Steering rack bushing replacements
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 3rdGenTurd, Sep 2, 2020.
  1. Sep 2, 2020 at 11:40 AM
    3rdGenTurd
    3rdGenTurd [OP] Member
    Really hoping someone can help. The bushings on my steering rack are shot on my 3rd gen tacoma. I cannot find replacements anywhere. Toyota wants to replace the whole rack which I feel is overkill and super $$$. Can anyone suggest bushings that would work?
    Thanks!
  2. Sep 2, 2020 at 11:55 AM
    3rdGenTurd
    No im over 90k miles. Bought this thing heavily used for what I thought was a good price. Dont have pics of the bushings but I have an issue up front where something is loose. When someone turns my wheel back and forth I can see the whole rack moving.
  3. Sep 2, 2020 at 11:58 AM
    3rdGenTurd
    It seems that the 2nd gen may use the same bushings but Im having trouble confirming that. Those are readily available aftermarket.
  4. Sep 2, 2020 at 2:54 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Interesting, I'm sure as the miles amass, others will be interested. For now, you just may have to be the front-runner.
  5. Sep 2, 2020 at 2:58 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Call energy suspension and see if theirs fit
  6. Sep 2, 2020 at 2:59 PM
    3rdGenTurd
    From what Im seeing online it seems like something may have changed in 2014. I dont see bushings for tacoma steering racks beyond 2013. The toyota parts diagram states "this part is not supplied as an individual part because it is hard to assemble/disassemble due to the structure"
    It does not say "impossible" though!
  7. Sep 2, 2020 at 3:00 PM
    3rdGenTurd
    Thanks Ill check them out
  8. Sep 2, 2020 at 3:08 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Yeah, it's probably hard while warranty exists, but us common folk will probably find a way to not only avoid costs of replacing a whole rack, but also keeping that OEM quality if possible. Fixes like this will happen more often as folks drive out from under the protections of warranty.
  9. Sep 2, 2020 at 3:11 PM
    3rdGenTurd
    Agreed. I am not spending the 2k they are quoting to replace it. Im not really even willing to spend the $500 for a whole rack to replace myself when bushings are so damn cheap.
    FYI they bolted it in in a way that you have to cut the bolts or lift the engine. I feel they are quoting me labor to lift the engine. You can place new bolts in upside down.
    synaps3 and Chew[QUOTED] like this.
  10. Sep 2, 2020 at 3:13 PM
    hoarder23
    Shay
    NJ
    Scratches
    Is it that different from a 2nd gen? You can change a 2nd gen rack without pulling an engine
  11. Sep 2, 2020 at 3:14 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    We need that infomercial guy that builds boats out plexiglass, to make a bushing in a tube :rofl:
  12. Sep 2, 2020 at 3:17 PM
    3rdGenTurd
    Im not sure to be honest. I do know the 2nd gen and 3rd gen racks look identical on the parts diagrams. The 3rd gen bolts are placed top down and cant be removed all the way b/c of that therefore cut the heads and drop them out.
    dude thats a million dollar idea!
    Chew[QUOTED] likes this.
  13. Sep 2, 2020 at 3:25 PM
    hoarder23
    Shay
    NJ
    Scratches
    Do you live in an area with multiple Toyota dealers? If so ask for a written estimate for steering rack replacement from another.
  14. Sep 2, 2020 at 3:28 PM
    3rdGenTurd
    Im near SLC UT. Called everyone around me and a couple independent shops. Labor prices are stupid.
  15. Sep 2, 2020 at 5:54 PM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    The driver's side bolt will come out... Unbolt the AC compressor and slide it to the side on the studs.
    Grossomotto likes this.
  16. Jun 20, 2022 at 11:59 AM
    Tacoma_TM22
    Tacoma_TM22 Member
    Hawaii
    2018 tacoma sport
    6 inch pro comp lift on 33s
    Hate to revive a dead thread..
    I can confirm you can use the 2nd gen polyurethane bushings with the 3rd gen rack..
    The rack is the same design for the 2nd gen Tacoma..
    you will need too cut the metal bushings in order to press them out..
    Will post pics if anyone is interested..
  17. Jun 20, 2022 at 3:51 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Awesome, thanks for sharing! I’m sure it’ll help someone out of major repair.
  18. Aug 17, 2022 at 3:23 PM
    Mshort03
    Mshort03 Well-Known Member
    Martin
    Holly springs nc
    2020 TRD off road tacoma
    I'm interested as I just ordered 2g bushings for my 2020. Rack bushing have pretty much left the chat
  19. Oct 26, 2022 at 5:14 PM
    horribleharp
    horribleharp Member
    2019 Silver Tacoma Off Road
    Sorry to join the party late but if you could post those pics, it would be greatly appreciated!
    Contemplating on attempting the rack bushing replacement myself.
    Thank you in advance!
    tneynop likes this.
  20. Oct 26, 2022 at 7:43 PM
    Mshort03
    Martin
    Holly springs nc
    I did the replacement recently. Its pretty straight forward.. The bushings that are in it have a metal sleeve that folds out to make it "clamped" on the rack (thats why they cant be bought seperate for 3rd gen cuz its "one piece")..just remove the bushing then the sleeve and you can insert the poly bushings. I did it with the rack in the truck still and the help of an air hammer. Rotate the rack forward and you can work the old bushings out. I never disconnected the outer tierods.. It also helps to cut the driver side bolt threads off that protrude Past the nut so that it's easier to get bolt out without lifting motor. Took me like 2 hours
    Stopmithering, drizzoh and Chax like this.
