3rd Gen Tacoma Spark Plug Replacement.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gsingh, Jun 17, 2018.
  1. Jun 26, 2022 at 1:46 PM
    #301
    Nitesmoke
    Nitesmoke Member
    Kennesaw, GA
    2017 Tacoma TRD OR DCSB 4x4 MT
    Stock
    Anyone know what else needs to be disconnected on the drivers side for a manual transmission? There’s some other things on that side with hard lines that are a challenge to get around. I was able to do it, but it was a lot harder than I expected.
  2. Jun 26, 2022 at 3:12 PM
    #302
    ajmogen
    ajmogen Well-Known Member
    Aaron
    Wisconsin
    OR MT TACO T4R YARIS MT Corolla Hatchback MT
    You don't have to disconnect anything else. All the lines will flex out of the way
  3. Jun 26, 2022 at 6:06 PM
    #303
    Nitesmoke
    Nitesmoke Member
    Kennesaw, GA
    Stock
    I know you don’t have to. Like I said, I was able to complete the job. I was curious if there’s an easier way by disconnecting other things so that I don’t beat myself up to get to those plugs
  4. Jun 26, 2022 at 7:41 PM
    #304
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I just replaced my plugs this weekend at 51K miles. I was going to take pictures, but my old plugs looked identical to the plugs in post #284. I found this video helpful at tackling the drivers side. BTW, I did the drivers side first because I wanted finish with the easy passenger side. Also, all my old plugs were torqued properly from the factory.
    https://www.youtube.com/watch?v=fNyED_hSSKQ
  5. Jul 10, 2022 at 8:36 AM
    #305
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    Did my plugs at 60k last night. Went pretty smooth. Biggest pain for me was not having long enough 3/8 extensions but I did it with a combo of 3/8 and 1/2. Got my denso for AZ for 10.xx a piece. Not bad. Thanks for the write up.
    Junkhead and mquibble like this.
  6. Aug 12, 2022 at 4:51 PM
    #306
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
  7. Aug 12, 2022 at 6:19 PM
    #307
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    :cheers:
  8. Aug 18, 2022 at 6:42 AM
    #308
    M_McFly
    M_McFly Member
    2022 Black TRD Off Road
    Awesome write up and thank you! I will definitely be saving this for later.
  9. Aug 18, 2022 at 7:52 PM
    #309
    joebwan
    joebwan Active Member
    2017 TRD OR White & 2017 TRD Pro Cement
    Getting ready to change my plugs and just read through all of this, thanks all. And @tonered I remember you from that Ducati forum, I have an ST2!
    tonered likes this.
  10. Aug 18, 2022 at 7:55 PM
    #310
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yeah! Love the STs. Getting long in the tooth, but I still smile on every ride.
    :bikewheelie:
    joebwan[QUOTED] likes this.
  11. Aug 27, 2022 at 2:07 PM
    #311
    ccotner112
    ccotner112 Well-Known Member
    Saint Louis Missouri
    2018 Tacoma TRD Sport
    17' TRD rims/BFG Ko2, OEM Roof Rack, TRD Pro Grill, Locker down console , Snugtop Rebel, lots MESO mods
    Nice write up, knocked mine out this afternoon. 75K looked like the ones posted.
  12. Sep 10, 2022 at 11:52 AM
    #312
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    Thanks for this write up. Just did my plugs at 75k.
    Wish the drivers side was a little easier. I don’t remember my 2nd gen being as difficult.
  13. Sep 27, 2022 at 11:33 AM
    #313
    DonM77
    DonM77 Well-Known Member
    Don
    I'm changing my plugs out now. The problem I'm having is actually removing the plugs feom the each slot particular the back. Plug doesn't want to stay in socket just sits there. Plug is unthreaded.
  14. Sep 27, 2022 at 11:40 AM
    #314
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Use a telescoping magnet to remove and to gently place them in the bores.
  15. Oct 25, 2022 at 7:26 PM
    #315
    Halibut
    Halibut Well-Known Member
    Alaska
    18 OR SB MT
    Exactly what I did. Changed mine today at 54k, and mine were in pretty rough shape. I had a slightly but noticeable rough idle, and it's night and day after changing. Much smoother. Anyway, not sure if it's where I live or the various tunes I've used, fuel, etc. Just some info for people who are on the fence about needing to do it. Took me about 1.5hrs
  16. Oct 25, 2022 at 7:35 PM
    #316
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Good stuff!
  17. Nov 18, 2022 at 12:49 PM
    #317
    rick carpenter
    rick carpenter Well-Known Member
    Rick
    Huntsville, East Texas
    2019 SR5 2wd v6 DCLB for the win!
    Reading through this thread, 18" seems to be the length of spark plug socket plus extension needed. I have a GearWrench 6" flexy spark plug socket so I need to get a single 12" extension, correct? I wish I could get a pin-lock extension but the GW socket is only ball-detent, so I need a collared-lock extension. Any recommendations on which one to get?
  18. Nov 18, 2022 at 1:33 PM
    #318
    Speedbird
    Speedbird Well-Known Member
    Fort Couch
    2017 TRD-OR
    @rick carpenter : I would not knock myself out for a locking extension that gets only periodic use... I used gorilla tape to keep the extensions from pulling apart and a $0.30 length of vinyl tubing from the hardware store to help lower the new plugs in (Without them crashing down and bending the electrode) and to get the threads started right.
    Next plug change (Any vehicle), I will be getting a more modern spark plug socket, the kind with the magnet versus foam rubber part that holds the plug in place.
    rick carpenter likes this.
  19. Dec 3, 2022 at 3:47 PM
    #319
    smallfrye
    smallfrye Well-Known Member
    Stock
    Thanks for the write-up going to replace the plugs on my truck here in the next few days.
    Two service visits ago the dealer (yes I go there :p) said I needed to change the plugs since I was at 62,xxx miles (denied doing it since they wanted close to $600 to change them :eek:) and the last service visit at a different dealership (I moved) said I didn't need to change them till 120,xxx miles.
  20. Dec 5, 2022 at 8:17 PM
    #320
    smallfrye
    Stock
    Got the spark plugs changed out tonight passenger side took about 40 minutes and the drivers side about 1.5 hours trying to figure what to disconnect and move around to the get the coil packs out. Plugs looked pretty good overall probably could've gone longer with them.
    shakerhood and Junkhead like this.
