3rd gen torque converter shudder
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MarlonB54, Feb 11, 2021.
  1. Feb 13, 2021 at 11:39 AM
    #101
    MarlonB54
    MarlonB54 [OP] Well-Known Member
    Fishaholic
    22’ Barcelona Red TRD Off Road
    So when do I start feeling differences with Ovtune now intstalled???
    GrievousAngel and bulalo like this.
  2. Feb 13, 2021 at 1:36 PM
    #102
    MarlonB54
    Fishaholic
    Ok, what does this do?
  3. Feb 13, 2021 at 3:25 PM
    #103
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Reset some learning values
    MarlonB54[QUOTED][OP] likes this.
  4. Feb 13, 2021 at 8:19 PM
    #104
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Right away, at least that’s what I experienced . I have the 2017 so it’s a huge difference from stock.
  5. Feb 13, 2021 at 10:44 PM
    #105
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    FWIW, this was a known thing in the FJ community. TC shudder. Eventually Toyota owned up to it and warranty repairs were authorized. For me, it was a specific rpm and load. Could happen in all gears. But I could make it happen at will. Eventually, my brain and right foot teamed up and just avoided those scenarios. Take it out of ‘D’ and it stopped immediately. But that was in the 4.0. Mine started at about 60k miles. I sold it at about 190k miles and it hadn’t changed one bit in that time.
    I even downloaded a $0.99 app to monitor vibrations and it was the same frequency no matter the gear.
  6. Feb 14, 2021 at 5:39 AM
    #106
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I've had a few toyota 4wd trucks, and a couple cars over my 50+ years driving time, plus drive numerous chevy, dodge, jeep, and ford trucks of the past. This 2020 taco i have now is as good or better than all of them. There just isn't any vibration i can detect.
  7. Feb 14, 2021 at 5:41 AM
    #107
    MarlonB54
    Fishaholic
    Good for you. I didn’t detect anything for the first 4,000 miles which is why is was very happy.
    Lt. Dangle likes this.
  8. Feb 14, 2021 at 5:43 AM
    #108
    N5J_Taco
    N5J_Taco Well-Known Member
    Yeah I got all my vibrations worked out, mine was self induced after a lift.
  9. Feb 14, 2021 at 10:29 AM
    #109
    513Mugsy
    513Mugsy Well-Known Member
    Cincy
    2020 VOODOO AC OR MT sold now
    So I gotta to know...did the tune help? Or is it still the same?
    I don't have the tune. But I do notice exactly what what the video shows. Where the transmission is not tuned correctly and hunts gears in my 2021 OR auto.
  10. Feb 14, 2021 at 10:36 AM
    #110
    MarlonB54
    Fishaholic
    The tune did not help me with my shudder but the truck stopped hunting for gears and the shifting was much smoother and better pedal response.. the tune will help you with what you’re describing
  11. Feb 14, 2021 at 11:19 AM
    #111
    513Mugsy
    Cincy
    So which tune are you running then? 87 or 93?
  12. Feb 14, 2021 at 11:23 AM
    #112
    MarlonB54
    Fishaholic
    87, i was recommended to try 93 next. Ill try 93 after I see what another dealership decides to do with my truck for now
  13. Feb 14, 2021 at 11:26 AM
    #113
    513Mugsy
    Cincy
    Thanks for the information! Hope your fix comes soon. I will watch this thread to see.
    slvrtaco11 likes this.
  14. Feb 14, 2021 at 3:29 PM
    #114
    MarlonB54
    Fishaholic
    Thank you
  15. Feb 15, 2021 at 5:38 AM
    #115
    zoo truck
    None
    I can't understand what is the matter with toyota's current tune. Maybe my expectations of these trucks isn't the same as what others think they should be. If i wanted a truck with over 400 hp. i would of went elsewhere.
  16. Feb 15, 2021 at 6:24 AM
    #116
    N5J_Taco
    On stock older trucks the tune sucked, the auto transmission shifted constantly on small hills/head winds. It just got worse if you add bigger tires or weight to the truck. OVTune has reworked the base tune to fix a lot of those issues, more like an enhanced stock tune. Now that VFTUNE has been out tunes from @PapaRee, @Mooseditty17, @TWTaco, and others have taken it to another level. Aggressive/better throttle response, transmission holds gears better, and so on. Each truck is different as far as weight/tire size so the tune lets us adjust for our specific truck and driving situation. Can't speak for the new Tacoma models/stock tune but sounds like if you stay stock the newer tune is fine.
    PapaRee likes this.
  17. Feb 15, 2021 at 6:29 AM
    #117
    MarlonB54
    Fishaholic
    its still hunts gears a bit but overall, I was very happy with how the truck drove at first. I didn’t really experience all of the complaints about the transmission that everyone else had until lately..
  18. Feb 15, 2021 at 7:10 AM
    #118
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Or maybe you aren't experiencing the same issue that OP or others are and repeatedly stating that your truck is fine and you have no problems isn't really contributing anything meaningful and helpful? Maybe other trucks don't run just like yours?
    zacinnc78, slvrtaco11 and RX1cobra like this.
  19. Feb 15, 2021 at 7:13 AM
    #119
    Lt. Dangle
    Ohio
    OP, you have moved past this with the OV tune, but my truck has a bad miss on 87 and I have to run 89 or 93 to get it nice and smooth. a tank of 87 will result in a miss bad enough that you'd swear it is a driveline vibe. I know you have landed on the Tranny being the culprit, but I'd only recommend keeping an open mind about what could be the issue. Good luck getting it sorted out.
  20. Feb 15, 2021 at 7:46 AM
    #120
    MarlonB54
    Fishaholic
    thanks for the insight. Multiple people have recommended running the 93 tune to me and i am considering it after I get a response from another dealership atm.
    Lt. Dangle[QUOTED] likes this.
