3rd Gen Tacoma Lower Ball Joint
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jonsd2000, Apr 7, 2023.
  1. Apr 7, 2023 at 9:37 AM
    jonsd2000
    jonsd2000 [OP] Member
    2019 Tacoma SR Double Cab
    Looking for a video or instruction on how to change just the ball joint on my Tacoma. Shop I go to is is sure it will take 2-3 hours of labor to do and wants $320 per side. I can only find a lower control arm with the ball joint assembly and can see that would take more time to justify the labor cost. I found this one: https://www.amayama.com/en/part/toyota/4333009510 Any advice is appreciated or if your local to the Portland, OR area and can help, maybe some beers and a few bucks to teach me how to do it!
  2. Apr 7, 2023 at 9:43 AM
    eurowner
    eurowner Duke Sky
    Scoty
    https://www.tacomaworld.com/forums/oregon.286/
    Chew likes this.
  3. Apr 7, 2023 at 10:06 AM
    Camel89
    Camel89 Well-Known Member
    Houston, TX
    2016 TRD OR 4x4
    I haven't done them yet, but I will be changing the LCA ball joints on my wife's 4Runner soon. Found this video to follow. Once you get the hub and axle out of the way, removing and installing the ball joint seems pretty straightforward. You can rent a ball joint press from Autozone/Oreilys for free; I just got done using one replacing the u-joints in my driveshaft.
    A couple of things I would do differently than the guy in the video: 1. Soak the old ball joint with a penetrating spray for a few hours. Should make removal easier. 2. Once the old ball joint is out, clean out the flange with some brake cleaner. Deburr with a file if needed.
    Edit: One other thing, I think installing would have been easier had he flipped the press, so that it would be pushing up on the joint. I would also probably use a breaker bar instead of power tools to keep a closer eye on it, but that's just me.
    Topanga Taco likes this.
  4. Apr 7, 2023 at 10:17 AM
    kaljam
    kaljam Well-Known Member
    Bill
    New Hampshire
    2023 TRD Sport wind chill pearl
    There seems to be loads of ball joint choices on Rock Auto.
  5. Apr 7, 2023 at 10:17 AM
    sb0623
    sb0623 Well-Known Member
    DFW
    2022 Toyota Tacoma TRD Sport
    Limo tint, hitch step, grill guard, chrome running boards, running board lights, bed cover, dash cam, interior LED bulbs, MBRP cat back dual exhaust w/chrome tips, MillerCAT cat shield
    Always shop out of state for parts, 1/3 cheaper than local dealers. Try Olathe Toyota in KS.
    Topanga Taco and faawrenchbndr like this.
  6. May 8, 2023 at 7:57 PM
    chuymoreno
    chuymoreno Well-Known Member
    El Paso, Texas
    Tacoma SR5
    Did you end up getting the ball joints from that website?
  7. May 9, 2023 at 9:18 AM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Fyi in my honest experience oem ball joints are the best you can get
