3rd gen tacoma squeeze when shifting into reverse
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kgbrev, Jan 1, 2024.
  1. Jan 1, 2024 at 12:08 PM
    Kgbrev
    Kgbrev [OP] Well-Known Member
    2020trdoffroad
    Diamondback SD cover
    Hey guys when my truck is stationary, I get a squeak only when shifting into reverse. I also just changed the transmission fluid. I added about a quart more and let it drain to a Trickle. I used the temp check mode on the truck to indicate when it's safe to do it. And I used a scan gauge. The was 96 degrees when I checked it. Any idea what is causing the sqeauk in reverse?
  2. Jan 1, 2024 at 12:19 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    If it’s more of a creak, my guess is lack of lube on the leaf springs. You have to give much more information if you want more grab a wild guess.
    Chew likes this.
