3rd gen tacoma stalling
Discussion in '3rd Gen. Tacomas (2016-2023)' started by javis11x, Jan 23, 2024.
  1. Jan 23, 2024 at 7:14 PM
    javis11x
    javis11x [OP] Member
    Javier
    2013 Toyota Tacoma single cab 4x4
    Can someone please help, my 2016 tacoma limited stalls. Has anyone experienced this problem?
  2. Jan 23, 2024 at 7:17 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Did you press the gas pedal and the brake pedal at the same time?
  3. Jan 23, 2024 at 7:19 PM
    javis11x
    Javier
    No, I wasn’t pressing anything it was idling. Also the abs code light up when it started stalling, it wasn’t on before
  4. Jan 23, 2024 at 7:21 PM
    Tacomike18
    J
    Step one is to scan the codes and erase to see if it persists. If after it still won’t run then check the basic battery-maf sensor-fuel pressure-etc.
  5. Jan 23, 2024 at 7:21 PM
    atmullis
    atmullis Member
    Alex
    Denver
    2015 DCLB
    What kind of LED stuff do you have installed? Headlights, taillights, interior lights etc. I work for Toyota and you'd be surprised how much we see interference from LED's. Warning lights, stalling, won't crank etc.
    Chew likes this.
  6. Jan 23, 2024 at 7:24 PM
    javis11x
    Javier
    I don’t have any LED installed. Headlights and taillights are oem
  7. Jan 23, 2024 at 7:28 PM
    javis11x
    Javier
    its also taking longer to start
  8. Jan 23, 2024 at 7:40 PM
    Tacomike18
    J
    Check for crank sensor code
    shakerhood likes this.
  9. Jan 23, 2024 at 7:41 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Rodent activity where you park your truck?
  10. Jan 23, 2024 at 7:51 PM
    javis11x
    Javier
    Code P0116 shows on my scanner is a basic scanner
  11. Jan 23, 2024 at 7:52 PM
    javis11x
    Javier
    It was outside yesterday. It was raining
  12. Jan 23, 2024 at 8:02 PM
    toyotahenry
    toyotahenry N/A
    Houston, Texas
    2021 TRD OFF ROAD 4X4 ARMY GREEN
    alternator.. maybe
  13. Jan 23, 2024 at 8:08 PM
    ppat4
    ppat4 Well-Known Member
    Paul
    Kelowna, BC
    2016 Tacoma TRD Off-Road Access Cab
    Just added toolbox and roof-rack to haul my fishing boat 100's of miles into the backwoods every week. Goodrich K02s, Bilstein 5100 front and back, no lift.
    May not be related, but my 2016 TRD OR would fluctuate idle between 600-1000rpm. Got worse over months.
    I cleaned, then put in new MAF. New plugs, new air filter, new PCV. All improved performance, but none fixed the crazy idle. Note, the idle had nothing to do with AC or defrost settings. It would range from 600-1000 for a full minute while stopped.
    Cleaned the throttle body. Instantly fixed the issue and it has not returned after months. Idle is so steady now that it is actually stange to see it never fluctuate.
    So, I suspect it has nothing to do with your issue, but if you have never cleaned the throttle body on a 2016 you are way overdue. A 15 minute easy DIY.
    Canadian Caber likes this.
  14. Jan 23, 2024 at 8:19 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    Your high beams are on. That's not very nice to fellow road users.
    Looks like symptoms of low voltage. Either battery, connection, or alternator
    Chew and javis11x[QUOTED][OP] like this.
  15. Jan 23, 2024 at 8:21 PM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    Definitely doesn’t look like a bad battery. When batteries die out, things flicker and shut down. This looks electrical, but definitely not battery.
    javis11x[OP] likes this.
