3rd Gen to 4th Gen… was it worth it?
Discussion in '4th Gen. Tacomas (2024+)' started by jrshaw91450, Jul 7, 2024.
  1. Jul 7, 2024 at 6:42 PM
    jrshaw91450
    jrshaw91450 [OP] Well-Known Member
    Maui
    2019 Cement Tacoma TRD OR 4x4
    TRD Cat back & Skid plate
    Owner of a 2019 here. Just trying to get a feel of those that went from a 3rd gen to a 4th gen and after the newness wore off, if it was ether “worth it”, “Meh” or “should have kept my payed off 3rd gen”
    I test drove a 4th gen and liked it, but everything is great being that its different and new.
    Rus TRD and Gfenza89 like this.
  2. Jul 7, 2024 at 6:56 PM
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    Test drove 2 have had deposits on 3 and offered 3 buyer backouts. Have never been this indecisive about a new taco and usually I’m like sold, take my money. I did a write up but it’s def a different truck from prior gen’s. But if you like it grab it!
  3. Jul 7, 2024 at 7:32 PM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    I looked at one was not impressed enough to justify paying that amount for one . But if u like it go for it .
  4. Jul 7, 2024 at 7:43 PM
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    sure, unless you prefer a motor with no torque, less mpg and a transmission that doesn't know what gear it wants to be in. :popcorn:
    BearWithMe, Mb.1, Motor Away and 5 others like this.
  5. Jul 7, 2024 at 8:14 PM
    Digitalwiz5
    Digitalwiz5 Well-Known Member
    Same old conversation comes up…blah blah. I had a 2nd gen and yeah, 4th is way better all the way around. It’s better than the 3rd gen I helped my daughter pick out. It’s just better. That’s not saying it has the same long term reliability, we wont know that for some time but when it’s working, which is always so far, it’s better.
  6. Jul 7, 2024 at 8:17 PM
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    @Mallcrawler20 and @TacoBuffet do not own one so their posts are void. Not even sure why they’re commenting.
    I had a ‘21 TRD OR and my new truck is leaps ahead and zero post buyers remorse after 1600 miles.
    Engine actually makes low end power so you don’t need to ring it out at all. Rarely get over 3500rpm
    Shifts are very very smooth. Instead of downshifting, it’ll spool up a bit and get you going. A steep hill I commute on would normally need 4th gear, sometimes even 3rd. This truck can do it in 8th gear without downshifting.
    Around 20/21mpg with 33s. In a hilly region.
    Seating position is way better and more comfortable.
    Things I’m not crazy about are the 18 gallon tank and the turning radius. But both are livable.
    BlkTaco47, brigsby99, Mb.1 and 4 others like this.
  7. Jul 7, 2024 at 8:33 PM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    I think taco buffet just got one
    50Buck likes this.
  8. Jul 7, 2024 at 8:56 PM
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    Wrong, did you even read his post?
  9. Jul 7, 2024 at 8:58 PM
    IEsurfer
    Socal
    No hence why I said I think he got it
    Steves104x4 likes this.
  10. Jul 7, 2024 at 9:01 PM
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    How about we help the OP and post if we actually have one. Like he asked for. :smack:
  11. Jul 7, 2024 at 11:00 PM
    hemlockz
    hemlockz Well-Known Member
    24 Bronze ORP 6MT
    You have a nice truck, but factory warranty running out. How many miles?
    I already sold my 3rd gen, mostly because it had some engine issues so was easy to say bye, and shopping for a ‘24 currently.
    Steves104x4 and Gfenza89 like this.
  12. Jul 8, 2024 at 2:43 AM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    For the first time since 2005 we have a completely new truck. Fully boxed beefed up frame, coil spring rear suspension, rear disc brakes, powerful engine with great torque, completely new modern styling. Modern technology finally. What’s there not to be excited about? Almost 20 years of the “same truck” time to move on and glad I did even with the “risks”
  13. Jul 8, 2024 at 3:13 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I really like mine. For having just an SR5 it's got plenty of features and nothing I don't need. First time I've had a heated steering wheel on a vehicle, that was an interesting surprise.
    The new turbo 4 and 8 speed automatic is finally a good matched pair unlike the 3rd gens 3.5 and 6 speed combo's (both AT and MT, I've owned both). I consistently get 24-25 mpg hand calculated each tank.
  14. Jul 8, 2024 at 3:18 AM
    Gfenza89
    Agreed, the seating position finally is normal. Never had heated seats will be so nice in winter. Your spot on with the pairing of the engine and trans too.
    Steves104x4 and Delta09[QUOTED] like this.
  15. Jul 8, 2024 at 3:21 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Heated seats are awesome in the winter. I've had several vehicles with them!
    I will say keep an eye on the oil level. My truck is about 2,000 miles in and appears to have used a little oil. I feel like I'm owning a turbo VW again... o_O
  16. Jul 8, 2024 at 3:22 AM
    Gfenza89
    Owners booklet says oil usage during break in is normal. Thanks I’ll keep an eye on it though
    Delta09[QUOTED] likes this.
  17. Jul 8, 2024 at 3:25 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    That's why I'm not concerned too much. Same thing happened on my GTI that I bought new. Finally leveled out. If SHTF I'll just turn it in after my 3 years and buy something else :laugh:
    However for folks that don't check things that might prove interesting if they go by the book... o_O
    Gfenza89[QUOTED] likes this.
  18. Jul 8, 2024 at 3:26 AM
    Mallcrawler20
    Technically I owned it for 20 min lol but whatever forum police .
  19. Jul 8, 2024 at 3:28 AM
    Gfenza89
    jaybird099 likes this.
  20. Jul 8, 2024 at 4:19 AM
    TOMRR
    TOMRR Well-Known Member
    Tom
    Mass
    2016 TRD OFFROAD, DCSB, AUTO, BLAZING BLUE, PREMIUM JBL TECT.
    Stock TRD OFF ROAD DCSB AUTO JBL TECT. Bed Mat Heated and turn signal mirrors Wet Okole Front Seat Covers Prodigy Brake Controler Front Skid Plate Power Wagon Badge Tint Driver and Pessenger door windows Inchannel window vents
    I had my 2016 OFF ROAD for 8 years. Had some early issues the first year. I will admit at first, I did miss it. but now Iam really442422628_7561781393887569_5126198926060194377_n.jpg into my 4th Gen Off Road.
    gmtech, Steves104x4 and Gfenza89 like this.
