3rd gen Tail, license plate, and front running lights out.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DanGit, Oct 6, 2023.
  1. Oct 6, 2023 at 6:28 AM
    DanGit
    DanGit [OP] Member
    There's a few posts on it, but they all are dead before an answer.
    2023 TRD OR.
    I switched to led BULBS only with resistors. When I did my turn and brake worked, but I lost tail, front marker, and license plate. I switched the assembly to Alpha Rex, and have the same problem.
    The 7.5 fuse is good, I replaced it. And it has battery power. There has to be a simple answer and I don't know what it is.
    I can't find a relay for them. Is it possible I cooked a wire? BCM? I don't know enough about electrical or these trucks to be honest.
    Any help is appreciated.
  2. Oct 6, 2023 at 6:58 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    did you try to switch back to the OE bulbs and headlights?
    I would go there next after having checked fuses.
    there is no relay, blinkers are controlled by the ECM
    RIX TUX likes this.
  3. Oct 6, 2023 at 8:21 AM
    DanGit
    DanGit [OP] Member
    I did. I put the old bulbs back in and flipped them all every way possible.
  4. Oct 6, 2023 at 1:34 PM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Cooked wire or bad ground. Don’t mess with mother tacoma
  5. Oct 6, 2023 at 1:39 PM
    Neal4x4
    Neal4x4 Well-Known Member
    Southern California
    Truck.
    when you put the old bulbs back in did they work?
  6. Oct 6, 2023 at 2:39 PM
    DanGit
    DanGit [OP] Member
    Nope, same problem, different bulb.
  7. Oct 6, 2023 at 2:41 PM
    DanGit
    DanGit [OP] Member
    I was a little mad I bought an "LED package" and my rear bulbs were incandescent. In my genius mind I thought, well that's a simple fix.... man was I wrong.
  8. Jan 4, 2024 at 6:54 PM
    DanGit
    DanGit [OP] Member
    So somewhere someone had an answer to this, the final consensus was I burnt out the fuse block under the driver's seat. I am supposed to pick it up tomorrow and I can post a picture.
    My wallet is recommending you don't make the mistake I did and use resistors.
    Chew likes this.
