3rd gen Tacoma dead
Discussion in '3rd Gen. Tacomas (2016-2023)' started by black3rdgen, Jan 13, 2025.
  1. Jan 13, 2025 at 12:31 PM
    black3rdgen
    black3rdgen [OP] Well-Known Member
    STL
    3G on 35s, 5.29s
    YW tune, 5.29s, equal length dual exhaust, 2000w audio system
    Took the taco to work this morning and it was all 100% perfect, drove perfectly fine and started no issue. I go out to take it to lunch and it doesn’t crank or anything. Black on all the screens, dome lights come on super faintly. Assuming it’s just a loose terminal or something, hoping it’s not a draw. Got a new battery probably 2-3 months ago. Tried jumping it, and it cranks, just extremely slowly. Just wondering if anyone has had a similar experience, any help is appreciated!
  2. Jan 13, 2025 at 1:37 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Try cleaning the cable end clamps with a wire brush made for that purpose & reinstall.
  3. Jan 13, 2025 at 1:55 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Check (and possibly disconnect) all aftermarket wiring. Your album picture shows what appears to be underbody / inner-fender lighting.
  4. Jan 13, 2025 at 2:12 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Check terminals, have new battery tested, and disconnect any after market electrical doodads,,, right down to a phone charger.
  5. Jan 13, 2025 at 3:45 PM
    lit_taco4x4
    lit_taco4x4 IG and YT: @2a_crawlcamper
    Louie
    2018 Tacoma TRD Pro
    JD fab LT, Archive and Deavers, King shocks, Dual locked, Dual T case, Tundra steering rack, 39’s
    Sometimes even with new batteries, truck may still be drawing from somewhere such as OBD, etc.
  6. Jan 13, 2025 at 3:51 PM
    MGMDesertTaco
    swap the battery again, make sure the terminals are tight.
    shakerhood likes this.
  7. Jan 13, 2025 at 4:02 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Use a multimeter to check for draw while parked. It should be pretty minimal.
  8. Jan 13, 2025 at 4:07 PM
    black3rdgen
    STL
    3G on 35s, 5.29s
    Rock lights were busted out but still connected to the battery, so I took that off. Also took off wiring for an aftermarket horn I took off which could’ve been drawing to the relay. I put a new battery in so we’ll see if it dies again. Thanks for the help this thread can die now lol
    Gen3TacomaOBX[QUOTED] likes this.
  9. Jan 13, 2025 at 4:09 PM
    black3rdgen
    STL
    3G on 35s, 5.29s
    Excuse my stupidity but how do I check for a draw? I’ve only ever used that to check voltage..
  10. Jan 13, 2025 at 6:09 PM
    OnHartung'sRoad
    shakerhood and black3rdgen[OP] like this.
