3rd Gen Tacoma- dual usb ideas?
Discussion in 'Technical Chat' started by 50tree, May 28, 2018.
  1. May 28, 2018 at 3:55 PM
    50tree
    50tree [OP] Well-Known Member
    Portland, OR
    2017 Tacoma TRD OR 4x4 DC-SB
    None yet, that's why I'm here now
    Anyone have simple Wiring diagrams for this mod?
  2. Jun 3, 2018 at 6:35 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Can you be more specific as to what you want, where the addition usb ports should be, when they are hot, what you are planning on using.
  3. Jun 3, 2018 at 6:42 PM
    50tree
    Portland, OR
    @joeyv141 I would like to install a double USB port in the center console for kids/passengers in the back. I’ll most likely only want it hot when truck is on.
  4. Jun 3, 2018 at 6:48 PM
    joeyv141
    New Jersey
    Ok how electrically savvy are you? And do you already have a usb plug you want to use?
  5. Jun 19, 2018 at 1:38 PM
    bmgreene
    bmgreene Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Prinsu Cabrack, DIY custom in-bed storage/sleeping deck, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    There are dual USB port units that fit the regular size switch knockouts, but I've only ever seen a single port for the "small" switch pockets in the center console. There are a number of various units that are made to plug into a 12V port, but could be modified to hard-wire into an add-a-fuse and surface mounted wherever you want.
    For a more complicated solution, you could get a 12V-5V reducer unit in an appropriate size and wire that into something (such as wiring that output to a cut USB cable then feed a hub off of that for 4-8 ports if you want). If you go that route, you might need to wire a resistor from the "hot" to the inside pins of the plug to convince apple stuff that it's actually plugged into a data port instead of just a power port.
