3rd Gen Tacoma ECU-IG2 fuse keeps blowing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chachamurp, Jan 31, 2022.
  1. Jan 31, 2022 at 5:18 PM
    chachamurp
    chachamurp [OP] New Member
    2020 Tacoma and the ECU-IG2 fuse keeps blowing. The exterior tempurature dissapears off of dash and only says the direction East. Climate control cluster stops working, so I can't turn any heat or air. Cruise control won't work I assume from the pre-collison malfunction coming up on dash as well. Any ideas on where to start searching for the short?
  2. Oct 29, 2022 at 9:21 AM
    TRD-WY
    TRD-WY Active Member
    Wyoming
    2025 TRD OR
    Having the same issue. Did you figure out the issue?
