3rd Gen Tacoma SwitchPro/Auxbeam Switch Panel
Discussion in 'Runnin 4 Tacos' started by runnin4tacos, Jun 10, 2022.
  1. Jun 10, 2022 at 11:46 AM
    runnin4tacos
    runnin4tacos [OP] Well-Known Member Vendor
    Tuan
    Denver, Colorado
    2017 Cement TRD Pro, 2024 TRD Off Road
    Hi guys,
    It has been a while since we made a post, but we are back on TW. We will be more active on TW starting today, and we are excited to share everything to come with you guys!
    In this thread, we are showing a new product for the 2016-2022 Toyota Tacoma. In the photo below, you will see a switch panel that we have in production. This panel will accept an Auxbeam or similar 8-button switch controller. It can also take the Switch Pro SP9100 with the adapter plate. The panel will also take five small style switches and/or the rear window switch in the bottom row. The rear window switch is on a 2017-2022 and is generally located on the left panel but sometimes under the climate controls. If your truck is equipped with the cab/bed light, it will be relocated to the right of the switch panel. This kit will include a cab/bed light replacement face so that the words are correctly oriented.
    The panel's material will be made of the same plastic like the factory panel and will also have the same texture. For those who have a manual transmission, we will have a small style "Clutch Start Cancel" button available. We made it a small style button to keep the buttons on the bottom row the same.
    This panel should be available at Runnin4Tacos.com in roughly a month. Let us know what you guys think!
  2. Aug 4, 2022 at 5:24 PM
    Kruze1971
    Kruze1971 New Member
    Dale
    2017 TRD Off Road Dbl Cab
    Very interested in this. I purchased a similar item from Etsy and was very disappointed in the quality.
  3. Jan 19, 2023 at 7:54 AM
    RI_Taco
    RI_Taco Member
    Bryce
    2019 Tacoma TRD Off-Road
    Body Armor 4x4 Hiline Bumper Cali Raised Ditch Lights
  4. Jan 19, 2023 at 10:55 AM
    Kruze1971
    Dale
    Out2gtcha and TacoPacific like this.
  5. Feb 15, 2024 at 11:12 AM
    Out2gtcha
    Out2gtcha Well-Known Member
    Brian
    Omaha, NE
    2020 Quicksand Off Road DCLB 4x4
    Just found this thread after deciding to invest in an AuxBeam 8 gang switch panel. I've been really wanting a new switch panel to replace the OEM one, in order to accommodate the new 8 gang switch set up.
    It seem most of the 8 gang panels available are on Etsy, and the 3D print lines are very noticable.
    I was really hoping for a much more OEM look, and this looks like it will definitely fit that bill much more effectively!
  6. May 5, 2024 at 7:42 AM
    Chuzzi1
    Chuzzi1 New Member
    ‘06 TRD OR
    Stock
    Any word on when these will be back in stock?
  7. Feb 10, 2025 at 7:16 PM
    pineapple_taco
    pineapple_taco Member
    James
    21 Taco TRD Sport
    400 watt inside cab AC
    +1 waiting for these to come back in stock.
    3 pedal Taco likes this.
