3rd gen to 2nd gen TRD OR susp bushings?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Burritopa, Apr 22, 2023.
  1. Apr 22, 2023 at 3:11 PM
    Burritopa
    Burritopa [OP] Well-Known Member
    Sean
    NSB, FL
    '15 PreRunner 4 door 4 banger 5 bed
    Hey folks, new here. Hailing from the east coast of Americas schlong.
    Got my first Tacoma a few weeks ago ('15 prerunner) and I've been studying the forum and it's info like its my job.
    I've got some nicer wheels/tires on the way (needed to replace the 3rd world rubber thats on it anyhow) and made sure they fit thanks to the forum.
    That said I'd like to level the front up a bit and replace the 113k mi struts/springs without going crazy (my ranger was lifted and a horror on the hwy... I'm over that sh) ...so I found a local fella with some 2020 TRD OR's with about 4k on em before he went to Fox - I procured em for 160 which seemed a fair price.
    Picked em up today, they look great but one of the rears (which he did divulge to me) is missing the bushing and the nut.
    Will my current OEM struts be able to have the bushings/nut removed to place on the new setup or should I buy new bushings for a full freshie... and if so whats a good brand?
    Thanks to the 3 to 2 gen susp swap thread I went this route - great info
    wi_taco likes this.
  2. Apr 22, 2023 at 3:54 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    2015 Toyota Sienna with rear locker
    Welcome to Tacoma World. If you are talking about the upper bushing insulator that gets sandwiched in between the washers where it mounts to the frame then yes they should be the same 2nd gen and 3rd gen with stock shocks. I did a quick search and came up with part number 90540-A0007. Pretty cheap, you can get them at the dealer or your local parts store. Should be able to re-use the original washer and nut (or if it's a lock nut you can probably get one of those locally too).
    Burritopa[OP] likes this.
  3. Apr 22, 2023 at 5:03 PM
    Burritopa
    Sean
    NSB, FL
    Thanks for the heads up and the part number, that'll give me a leg up
    Guess I might as well get some new ones since those bushings rot and dry up after awhile.... atleast on the Rangers they do
    :cheers:
  4. Aug 28, 2023 at 8:00 AM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    I found this thread during a search for part numbers too. I thought I'd post up in case others were looking.
    The part numbers are:
    Bottom Bushing 90540-A0008
    Top Bushing 90540-A0007
    They're $6-$7 each. I found all 4 on ebay for around $27 shipped. OEM from a toyota dealer.
    wi_taco[QUOTED] likes this.
