3rd Gen tacoma m/t can't spin tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Zachbleau, Aug 31, 2020.
  1. Aug 31, 2020 at 5:03 PM
    Zachbleau
    Zachbleau [OP] Member
    Zach
    2017 Toyota Tacoma TRD Sport
    I have a 2017 tacoma with a manual transmission and everytime i turn the traction control all the way off and drop the clutch the tires never spin. Even when the ground is wet. Havent tried it in snow yet but im sure it will work in snow. But why not on regular pavement?
    tacomainthesun likes this.
  2. Aug 31, 2020 at 5:06 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    ^Please delete and re-post Friday.
  3. Aug 31, 2020 at 5:07 PM
    High_Desert_Rex
    High_Desert_Rex Well-Known Member
    Adam
    SLC and Kanab, UT
    Cement ‘21 TRDORDCSB w/GFC - Red ‘19 TRDORDCSB6MT w/GFC (rip)
    GoFastCampers Platform Camper
    Because it's not powerful enough and not meant to do that? o_O It's not a muscle car, not sure what you expected buying a MT pickup truck. Great way to wear out your clutch/drivetrain. :facepalm::facepalm:
  4. Aug 31, 2020 at 5:08 PM
    You Suck I Suck More
    You Suck I Suck More Well-Known Member
    Meatloaf
    North Florida
    2017 Super White DCSB TRD OR
    Your parents' favorite Airman
    Put some KY on your tires
  5. Aug 31, 2020 at 5:08 PM
    waltuo
    waltuo Well-Known Member
    Toyotas
    “Regular” pavement has anti tire spinning properties.
    Twize, BSFord, Rockefelluh and 5 others like this.
  6. Aug 31, 2020 at 5:09 PM
    jmneill
    SE
    And all three pedals...
  7. Aug 31, 2020 at 5:10 PM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    It's cause you're granny shifting, not double clutching like you should.
  8. Aug 31, 2020 at 5:18 PM
    Karl-2
    Karl-2 Member
    Reno, NV
    2019 Cavalry Blue DCSB TRDOR M/T
    Bedside ARB Twin OBA
    I had a problem with this once trying to do donuts in the snow. Turns out if you only press the button for traction control, it doesn't really turn off. Glazed my clutch pretty good that day...learned the hard way..
    You have to press and hold the button to get it to turn off. Give that a try and it might work. Not sure the truck has the power to spin the tires on dry pavement, but it should be able to do it on wet pavement with the traction control all the way off.
    Edit: just saw that you mentioned you turned it all the way off..idk what to tell ya bud:notsure:
    Gunshot-6A likes this.
  9. Aug 31, 2020 at 5:21 PM
    Shellshock
    Iowa
    You need tuned. After doing so, it’s possible to cut them loose.
    where are you located? There may be someone near by that can hook you up.
    tonered and G8R_Taco like this.
  10. Aug 31, 2020 at 5:21 PM
    wayne0
    wayne0 Well-Known Member
    Why??
    69 Jim likes this.
  11. Aug 31, 2020 at 5:22 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Dunno, but I managed to drift around a corner last week
    pinochle and Myles G like this.
  12. Aug 31, 2020 at 5:23 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    A6C0A9BD-A79C-49FE-B84B-03C4C8855F7B.jpg Because you need this sticker on the sun visor
  13. Aug 31, 2020 at 5:25 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    FIFY
  14. Aug 31, 2020 at 5:26 PM
    Xer0 SiN
    Xer0 SiN Well-Known Member
    Hilo, HI
    19 TRD SPORT TACOMA / 21 LIMITED RAV4
    this and that...
    its because the horrendous drive by wire design. get a sprintbooster or something equivalent that eliminates the throttle gating and lag. if you want to spin the tires, youll do so easily. you dont even need to turn off trac to do it.
    MOC221_ likes this.
  15. Aug 31, 2020 at 5:27 PM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    You need to use 91 octane.
    b_r_o likes this.
  16. Aug 31, 2020 at 5:30 PM
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    The 4-banger can break the tires loose. Must be that V6 Atkinson Diet. :notsure:
  17. Aug 31, 2020 at 5:39 PM
    CrustyComa
    CrustyComa Well-Known Member
    Michigan
    2020 SR SX TRD Sport love child
    Get a K&N filter and for sure you will be able to roast 'em through 6th.
  18. Aug 31, 2020 at 5:43 PM
    Biscuits
    Throw in a Flowmaster and some Amsoil and you'll roast 'em through 7th.
    420taco, heybronicetacoma and WarrenG like this.
  19. Aug 31, 2020 at 5:46 PM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    must be your pavement, today it rained a bit in Texas, we have roads covered with oil, and they get very slippery when wet, I even slipped in 2nd gear at 3000 RPM today, no bed load
    tonered likes this.
  20. Aug 31, 2020 at 5:52 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    My ranger spun the tires no problem. It had mechanical LSD. I only done hard 1-2 shift in my taco, does a little burn out. I have not dumped the clutch yet on my taco. Still a virgin i guess.
    Lucifer1, drewmac270 and shakerhood like this.
