3rd gen Tacoma random hard start
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Yotasonly, Jul 23, 2025.
  1. Jul 23, 2025 at 7:48 PM
    Yotasonly
    Yotasonly [OP] Member
    Reece
    Been having an issue for a few months now with a random hard start. Truck is a 2020 4x4 sport with 67,xxx miles. Truck will just crank and take a couple tries before it will start. No check engine light and whenever I get it started the truck smells like gas. Been to the dealer 3 times now and each time they turn me away because they “couldn’t replicate the issue” and there are no codes and no engine light. Leaning towards the fuel pump but want to hear if anyone had any similar issues? Biggest problem is it’s super random and sometimes will go weeks without skipping a beat but when it decides to act up, im stuck in a parking lot cranking over for a few minutes
  2. Jul 23, 2025 at 7:53 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    Start taking a video everytime you start your truck, when you get a hard start recorded, show it to the dealer.
    Daulll and shakerhood like this.
  3. Jul 23, 2025 at 8:37 PM
    Yotasonly
    Reece
    This is the video I gave the dealership when I dropped off the truck. They still couldn’t do anything about it‍♂️
  4. Jul 23, 2025 at 8:39 PM
    Yotasonly
    Reece
    Sorry having trouble attaching the video
  5. Jul 23, 2025 at 8:40 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Can’t say anything definitive based on only descriptions, but sounds similar to a failing crankshaft position sensor. Although usually they don’t keep limping along for very long, so that your issues are so spread out makes it more questionable.
  6. Jul 24, 2025 at 1:21 AM
    Kabogski
    Kabogski Sport Rally Five
    Bote
    Los Angeles
    17' MGM - Anim na Piston.. Sport Rally Five
    Hi tuck Exhaust FalkenWildPeaks Blackout Badge
    Check Oxygen sensor and cranckshaft position sensor.
  7. Jul 24, 2025 at 4:40 AM
    joebwan
    joebwan Active Member
    2017 TRD OR White & 2017 TRD Pro Cement
    There was a fuel pump recall for your year which I also received and in the letter it says smell of gas is a sign of the failure. Your dealer should know this obviously, but you should get yours changed.
    xBloodxLinex likes this.
  8. Jul 24, 2025 at 4:23 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Can you elaborate on “will just crank and take a couple tries before it will start”?
  9. Jul 24, 2025 at 5:06 PM
    Yotasonly
    Reece
    It’s a push start so I’ll push the button to start the truck and I’ll let it crank for about 4-5 seconds before I push the button again to cancel. After about three tries the truck will start and run rough for a few second filling the cab with a gasoline smell. Then it will clear out and the truck will run fine. Forgot to say the truck runs normally and only has issues with starting
  10. Jul 24, 2025 at 8:41 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Here is info on the fuel pump recall. Your 2020 is covered for 10 years regardless of mileage.
    https://static.nhtsa.gov/odi/tsbs/2023/MC-10236191-9999.pdf
  11. Jul 24, 2025 at 10:21 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    What happens if you wait longer before push the button to start?
    Perhaps pump does not pressurize the line to a specific pressure. Easy to see with a scanner or obd2 apps
    Startup uses both injection modes.
    Chew likes this.
  12. Jul 25, 2025 at 5:25 AM
    gudujarlson
    Minnesota
    A gasoline smell suggests to me a rich fuel-air mixture.
  13. Jul 25, 2025 at 4:14 PM
    Phlogiston
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    Might wanna remove the Carburetor and make sure the floats aren't stuck.
  14. Jul 25, 2025 at 5:47 PM
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    Tacoma trucks never did have carburetors.:confused:
  15. Jul 25, 2025 at 6:04 PM
    gudujarlson
    Minnesota
  16. Jul 25, 2025 at 6:30 PM
    Pnw_tnerb
    Pnw_tnerb Active Member
    2021 sc Tacoma
    How old is the battery. I had a truck that would do this. Crank and crank and crank. Eventually it would start. The battery had the cranking amps but didn’t have the power to run the truck. Check the battery voltage while cranking. If it drops below 12 time for a new batt.
    Tocamo likes this.
  17. Jul 25, 2025 at 6:35 PM
    gudujarlson
    Minnesota
    The battery only starts the engine. From then on, the alternator feeds the engine electricity. Once the engine is started, you could remove the battery and drive off.
    Other examples of this are dirt bikes with kick starters, lawn mowers with pull starters, and manual transmission automobiles being push started.
    Phlogiston likes this.
  18. Jul 25, 2025 at 6:46 PM
    Phlogiston
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    yeah, if the battery is strong enough to turn the engine over then fuel or spark would be the most likely culprits if it won't start.
  19. Jul 25, 2025 at 7:41 PM
    Vlady
    Issy, WA
    Mine used to drop below 11 and still start w/o hesitation.
  20. Jul 25, 2025 at 9:01 PM
    STEELeR43
    Hawaii
    gudujarlson[QUOTED] likes this.
