 DCSB
    Thanks Victory... I'm sure that's what he has and I also thought they looked a little different from the standard fogs. I'll have to take a closer look at them.
  4. Nov 28, 2018 at 9:09 AM
    Victory
    Victory Well-Known Member
    St. Pete, FL
    2016 White Tacoma TRD Off Road
    Anyone else do this yet?
  5. Nov 28, 2018 at 10:37 AM
    AmericanDrug
    AmericanDrug Well-Known Member
    Rod
    Valdosta, GA
    2018 TRD OR 4x4 6mt
    I was just wondering if this was possible, just put in led pods for fogs. Anybody else try this?
  6. Nov 28, 2018 at 12:15 PM
    Victory
    St. Pete, FL
    Just ordered some parts, I’m going to tackle this on Sunday, I don’t want to cut stock wires, but think I found a way around that.
  7. Nov 28, 2018 at 12:22 PM
    xA101x
    xA101x Well-Known Member
    AJ
    Idaho
    2017 TRD PRO MT
    Keep us updated!
  8. Nov 28, 2018 at 12:25 PM
    KTJO 4x4
    KTJO 4x4 Well-Known Member
    Katie
    Oregon
    2017 TRD OFF-ROAD 4x4 DCSB BARCELONA RED
    Nitro 4.88 Gears OVTune 1.05 91Oct DirtyDeeds Exhaust
    I will be excited to hear back. I’ve been swamped so I haven’t had the chance to even look into this yet
  9. Nov 29, 2018 at 1:30 AM
    cdubray
    cdubray [OP] Active Member
    Cody
    2017 Tacama
    Yes! Let me know if there is a way to do it without cutting wires! (Even tho I already have) that would be awesome
  10. Dec 1, 2018 at 7:28 AM
    Victory
    St. Pete, FL
    @cdubray you say the blue wire is +12v when fog switch is off and 0v when switch is on?
    It also looks like this is connected to +12v constant (the battery, not ignition controlled) It seems to me this would mean the lights would turn on when you turn the truck off, but obviously this can’t be correct? Am I missing something or should there be a switched ignition source somewhere?
    Edit: nevermind I just checked and it looks like that blue wire is also an always on +12v even when the truck is off.
    KTJO 4x4 likes this.
  11. Dec 1, 2018 at 9:15 AM
    VicNic3
    VicNic3 Well-Known Member
    GA
    2018 Toyota Tacoma Sport 4x4 DCSB Silver Sky Metallic
  12. Dec 1, 2018 at 9:26 AM
    KTJO 4x4
    Katie
    Oregon
    Yeah. I don’t believe that is for the actual fog light to work anytime. I believe that is for the halo to work with the DRL and then the fog light works like OEM. I could be wrong
  13. Dec 1, 2018 at 9:26 AM
    KTJO 4x4
    Katie
    Oregon
    I’m excited for you to get this done and what you come up with
  14. Dec 1, 2018 at 12:13 PM
    Victory
    St. Pete, FL
    0FA1F6EA-A9C8-4228-AAB6-BFC718F8BE65.jpg 7D3CAAEA-DEC3-4FAB-B158-1F6A08C65621.jpg 7742C958-982D-4DC8-AE7E-827FF1EE8424.jpg
    So I’ve got it all hooked up, I got around cutting the stock wires by buying a new harness from Amazon:
    iJDMTOY (1) H11/H8 Relay Harness... https://www.amazon.com/dp/B019J7XIGC?ref=yo_pop_ma_swf
    This has the connectors that will clip into stock fogs (though I did have to reverse the polarity for the Rigid Fogs). I taped off the stock fog harnesses and left them disconnected behind the fogs.
    This also comes with a Relay so no need to buy that, but I did buy the resistor and P Channel MOSFET from the first post.
    I have 2 MOSFET chips left but plenty of resistors left. The MOSFET chips have been wired up with a pigtail and the resistor $3.50 each for those, or $1 for resistors and I’ll throw in a spare.
    I did connect it slightly different from the OP; instead of connecting to always on 12V I connected to ignition switched 12V so the fogs would turn off when ignition is off. I connected to the power outlet fuse with an add a fuse circuit on the inside circuit box.
    I have edited the original wiring diagram made by @cdubray to show this.
    Gehxplore, KTJO 4x4 and tonered like this.
  15. Dec 1, 2018 at 8:44 PM
    #35
    KTJO 4x4
    Katie
    Oregon
    Sent you a PM. However, if this new harness just takes place of the OEM harness, I think I’d rather use OP’s with your Ignition Switched 12V. I do not want to add another switch in my truck when I have a perfectly good switch already there. Is this the only other way of doing this? I haven’t even had time to try the 2nd gen wiring diagram like I had planned to do because I’ve been so swamped.
  16. Dec 1, 2018 at 8:46 PM
    #36
    Victory
    St. Pete, FL
    The factory switch still works I did not use the switch that came with that harness, I just wanted the wiring and H11 connectors so I could cut those up and didn’t have to cut up my stock wiring.
    You don’t need the harness but you would need to buy a relay anyway and also cut stock wiring.
    Really the only change I added to the OPs directions was hooking up the relay to ignition switched power via an add a circuit fuse tap in the interior fuse box so the lights would shut off when the truck shut off. Otherwise I just used different wiring to do the same thing.
    The indicator on the dash only lights up when the headlights are on in parking or low beam mode, but the fog lights now switch on when headlights are off and also on with high beams (but the indicator won’t show)
    If you connect it following the OPs diagram the lights won’t turn off when you shut off the truck, you would have to manually switch them off, with my edited version of his wiring diagram they will shut off when the truck is shut off even when the switch is on.
    In addition to the harness with relay you will need a little extra wiring, maybe 6 feet, an add a circuit fuse tap, the MOSFET chip and resistor, some wire taps (I like positaps) and some butt connectors (I like heat shrink butt connectors) or solder and tape or heat shrink.
    Gehxplore, 2016trdtacoma and tonered like this.
  17. Dec 1, 2018 at 8:53 PM
    #37
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
  18. Dec 3, 2018 at 2:26 AM
    #38
    cdubray
    Cody
    2017 Tacama
    This is awesome! Great idea wiring the source to 12v ignition! Love it! And you don't have to cut wires with that harness! Awesome! Was no use to me though as I have aftermarket pods lol.. but will help others!
    Victory[QUOTED] likes this.
  19. Dec 3, 2018 at 3:39 PM
    #39
    Victory
    St. Pete, FL
    A few people have asked me to essentially put together a shopping list of what is needed to complete this.
    You will need;
    MOSFET P Channel chip
    https://www.amazon.com/dp/B00MMYMA1O?ref=yo_pop_ma_swf
    15k resistor -PM me I’ll send you a couple for $1 shipped.
    https://www.amazon.com/dp/B0185FIPIA?ref=yo_pop_ma_swf
    4 Pin Relay, I recommend getting this wire harness which will give you the relay, extra wiring, a fuse, a terminal to connect to the battery and H11 connectors so you don’t need to cut your stock wiring. (Just throw the included switch away as you won’t be using it)
    Add a Circuit Fuse Tap with two 15amp fuses. I recommend Micro but mini will also work.
    https://www.amazon.com/dp/B071NH98YN/ref=cm_sw_r_cp_api_1UBbCbSJSE2A2
    You will also need some blue butt connectors (I recommend heat shrink butt connectors) https://www.amazon.com/dp/B01N6WWKDD/ref=cm_sw_r_cp_api_T2BbCbKPNRXSN
    And a Crimper/Stripper.
    https://www.amazon.com/dp/B000JNNWQ2/ref=cm_sw_r_cp_api_Q1BbCb4WYMRVG
    A little extra wiring would be a good idea even if you buy the harness.
    https://www.amazon.com/dp/B07D74RGVM/ref=cm_sw_r_cp_api_v6BbCb7JGJT6H
    These links are just examples, they may not be the best brands or best prices, so you may want to shop around a little still, but should give you an idea.
    tonered and backcountryj like this.
  20. Dec 3, 2018 at 3:43 PM
    #40
    Victory
    St. Pete, FL
    Sorry these are all sold, but if anyone needs resistors I’ll send them out for the price of a stamp and envelope.
    tonered likes this.
