3rd Gen Tacoma Custom Aluminum Front License Plate Mount
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MetrickMetal, Sep 27, 2016.
  1. Sep 27, 2016 at 10:47 AM
    MetrickMetal
    MetrickMetal [OP] Praise the Lowered
    Scott
    Yerington NV
    2017 Super White SR5 Access Cab / 4WD, AT / TP
    See my sig for mods
    Sorry, but I am no longer making these
  2. Sep 29, 2016 at 4:59 AM
    MetrickMetal
    Scott
    Yerington NV
    See my sig for mods
    Please only contact me about purchasing the license plate mounts by email to metrickmetal@hotmail.com.
    Thanks. Scott
    noiwillnotfixurpc and aceiswar like this.
  3. Sep 29, 2016 at 5:22 AM
    MetrickMetal
    Scott
    Yerington NV
    See my sig for mods
    I'm also selling my rear license plate mount spacers plates.
    These spacer plate fit in between the top mounting holes in the plastic center cap and the steel bumper support, and after drilling out the self tapping mounting threads in the plastic bumper center cap with a 17/64" drill bit, 1/4" mounting bolts of your choice can now be passed through the bumper cap, spacer plates and steel bumper support and secured with flat washers and nuts on the back side.
    This make for a much stronger and secure mount for the license plate by allowing the new 1/4" mounting bolts to a lockup solid against all three segments as opposed to the stock self tapping mounting screws only screwed into the 1/8" thick plastic bumper cap.
    If your also running a license plate frame, you can also cut away the plastic on the bumper cap to make room for the two lower license plate screws so that you can secure the plate and frame together so you don't two empty holes, which also makes the entire rear mount more secures and complete looking.
    The rear license plate mount spacer plates are $10 shipped only if ordered with the front license plate mount.
    So the total shipped for both front and rear license plate mounts will be $57.50
    Cheers. Scott
    My Truck likes this.
  4. Sep 30, 2016 at 2:59 PM
    marazaii
    marazaii Well-Known Member
    Mario
    Helena
    '16 DCSBOR4X4
    Does this eliminate drilling in the bumper cap? How thick is the aluminum?
  5. Sep 30, 2016 at 3:31 PM
    MetrickMetal
    Scott
    Yerington NV
    See my sig for mods
    If you read my post on the rear license plate mount spacer plates it clearly states that you drill out the self tapped mounting holes in the bumper cap, and as far as the thickness of the plates, they are the proper thickness to fill the gap between the bumper cap and the steel bumper support.
  6. Sep 30, 2016 at 5:14 PM
    marazaii
    Mario
    Helena
    '16 DCSBOR4X4
    I meant the front bumper "chin" I suppose is the name for it...
  7. Sep 30, 2016 at 8:29 PM
    Wu tang
    Wu tang Well-Known Member
    Reno
    Bump for local.
  8. Sep 30, 2016 at 9:42 PM
    MetrickMetal
    Scott
    Yerington NV
    See my sig for mods
    My front license plate mount uses the stock mounting holes and mounting screws, and the material thickness is stated in the first post.
    Cheers. Scott
  9. Oct 13, 2016 at 10:17 AM
    MetrickMetal
    Scott
    Yerington NV
    See my sig for mods
    For all of you that have bought my front license plate mount as well as anyone else who might be interested in it, you now have two mounting heights to choose from depending on how you mount the license plate mounting bars to the main mounting bracket.
    So attaching the license plate mounting bars with the long end facing down you have the low mount, and mounting the license plate mounting bars with the long end facing up give you a high mount.
  10. Nov 29, 2016 at 4:46 PM
    chriskcsa808
    chriskcsa808 Instagram: 4v6sandtrooper
    Christian
    2016 Quicksand Tacoma TRD
    Dang it require drilling for rear
  11. Nov 29, 2016 at 7:01 PM
    MetrickMetal
    Scott
    Yerington NV
    See my sig for mods
    Just drilling thru the two existing mounting holes in the plastic bumper cap which are only about 1/8" thick which is very easy with an electric hand drill and a 17/64" drill bit and takes less than 1 minute to do.
  12. Feb 6, 2017 at 10:42 AM
    MetrickMetal
    Scott
    Yerington NV
    See my sig for mods
    Here is a picture of the updated license plate mounting brackets with an additional 3rd mounting hole which gives you a total of 4 different mounting heights for the license plate. So you can attach the mounting brackets with the long end up for the high mount or down for the low mount. Then you can also fine tune the height up or down 1/2" by simply using the upper two mounting screw holes or lower two mounting screw holes.
    This pictures show the mounting brackets in the low position, with the right bracket shown mounted in the low position (stock height) and the left bracket mounted in the high position.
  13. Feb 6, 2017 at 6:56 PM
    not0ny
    not0ny Well-Known Member
    2017 MGM TRD SPORT DCSB 4X4
    Bilstein 6112/5160 JBA UCA
    Thanks for the mount Scott!
    Great customer service and communication!
  14. Feb 16, 2017 at 7:33 AM
    MetrickMetal
    Scott
    Yerington NV
    See my sig for mods
    Thanks.
  15. Mar 20, 2017 at 10:46 AM
    aceiswar
    aceiswar Well-Known Member
    i'm very tempted to pull the trigger on getting this...
  16. Jul 10, 2017 at 9:21 PM
    readyme
    readyme Well-Known Member
    Western WA
    2017 TRD OR DCLB
    Can you post some pictures after installation?
    Jaceto377 and joepagejr like this.
  17. Oct 27, 2017 at 8:26 AM
    Blake1979
    Blake1979 Member
    Blake
    2017 Tacoma TRD Off Road
    I tried emailing you says your email is not valid.
  18. Oct 31, 2017 at 5:54 AM
    MetrickMetal
    Scott
    Yerington NV
    See my sig for mods
    I've had this email address for years and you the first person to say this.
  19. Nov 17, 2017 at 7:37 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Just installed mine today. Very clean! Perfect design. I like the way it doesn’t hang over onto the silver trim piece like the stock Toyota Shoebox. Thanks @MetrickMetal for the great product!
    taco 16 likes this.
  20. Nov 20, 2017 at 1:16 PM
    MetrickMetal
    Scott
    Yerington NV
    See my sig for mods
    Thanks, and I'm glad you like it. :)
    Stocklocker[QUOTED] likes this.
