3rd gen Tacoma tire question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BillBluesFan, Mar 13, 2020.
  1. Mar 13, 2020 at 8:05 PM
    BillBluesFan
    BillBluesFan [OP] Member
    2021 Red Tacoma SR5 Double Cab Short Bed V6 4wd
    I have a 2019 Tacoma SR double cab short bed V6 4wd. I like the look of the fat 16” tires but would like to eventually change the steel wheels to something better looking . My factory tire size is 245/75R16. I am looking at a set of take offs from a TRD Off Road that are 265/75R16. Same sidewall aspect ratio (75) so they will be a little taller as well as wider. Will these tires create any problems since they are taller and wider than the factory tires on my SR? Has anyone done what I am considering? Thanks.
    Coach_Cooke20 likes this.
  2. Mar 13, 2020 at 10:11 PM
    OregontoBajaCA
    OregontoBajaCA 2025 DC OR High Bread
    2025 OR DC iF Max
    As factory Off-Road tire size is 265/70-16.
    Changing your tire size to 265/75-16 is no problem.
    They’ll fit your truck just fine.
    Garyji likes this.
  3. Mar 13, 2020 at 10:27 PM
    Suspender
    Suspender Well-Known Member
    Colin
    IE, CA
    265/75-16 fits. It is as big as you can go without rubbing.
    Well, can also fit 255/85-16 without rubbing.
  4. Mar 13, 2020 at 10:36 PM
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Yay a tire thread!! Thought we might miss having one (or seven) this week!
    Superdave1.0, CrippledHo and Tullie D like this.
  5. Mar 13, 2020 at 10:51 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    I have 265/75/16 size in snow tires on stock 16” off road wheels. No rubbing or issues at all. Have OEM mudflats.
  6. Mar 14, 2020 at 8:52 AM
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
  7. Mar 14, 2020 at 3:55 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    But, will a 4” lift affect my use of 325x40xR12 tires? Will it rub when I’m stopped at a no left turn sign?
  8. Mar 14, 2020 at 4:02 PM
    CrippledHo
    CrippledHo I'm calling about your car's extended warranty
    Eric
    Biggest Little Dumpster
    2016 DCSB Diet Coke
    Dents and a rattle can
    shane100700 and Superdave1.0 like this.
  9. Mar 14, 2020 at 4:02 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Will not rub but will scrape your calipers. :thumbsup:
    shane100700 and CrippledHo like this.
  10. Mar 14, 2020 at 4:06 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    So you’re saying maybe to a 3” lift?
  11. Mar 14, 2020 at 4:09 PM
    CrippledHo
    Eric
    2016 DCSB Diet Coke
    maybe if you remove the calipers you'll be good. Who needs those anyway
  12. Mar 14, 2020 at 4:10 PM
    Superdave1.0
    SoCal
    CrippledHo likes this.
  13. Mar 14, 2020 at 4:12 PM
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Drums are better anyways. Get the Pelfreybilt front drum conversion kit. Think TacomaBeast carries it.
    CrippledHo[QUOTED] likes this.
  14. Mar 14, 2020 at 4:19 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    Function over beauty, I like it! I think I saw those on RobMotive’s channel...
    shane100700[QUOTED] likes this.
  15. Mar 14, 2020 at 4:21 PM
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    I heard Pelfreybilt is hard to get a hold of, but if you just send them the 50% down, they will get back to you. :rofl:
  16. Mar 14, 2020 at 4:22 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    That is a good thing though, right? They will be “right size” when finished the finishing process. There was a Red Green episode on this if I recall correctly. :woot:
    shane100700 likes this.
