3rd Gen Tacoma Spark Plug Replacement.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gsingh, Jun 17, 2018.
  1. Jul 27, 2019 at 10:15 AM
    #81
    Hstone556
    Hstone556 Ain’ters gonna ain’t
    Hunter
    Austin
    2019 Ram 2500 Laramie
    Raceline 17" Gauge's 37x12.50 Toyo's RT, Carli King 2.5s
    Yes, parts and labor. They have always been pretty affordable at my local dealership.
    DVS1[QUOTED] likes this.
  2. Jul 27, 2019 at 2:13 PM
    #82
    DVS1
    DVS1 Well-Known Member
    Ray
    Tampa, FL
    18 4Runner TRD Off Road
    Fuzzy dice
    I'll have to check with other dealerships, for quotes. When I picked up my truck I had asked the service advisor more into detail why it was so expensive. Explain that they had to remove hoses and drain coolant lines.
  3. Jul 27, 2019 at 2:59 PM
    #83
    Hstone556
    Hunter
    Austin
    That’s crazy, and a first hearing that! I’d definitely check around.
  4. Nov 14, 2019 at 9:53 AM
    #84
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Holy crap! My 2nd gen plugs were only 2.75/each
  5. Dec 15, 2019 at 3:13 PM
    #85
    SqFt
    SqFt Well-Known Member
    2016 Tacoma TRD Sport
    Iridiums are pricey. I found the best deal at Rockauto for $11.55 (15 Dec 2019).
    gilligoon likes this.
  6. Apr 6, 2020 at 1:28 PM
    #86
    littlefish
    littlefish Buzz, your girlfriend...
    Hudson Valley NY
    2016 TRD Off-Road DCSB
    The one who dies with the most stuff wins.
    So I changed my plugs today following this writeup. One thing I would add is that for the two brackets on the driver's side, the bottom bolts are easiest to access from the wheel well. Tried for a while from up top before finding out you can access them from below.
  7. Apr 11, 2020 at 2:27 PM
    #87
    JimTheLegend
    JimTheLegend Member
    Jim
    2016 TRD Off-Road 4x4 DCSB
    This is what I came to find. Did you need to jack up the car or remove the wheel? Or could you access it normally?
  8. Apr 11, 2020 at 2:50 PM
    #88
    littlefish
    Hudson Valley NY
    No need for either, was able to access it normally.
    JimTheLegend[QUOTED] likes this.
  9. May 7, 2020 at 4:16 PM
    #89
    seawolf68
    seawolf68 New Member
    Chuck
    2016 Blue Tacoma
    None yet
    How did you get to the bottom bolts on the bars? I can't get my hands down there and have enough room to work the ratchet
  10. May 7, 2020 at 5:17 PM
    #90
    littlefish
    Hudson Valley NY
    Through the wheel well. A 12” extension and a universal joint.
  11. May 7, 2020 at 5:45 PM
    #91
    seawolf68
    Chuck
    2016 Blue Tacoma
    None yet
    That's the route I went but busted my knuckles due to using the short socket. Don't have a universal joint.
    Don't have to do that for a while thank goodness.
    Thanks for the reply.
  12. May 12, 2020 at 2:31 PM
    #92
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    Just did all (6) of my plugs for my 60,000 mile service on my 2016 TRDOR.
    I used this write-up as a guide (thanks for putting this together OP), but decided to complete the task without removing any components. Color me lazy I suppose.
    You can replace all (6) plugs without removing the airbox or the brackets on the drivers side. I had to disconnect (2) plugs, (2) hoses (one required zero tools), and move the drivers side rear insulation a bit.
    If anyone is interested in doing this work without removing any major components let me know and I may attempt to film the work to share with the community.
  13. May 21, 2020 at 6:33 PM
    #93
    MGMSangTaco
    MGMSangTaco Colorado Toyota Tuning
    Denver, CO
    2017 TRD OR MGM DCLB
    I'd definitely be interested in a video of this. Just hit 60k myself
    Tommyb08 and over60 like this.
  14. May 21, 2020 at 7:17 PM
    #94
    hiroslammer
    hiroslammer Well-Known Member
    Carlsbad,CA
    2016 OR 4x4
    I changed the plugs myself using this write-up as a guide, took about an hour and was fairly straightforward.
    MGMSangTaco likes this.
  15. May 22, 2020 at 8:23 AM
    #95
    MR E30
    Michael
    Alright, I have received an adequate number of likes to give it a shot.
    Let me figure out when I can pull the truck back in the garage. Also have to figure out how to film it well enough as well.
    Alper2nd, trabo, 44-16 Taco and 7 others like this.
  16. May 22, 2020 at 8:25 AM
    #96
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    what else can I get you to do for likes
    Malvolio, usmc2msu, trktwo and 6 others like this.
  17. May 22, 2020 at 8:46 AM
    #97
    MGMSangTaco
    Denver, CO
    Hahaha
    Do you have a go-pro? If so head strap would be amazing
  18. May 22, 2020 at 9:00 AM
    #98
    MR E30
    Michael
    Bwahaha
    #pmsent
  19. Jun 3, 2020 at 11:48 AM
    #99
    MGMSangTaco
    Denver, CO
    Any update? Sorry don't mean to pester but a video would be huge and I have a 2,000 mile trip coming up.
    over60 likes this.
  20. Jun 3, 2020 at 1:34 PM
    #100
    TRok
    TRok Well-Known Member
    Texas
    2022 Army Green TRD Sport 4x4
    I was able to accomplish this as well without having to remove the air box and brackets. Granted, you need to have extensions and universal joints to make life easier, but most Tacoma owners do because they like to accessorize. It’s not difficult at all. I’ve done Hemi motors and those are buried against the firewall.
