3rd gen tacoma anytime fog mod!!!!!!!!!!!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cdubray, Nov 14, 2018.
  1. Oct 25, 2019 at 9:29 PM
    #101
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    It was a fun exercise to brainstorm through. I may use a similar wiring setup in the near future with the additional aux lights I have in the works. :)
    cactushead[QUOTED] likes this.
  2. Oct 26, 2019 at 1:30 AM
    #102
    caribe makaira
    Caribbean, Puerto Rico
  3. Nov 26, 2019 at 6:28 AM
    #103
    ILuvHotTaco
    ILuvHotTaco Well-Known Member
    2017 TRD OR DCSB MGM
    Any update on your PnP harness?
  4. Dec 12, 2019 at 4:18 AM
    #104
    ILuvHotTaco
    I guess if I wanted a response I probably should have copied @KTJO 4x4 on my question.
    KTJO 4x4[QUOTED] likes this.
  5. Dec 12, 2019 at 6:52 AM
    #105
    KTJO 4x4
    KTJO 4x4 Well-Known Member
    Katie
    Oregon
    2017 TRD OFF-ROAD 4x4 DCSB BARCELONA RED
    Nitro 4.88 Gears OVTune 1.05 91Oct DirtyDeeds Exhaust
    I am actually working on getting 16 of these PNP Harnesses to start so I should have them soon :bananadance:
  6. Dec 12, 2019 at 7:15 AM
    #106
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Do you have a thread for this PnP harness?
  7. Dec 12, 2019 at 7:16 AM
    #107
    KTJO 4x4
    Katie
    Oregon
    Not yet but I will be starting one when I get the harness ;) I will also have it on my website at www.ktjo4x4.com
    Tacospike and Technique[QUOTED] like this.
  8. Dec 12, 2019 at 7:29 AM
    #108
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Holy Shit! You have a grab handle concept!? You need to be yelling that from the rooftops. :cheers:
    I am tapped out now, but some time next year, I'm in!
  9. Dec 12, 2019 at 8:06 AM
    #109
    KTJO 4x4
    Katie
    Oregon
    Yes I do. Well any suggestions I’m all ears!! I have a thread on here for it. Haha I look forward to your purchase
    tonered[QUOTED] likes this.
  10. Dec 12, 2019 at 8:13 AM
    #110
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I didn't see that thread and don't see a link in our siggy. Searching!
    :cookiemonster:
  11. Dec 12, 2019 at 1:05 PM
    #111
    ILuvHotTaco
    Awesome! I'm in. Where do I get in line?
  12. Dec 12, 2019 at 1:17 PM
    #112
    KTJO 4x4
    Katie
    Oregon
    Subscribe to my website if you’d like, follow me for when I start the new thread in here, or just keep a eye out for the new thread :thumbsup:
  13. Dec 12, 2019 at 4:12 PM
    #113
    Slickestwilly
    Slickestwilly Well-Known Member
    Will
    NH
    25 Pro
    Any ballpark on $?
  14. Dec 12, 2019 at 6:36 PM
    #114
    KTJO 4x4
    Katie
    Oregon
    Piecing it all together now
    Stash419 likes this.
  15. Jan 29, 2020 at 1:12 AM
    #115
    sportracer829
    sportracer829 Taco Tuesdays... PShhh Taco Everyday!
    Andrew
    Colorado
    2018 Black TRD PRO DCSB
    So what this does not show is weather or not you even use the factory harness to plug into the fog lights. I am going to take a guess and say that you wire this into a plug that fits the fog lights and you leave the factory plugs tucked somewhere away?
    I have a TRD pro and water got in one of the rigid fog lights and its $250 just to replace one pod... I am going to switch them for CaliRaised aftermarket LED fogs and you can get them with a plug and play conversion for the factory harness as seen here.
    https://caliraisedoffroad.com/colle...-4runner-led-pod-to-fog-light-conversion-plug
    If what I said earlier was true about just leaving the factory harness tucked away then i would be able to use the conversion plug and take the factory side of the plug off and directly wire it to the power and ground from your diagram and viola it works?
    Or am i way off lol?
    EDIT*
    I also forgot to ask. So I dont wanna use the dim feature, if I just wire the yellow wire to the 12v power I will always have the brightest setting? If i just leave it neutral it will be the medium bright setting? If i ground it to something it will be the dimmest setting? obviously I am gonna want it to just stay on the setting I like but I wanted to make sure I had that theory correct.
  16. Jan 29, 2020 at 4:13 AM
    #116
    Garab
    Garab Well-Known Member
    2018 TRD Sport MT6 DCSB
    OVtune 2.0 TRD Sema wheels 265/70/17 Falken Wildpeak AT/3 SL ADM BAKflip mx4
    Ive got a 2018 sport 6MT and it works independently from the lights on mine. On the switch, first click is for the led DRL, second click is for the fogs, and third turns on the headlights.
    Is this not normal on all 3rd gen tacomas?
  17. Jan 29, 2020 at 6:48 AM
    #117
    Reegsy
    Reegsy Well-Known Member
    MA
    2018 TRD OR
    I do not (did not) use the factory plugs on mine, I tucked them away so I could put the factory fogs back in if I ever wanted to. I purchased some harness from Amazon, I think its listed early in the thread, not by me, I just got the one that was listed. You could, if you wanted, cut your factory harness connectors off and use them to wire to your new fogs to the setup I show. I wouldn't, I didn't have to cut any wires during the install, keeping the factory wiring intact was a priority for me.
    If you wire the yellow wire directly to the +12V the fogs would be at max brightness all the time when on. Buying the dimmer controller and following my setup would be pointless if you wired the yellow wire directly to +12V. You could just hard wire them to be bright af without the controller. If you wire the yellow wire to ground you can program a brightness level when you start the truck, it can be changed as many times as you want.
    I would wire in the switch, I keep the BD fogs I have at 30% when on regular roads, if i use them (rain fog snow). The 100% is way overkill and you will blind the f out of oncoming traffic, its a dick move. When I turn on the high beams and the fogs are on, they switch to 100% automatically, night becomes day, its crazy bright.
  18. Jan 29, 2020 at 7:22 AM
    #118
    Reegsy
    MA
    2018 TRD OR
    Do you not have a separate switch on the headlight stock for your fogs? I'm thinking that yours aren't normal. I obviously can't speak for everyone but (from what i can remember, not in my truck or going to look) the first position is drl/headlights off, second is auto headlights/drl, third is drl only, fourth is headlights/drl on, there is another switch on the same stock closer to the steering wheel for fogs on off.
    If you bought the truck used maybe the PO installed factory fogs but re-wired the stock to make them work instead of buying the correct one? idk
  19. Jan 29, 2020 at 7:58 AM
    #119
    mlr69
    mlr69 I had a savings account before I joined TW
    South Carolina
    2018 TRD Sport 4x4 DCSB
    2" ToyTec/Eibach Pro Sport Lift Kit -SparksParts.com 3/4" ToyTec Front Top Plate Spacer Kit -SparksParts.com SPC Performance Upper Control Arms -SparksParts.com Nitto Ridge Grapplers 285/75/17 (34") -SparksParts.com 1.25" Spidertrax Wheel Spacers -SparksParts.com Hypertech Speedometer Calibrator -hypertech.com Predator Tube Steps -SparksParts.com BAKFlip G2 Tonneau -SparksParts.com OEM Rubber Bed Mat -SparksParts.com OEM All-weather Floor Liners -SparksParts.com Gentex Frameless Mirror with Homelink @RJP869 Subaru/Kicker Tweeters -amazon.com Kicker Door Speakers (x4) -crutchfield.com Radio Knobs @Tacowiede Vehicle OCD Glove Box Organizer -amazon.com ‎JoyTutus Center Console Tray -amazon.com FormulaOne Pinnacle Window Tint -SparksParts.com ACDF Horn Kit @BartMaster1234 Total Tail Light S1 Kit @MESO ECT Button Relocation Kit @Tacowiede Minimalist Key Fobs @MESO Ultimate Map & Dome Lights @MESO Fortin EVO-ALL Remote Start w/Cell Module @jmeitz Coin Bucket with Lid @MESO GermesLab Camera Control System @FreshMexicanTaco Natika Front View Camera -amazon.com VLEDS LP Reverse Light System -vleds.com LIFTd Customs Fuel Cap Cradle @JIMMEISTER OEM Power Tailgate Lock -SparksParts.com OEM 2022 Limited Grille -SparksParts.com OEM 2022 Limited LED Headlamps -SparksParts.com LED Headlight Conversion Harness @daveeasa Headlight Trim Plates @MESO OEM Door Sill Protectors -SparksParts.com Diode Dynamics Elite Fog Lights @memario1214 Fog Light Backlighting PNP Harness @daveeasa TacomaTime Dash Cubby Drawer -etsy.com FPE Fogs + High-Beam Module @memario1214
    I have a 2018 Sport also, my outer ring switch is Off / DRL / Parking lights / Headlights. My inner ring switch is fog light Off / On. My fog lights only come on if the first switch is on either Parking lights or Headlights.
    Garab[QUOTED], Pablo8 and tonered like this.
  20. Jan 29, 2020 at 1:56 PM
    #120
    Garab
    This is a better explanation of it. I just always have my fogs on.
    So what exactly is the point of this mod? I mean I feel like I can turn my fogs on without the headlights so... what's the point of splicing into my wiring and creating weak points in the harness?
