3RD Gen Tacoma Tid Bits
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SpeySquatch, May 31, 2020.
  1. May 31, 2020 at 4:53 PM
    SpeySquatch
    SpeySquatch [OP] Function over Form
    2016 TRD OR DCSB
    Post up facts with images that can only be related to the 3rd Gen Tacoma (2016-2020+). When you post, be clever and factual. Don’t make up some bs without proof. This thread is to share knowledge and be gentlemen. It should be simple enough to educate people on TW without too much explanation. Spread some knowledge while we wait out this COVID crud.
    I’ll start.
    What is this torque spec for?
    Oil pan bolt
    Xx_Evilvirus_xX and Skydvrr like this.
  2. May 31, 2020 at 4:57 PM
    tcjacado
    tcjacado Well-Known Member
  3. May 31, 2020 at 5:01 PM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
  4. May 31, 2020 at 5:20 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    3rd gen is 16-20 (sofar).
    fact checking your OP
  5. May 31, 2020 at 6:14 PM
    SpeySquatch
    2016 TRD OR DCSB
    Fixed. :cheers:
    Malvolio, tcBob and jmauvais[QUOTED] like this.
  6. May 31, 2020 at 6:14 PM
    SpeySquatch
    2016 TRD OR DCSB
  7. May 31, 2020 at 8:10 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Model Year 2017 had the most available Models with Manual Transmission.
  8. May 31, 2020 at 8:46 PM
    SpeySquatch
    2016 TRD OR DCSB
    Where’s your source Shaker? Image bro
    Malvolio likes this.
  9. May 31, 2020 at 9:12 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Gen 3’s are the only tacos that have an actual taco molded in!
    TRok, Malvolio, Fastbilly5 and 7 others like this.
  10. May 31, 2020 at 9:34 PM
    jmauvais
    NorCal
    ...stuff
    but where is it?
  11. May 31, 2020 at 9:38 PM
    Captqc
    Tigard, OR
    That’s the $64 question. Send me the money and I’ll tell all.:thumbsup:
  12. May 31, 2020 at 9:39 PM
    jmauvais
    NorCal
    ...stuff
    TRok, Shellshock, Auzea and 2 others like this.
  13. May 31, 2020 at 9:47 PM
    Captqc
    Tigard, OR
    :rofl:Okay okay, it’s behind the dash.
    jmauvais[QUOTED] likes this.
  14. Jun 1, 2020 at 1:21 AM
    TacoTheTaco
    TacoTheTaco Well-Known Member
    DC
    2018 TRD Sport 4x4 DBL Cab
    the first iteration of our engine type was used in a Prius. Explains a lot, lol
  15. Jun 1, 2020 at 2:44 AM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    An old article, not sure about the source, but looks accurate
    Internals of the 2GR-FKS engine are of superior quality. Block and heads are aluminum, of course. Both the crankshaft and connecting rods are forged. The cams are driven by a long-life chain rather than a belt, and the rocker arms ride on needle bearings. Iridium-tipped spark plugs are good for 60,000 miles, and have a deep threaded section, which allows thicker material in the head at that point, which in turn allows coolant passages to be routed closer to the combustion chambers. Externally, the exhaust manifolds and pipe are stainless steel.
    http://www.exploringoverland.com/overland-tech-travel/2015/8/20/the-new-tacomas-new-engine
  16. Jun 1, 2020 at 3:34 AM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    after I found mine (installing a speedo calibrator) I bought a T shirt with that logo on it :rolleyes:
    Malvolio, jmauvais, tonered and 2 others like this.
  17. Jun 1, 2020 at 6:36 AM
    andrewkissam
    andrewkissam Well-Known Member
    Dallas, Texas
    2017 Tacoma TRD Sport, DCSB, Silver Sky Metallic
    heritage grille, TRD beadlock wheels, TRD exhaust, TRD intake, rokblokz mudflaps, BFG KO2s 265/75r16, Toytec front spacer leveling kit, 2nd gen running boards, chin spoiler delete, MESO gasshole, Toyota bed mat, Toyota all weather floor mats, Tufskinz doorsill protectors, Diode Dynamics LED headlight conversion, LED reverse and plate lights, LED interior lights, Diode Dynamics 30" stealth light bar, TRD shift knob, TRD start button
    I think you misunderstood that article. Yeah the first iteration of the Atkinson cycle engine was used in the Prius, but as far as I'm aware the GR V6 family of engines was never used in the prius.
    Boghog1, boynoyce and SpeySquatch[OP] like this.
  18. Jun 2, 2020 at 3:59 AM
    TacoTheTaco
    DC
    I said “type” intentionally
    Also, according to the chief engineer of the Tacoma and Tundra, drum brakes are better for off-roading. Makes me wonder why the Tundra has had disc rears for a hot minute.
    SpeySquatch[OP] likes this.
  19. Jun 2, 2020 at 9:59 PM
    jmauvais
    NorCal
    ...stuff
    well that took zero effort haha
  20. Jun 2, 2020 at 11:43 PM
    Captqc
    Tigard, OR
    It was the “look” :quickdraw:
