3rd Gen Tacoma Power Folding Mirrors
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by KTJO 4x4, Mar 2, 2019.
Thread Status:
Not open for further replies.
  1. Dec 25, 2019 at 1:01 PM
    #821
    erok81
    erok81 Well-Known Member
    Imposter
    Is there an install manual anywhere for the diy kit? I checked the first page and skimmed the thread but didn’t see anything.
    KTJO 4x4[OP] likes this.
  2. Dec 25, 2019 at 1:02 PM
    #822
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    There should have been a PDF sent to you.
  3. Dec 25, 2019 at 1:26 PM
    #823
    AllenOne1
    AllenOne1 Well-Known Member
    Allen
    Nashville, TN
    2013 TRD Sport / 2018 TRD Off Road
    Gen2: Access cab platform, Gen3: MESO Puddle Lights, KTJO Power Folding Mirrors,
    See if this helps. There is an install video that helps a lot too.
  4. Dec 25, 2019 at 1:29 PM
    #824
    AllenOne1
    Allen
    Nashville, TN
  5. Dec 25, 2019 at 1:48 PM
    #825
    erok81
    Imposter
    :facepalm:
    Yep! I remembered seeing this but thought it was via pm. Checked pm’s and it wasn’t there. So I figured I was crazy. I wasn’t...it was in my email.
    Thanks!
    I’ll check it. I did watch the one on the first page but saw it was for the bolt ones so I didn’t bother with it too much.
    Rainoffire[QUOTED] likes this.
  6. Dec 25, 2019 at 6:32 PM
    #826
    erok81
    Imposter
    Side note. Are there any good tips for pulling that mirror cover off? I just did the driver side and pretty much broke every tab (I really hope they sell these otherwise I’m starting over on a new mirror tomorrow). :rofl:
  7. Dec 25, 2019 at 8:27 PM
    #827
    Rainoffire
    I just pulled from the top, move to the outer corner, then it just pops off.
    If I recall correctly, there are two shallow tabs on top, one tab on the outer corner and two deep tabs to the inner side of the mirror.
    erok81[QUOTED] likes this.
  8. Dec 25, 2019 at 9:21 PM
    #828
    erok81
    Imposter
    I think I’ll be able to get the other off. I hope at least. This side is getting glued back together.
    Also... Did anyone have trouble getting the mirror adjustment thing to line up with that aluminum plate? I can get one hole lined up no matter which way I rotate it. I don’t want to drill new holes but I think I might have to.
    Edit: after installing the adjustment thing the wrong way 3 times I got it and just drilled a new hole. All good now!
  9. Dec 25, 2019 at 10:25 PM
    #829
    Rainoffire
    It is kind of a sacrificial part, as it is not completely necessary to have it for the assembly to work.
    So drill away!
  10. Dec 25, 2019 at 11:34 PM
    #830
    erok81
    Imposter
    I saw that in the notes.
    What’s it even for then? I’d love to just leave it out as I wasn’t a fan of those sharp edges on the wires. I taped them but I’d happily leave that thing off the other side.
    I got the driver side back on tonight! Only took 4 hours or so. Still need to do the wiring. I do everything diy but this one has me wishing I’d just have paid for the ones already done.
    Oh and ten bucks says I forgot something in there!:rofl:
  11. Dec 26, 2019 at 6:46 AM
    #831
    KTJO 4x4
    KTJO 4x4 [OP] Well-Known Member
    Katie
    Oregon
    2017 TRD OFF-ROAD 4x4 DCSB BARCELONA RED
    Nitro 4.88 Gears OVTune 1.05 91Oct DirtyDeeds Exhaust
    Check your email
  12. Dec 26, 2019 at 6:53 AM
    #832
    KTJO 4x4
    Katie
    Oregon
    The aluminum plate should match up exactly with all of the holes. There should be 4 for the mirror adjuster and four for the connection plate. I include I think now 1 extra screw to match the OEM silver ones because you will be one shy after you take all of you mirror apart and start putting it back together. Then you will have all brand new black ones to use for the motor and then for the two spots on the outside that secure the bottom panel piece to the main mirror housing. There are 5 of those per mirror that is needed. 3 for the mirror folding motor and 2 that will secure the bottom panel piece to the main mirror housing that comes around the turn signal.
  13. Dec 26, 2019 at 6:56 AM
    #833
    KTJO 4x4
    Katie
    Oregon
    You can always check the step by step guide that I emailed you and see how I did it but the easiest way so you don’t break the tabs is to reach from the back and just open up the tabs with like a flathead or something so you can pull the tab through. After you do that, the mirror will come right off.
  14. Dec 26, 2019 at 8:03 AM
    #834
    AllenOne1
    Allen
    Nashville, TN
    The first mirror is the time consuming one the second one goes a lot faster. I pulled them both and worked on them one at a time so I could always reference the other mirror. Just take your time and figure it out as you go. You can use small wire ties to secure the wires and keep them away from the sharp edges, make it look real neat and secure in there.
  15. Dec 26, 2019 at 3:09 PM
    #835
    erok81
    Imposter
    Okay me again...:rofl:
    I watched the video but can’t figure out out a few things.
    1. The video says you’ll have four loose wires but he also says two loose wires. I’m assuming this is from the updated harness and there is really only two loose wires?
    2. The adapter harness with the biggest connectors. Also has the white/gray wire. Where does this go? I’ve pulled my entire door apart and I don’t have this connector anywhere.
  16. Dec 26, 2019 at 3:15 PM
    #836
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    It's been a while since I did mine. But, I still have a ton of pictures. Can you show which harness/wire you are referring too?
  17. Dec 26, 2019 at 3:21 PM
    #837
    erok81
    Imposter
    Here is the one I can’t figure out.
    Then do I put the two loose wires into this connector? This doesn’t match the instructions either from what I can tell. Included a pic where it plugs in too.
    edit: I found the other two loose wires. So I have four of those now.
  18. Dec 26, 2019 at 3:31 PM
    #838
    fatboyfirebass
    I had one of the original kits that where that wire was loose and had to be tapped in to the oem harness. BUT, I think this is where the other end goes. Can you confirm, @KTJO 4x4?
  19. Dec 26, 2019 at 3:34 PM
    #839
    fatboyfirebass
    please double check the instructions and/or wait for OP to reply, before installing in the harness. If it is not right and you have to get that wire back out.. well, it's not easy or quick.
    I would hate to have you wire it up wrong because of me.
  20. Dec 26, 2019 at 3:34 PM
    #840
    erok81
    Imposter
    That pic looks like the on that I’m assuming is for the windows/locks. But mine has way less wires than yours.
    Also any idea on that big connector?
Thread Status:
