3rd gen torque converter shudder
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MarlonB54, Feb 11, 2021.
  1. Oct 4, 2022 at 8:24 PM
    #241
    MarlonB54
    MarlonB54 [OP] Well-Known Member
    Fishaholic
    22’ Barcelona Red TRD Off Road
    Update on the truck. Ive been driving it with very light vibrations at the range stated before. CVC tune helped out a ton. Im back on here to report at 14,000 mi vibrations are starting to be more noticeable again. I will be looking to reset the transmission learning and also the ecu learning. Hopefully this helps. For the most part, vibrations were less but it may also have been me sucking it up and just not paying attention to it.
    zacinnc78 likes this.
  2. Oct 7, 2022 at 12:04 PM
    #242
    zacinnc78
    zacinnc78 Well-Known Member
    Still deciding which taco to order
    this is what id like to know
  3. Oct 7, 2022 at 12:06 PM
    #243
    zacinnc78
    how do u reset those things?dealer?
  4. Oct 7, 2022 at 7:45 PM
    #244
    Sinister184
    Sinister184 Well-Known Member
    23 Tacoma TRD OR 4x4
    My previous 17' AT had this shudder every time I drove it. Sumbich buries itself into 6th gear every chance it gets and then doesn't want to let it go, which causes the truck to shudder as it struggles for life. There's really only one way to fix it, and that's to get a manual, which, so far, drives wonderfully.
    AmateurTaco1313 and The_vue's like this.
  5. Dec 25, 2022 at 12:58 PM
    #245
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    Just started having this issue. 2018 automatic OR, Ovtune 2.0, 70k miles. I noticed when it shifts down from 3rd to 2nd and I start to creep on the accelerator is when I experience it. Straight acceleration from lower speeds no problem. It's when I'm slowing down from like 30 to 20 and trying to slowly go back up to 30. Right between 1100 to 1500rpm. If I accelerate hard it doesn't happen.
    I'm also having my trans fluid completely drained and filled this week so I'm curious to see if this makes it go away since this will be my first time doing that.
    It's also been below freezing here for over a week so I wonder if that could have anything to do with it. Although I notice it can happen when the truck is totally warm too... frustrating.
  6. Dec 28, 2022 at 7:38 AM
    #246
    TS4x4
    2018 TRD Offroad
    Update:
    Seems smooth after a total drain and refill. First time doing it and my mechanic said he drained only about 4.5qts and it took 6 to fill. No signs of leaks so that means I've been running it under filled for all 72k miles of it's life. Fml.
    I also suspect that a lift, armor, and heavy tires has something to do with the trans fluid degrading faster. I guess I'll add trans fluid drain and fill to my every 50k mile maintenence. To me its worth the cost for the piece of mind.
  7. Dec 28, 2022 at 7:26 PM
    #247
    zacinnc78
    in the back of my mind id be worried its overfilled now and i would have to do the level check procedure lol
  8. Dec 29, 2022 at 4:13 AM
    #248
    TS4x4
    2018 TRD Offroad
    Yeah I definitely get that, but I trust my mechanic. He's a friend of mine and has kept my prior sh!tboxes running smooth before owning the Taco lol.
  9. Jan 5, 2023 at 9:04 PM
    #249
    ATXJoshL
    ATXJoshL Well-Known Member
    Josh
    2018 Tacoma TRD Pro Black
    1-1/4” Spacers, Tires: Goodyear Wrangler Duratrac, hard bed cover, Fuelpax custom-mounted on bed rail.
    I have a 2018 TRD Pro, 80k miles on it. About 2 weeks ago, I noticed a similar shudder to what you’re describing, I believe it is as soon as it shifts into 3rd gear, the rpm’s drop really low and starts shuddering. So only if I’m accelerating slowly. I didn’t do anything different, it just suddenly started happening. I have never changed my tranny fluid, I don’t believe it’s recommended yet, but if you’re saying it helped you, I’d be happy to try it. It’s quite annoying.
  10. Jan 6, 2023 at 3:14 AM
    #250
    TS4x4
    2018 TRD Offroad
    Sounds about like what I experienced. So far so good with mine after the drain and fill. Toyota says to do it around 90k but with armor, towing frequently, etc., it caused mine to fail faster.
    ATXJoshL[QUOTED] likes this.
  11. Jan 6, 2023 at 4:38 AM
    #251
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Seems these shudder issues don't happen on many gen 3 trucks from what i heard when talking with a friend that runs a large auto repair garage. I can tell you i don't have it. He sees a good number of all year tacoma's come it for oil, and all general fluid changes...he uses amalie for them of all brands...claims its good stuff.
    Canadian Caber, usmc2msu and ATXJoshL like this.
  12. Jan 7, 2023 at 7:52 AM
    #252
    Mgump3
    Mgump3 Member
    Matthew
    2016 Tacoma DCab Sport
    None
    Do the change and maybe add shudder fix as well. I had lower miles on mine when it started happening to me. Turns out my tranny fluid level was low which I think was common as I recall a long thread on it here. It could have been the replacement to the correct level that resolved but I added the shudder fix juice as well.
    https://www.tacomaworld.com/threads...ar-between-1500-2000rpm.529507/#post-28239927
  13. Jan 13, 2023 at 9:34 PM
    #253
    Lhd
    Lhd Active Member
    The OC.
    2021 Tacoma TRDPro Lunar Rock
    Just my 2cents but in my manual for my 21 trd pro it states 30k drain and fill on the trans ,15k on diffs and transfer case and 60k on plugs. I’m old school and Change my oil at 3k trans every 30k and diffs every 15k. Coolant once a year. This is my first Tacoma with now 5200 miles. My 97 4Runner has 336k on it and I service it the same way. I’ll be doing the same service intervals as I’ve always done and hope I get the mileage out of this one. I don’t like how the factory keeps pushing their services further out.
  14. Jan 14, 2023 at 5:00 AM
    #254
    Sinister184
    To each his own, but that’s all definitely way overkill on all aspects (except maybe the first trans change). Oil and filters are not what they were 30 years ago. Just one example, but Toyota long life coolant is a 5 year fluid. If you’re dumping that once a year youre just flushing a perfectly good product.
  15. Jan 14, 2023 at 5:12 AM
    #255
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    does the diff fluid really need to be changed every 15K miles?
  16. Jan 14, 2023 at 5:22 AM
    #256
    usmc2msu
    usmc2msu Well-Known Member
    TJ
    2017 SR5
    Abominator likes this.
  17. Jan 14, 2023 at 5:41 AM
    #257
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    usmc2msu[QUOTED] likes this.
  18. Jan 14, 2023 at 7:08 AM
    #258
    zoo truck
    None
    I know my gen1 tundra auto recommended a 4 qt drain and refill every 15k miles, but it used dexron3 atf. I never had a transmission issue in nearly 300k miles in 19 years owning that truck doing that. The transmission still felt fresh. I plan on a similar deal with my sr5 tacoma auto, but at 30k miles. I think this lifetime fluid change for these trucks is really pushing it. Their lifetime, or mine?
    Lhd likes this.
  19. May 11, 2023 at 8:44 PM
    #259
    maronesjsk8
    maronesjsk8 I am here for help. I am dumb.
    Marone
    Communist California
    2023 Overpriced Tacoma
    Stuff I don't need.
    Well…after a few thousand miles after it first reared it shuddery head around 6000 miles and checking to see what this truck would do, I still have shudder at 10,500 miles and it won’t go away. Mine is at 60mph, and when I have a contestant speed going uphill around 1700 RPM. Now I have a tune, the OTT and wondering if that’s the cause of it. I do buy cheap gas, so going to try upgrading gas to see if that helps. Truck of my dreams…drives like sh!t, first brand new truck, and I dumped a bunch of money into it already. (Shell, seat covers, racks, new tires,etc etc…) so I’m kinda stuck with it. Any suggestions would be great. Tuner said have dealer check transmission fluids, then there’s that story…the Dealers around me are horrible. Might try KDMAXX tune and see how that goes. At least I got a free oil change at 10,500 miles.:p:D
  20. May 11, 2023 at 10:21 PM
    #260
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Get a high throttle settings tune.
