3rd Gen Throttle body spacer
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JOHNNIE TOY, Aug 2, 2021.
  1. Aug 2, 2021 at 10:46 PM
    JOHNNIE TOY
    JOHNNIE TOY [OP] ToyLover
    Johnnie
    Tucson,Az.
    2017 Toyota Taco TRD Off Road
    2.5" Bilstein lift, 285/70R17 BFG ko2 tires. Method 17" Race Wheels, K&N air intake system, custom mesh grill, upgraded LED lighting throughout the whole truck, including light bars ditch lights rear bumper lights, Taco Tunes 1000 watt plug and play system.
    So has anyone used or bought the throttle body spacer for there 3gen taco? Is it worth it Or not? . I was thing of buying one. Thanks
  2. Aug 2, 2021 at 11:22 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    "The" throttle body spacer? There are many. All of them are complete bullshit.
    zoo truck, ConantTaco and Steves104x4 like this.
  3. Aug 2, 2021 at 11:38 PM
    JOHNNIE TOY
    Johnnie
    Tucson,Az.
    So your saying it don't do what they say they do? Or just not worth the money ?
  4. Aug 2, 2021 at 11:42 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Save your money
    Skydvrr and ConantTaco like this.
  5. Aug 2, 2021 at 11:58 PM
    GrundleJuice
    Michigan
    2016 TRD Bro
    Both. Modern EFI engines would need an adjustment to the calibration ("tune") even if the spacers did anything useful. The factory calibration is setup to be nominal for the intake plenum volume, runner length and pressure wave tuning of the OEM hardware. adding a spacer will at best do nothing, at worst it will hurt. If changing the torque curve and torque peak location on the curve is your goal, a TB spacer might be part of the formula along with charges to the factory ECU calibration/tune and exhaust side hardware changes. The factory intake manifold is a variable length runner design, too, which complicates how increasing the plenum volume changes things.
  6. Aug 3, 2021 at 12:12 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Throttle body spacer does nothing. Plenum spacers can help torque. That’s about it. But the trade off with plenum spacers is the loss of top end due to longer intake runners.
    Moral of the story? Save the money on a spacer and just put it into suspension/boost/audio… anything other than a spacer…
    Chew and 4x4Taco2012 like this.
  7. Aug 3, 2021 at 12:36 AM
    JOHNNIE TOY
    Johnnie
    Tucson,Az.
    Grundle juice. Thank you for that info. Make sense to me. Empty_Lord thank you for your info. So no spacer for me. This is what I needed to know. I'll use the money some place else. Thanks
    Steves104x4 and Empty_Lord like this.
  8. Aug 3, 2021 at 3:38 AM
    JEFFRPM
    JEFFRPM Well-Known Member
    Jeff
    2018 inferno Double cab long bed 4x4
    17 x 8.5 KMC wheels, yokohama 285-70-17 geolander, 3" lift, 800 watts of alpine, leer shell, front & rear cloud cameras,
    Buy a chrome tail pipe tip while your at it......both are worth NOTHING
    zoo truck likes this.
  9. Aug 3, 2021 at 5:15 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Save your money, throttle body spacers only work for throttle body fuel injection or carbonated engines. They serve no purpose in engines that are multi port, or direct port as ours. I guess if your into hearing some spacers make whistling sound like having a supercharger on the engine that's another thing.
